[GRASS-QA] GRASS QA: hamish |read.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Wed Aug 26 20:24:28 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/symbol/read.c
          Function
S_read(Begins at: 230, Ends at:469)
              |          New Metrics           |Old Metrics|
Complexity:   |      35 |       |           OK |        35 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      85 |       |           OK |        85 |
LOC:          |     240 |       |           OK |       240 |
Conclusion:   | this function is a            OK           |
metrics are OK
add_chain(Begins at: 99, Ends at:109)
Complexity:   |       2 |   *** |      MONSTER |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |      11 |   *** |      MONSTER |        11 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
add_element(Begins at: 130, Ends at:138)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
add_part(Begins at: 71, Ends at:80)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
add_point(Begins at: 156, Ends at:170)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
err(Begins at: 215, Ends at:221)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       7 |       |           OK |         7 |
get_key_data(Begins at: 33, Ends at:54)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
new_arc(Begins at: 173, Ends at:186)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a  BABY-MONSTER           |
new_chain(Begins at: 114, Ends at:127)
metrics are OK
new_line(Begins at: 142, Ends at:153)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
new_part(Begins at: 84, Ends at:96)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
new_symbol(Begins at: 58, Ends at:68)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
read_coor(Begins at: 189, Ends at:212)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Aug 26 20:02:57 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
