[GRASS-QA] GRASS QA: marisn |open.c generate.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Aug 28 05:07:50 EDT 2009
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/form/open.c
          Function
F_clear(Begins at: 160, Ends at:173)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
F_close(Begins at: 175, Ends at:190)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
F_open(Begins at: 49, Ends at:154)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
LOC:          |     106 |    ** | BABY-MONSTER |       106 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
make_socketpair(Begins at: 193, Ends at:201)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/v.digit/generate.c
          Function
F_generate(Begins at: 13, Ends at:253)
Complexity:   |      22 |   *** |      MONSTER |        22 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
CalledNBR:    |     107 |   *** |      MONSTER |       107 |
LOC:          |     241 |   *** |      MONSTER |       241 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Aug 28 04:45:47 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
