[GRASS-QA] GRASS QA: huhabla |local_proto.h main.c matrix.c stats.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Aug 27 17:14:56 EDT 2009
Hello huhabla,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/imagery/i.cca/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/branches/develbranch_6/imagery/i.cca/main.c
Function
main(Begins at: 48, Ends at:223)
| New Metrics |Old Metrics|
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 76 | *** | MONSTER | 76 |
LOC: | 176 | *** | MONSTER | 176 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/imagery/i.cca/matrix.c
Function
getsqrt(Begins at: 34, Ends at:46)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
matmul(Begins at: 59, Ends at:74)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 16 | | OK | 16 |
product(Begins at: 7, Ends at:17)
Complexity: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
setdiag(Begins at: 20, Ends at:31)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 12 | | OK | 12 |
solveq(Begins at: 49, Ends at:56)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
Clone analysis:
File :grass/branches/develbranch_6/imagery/i.cca/stats.c
Function
between(Begins at: 29, Ends at:76)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 48 | * | WARNING | 48 |
Conclusion: | this function is a BABY-MONSTER |
within(Begins at: 5, Ends at:26)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 22 | | OK | 22 |
Clone analysis:
File :grass/branches/develbranch_6/imagery/i.cca/transform.c
Function
transform(Begins at: 7, Ends at:54)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 12 | * | WARNING | 12 |
Clone analysis:
File :grass/branches/develbranch_6/imagery/i.pca/main.c
Function
calc_covariance(Begins at: 276, Ends at:343)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 33 | ** | BABY-MONSTER | 33 |
LOC: | 68 | * | WARNING | 68 |
calc_mu(Begins at: 225, Ends at:273)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 49 | * | WARNING | 49 |
at least 4 values are close to an outlier please consider revising code!
dump_eigen(Begins at: 532, Ends at:549)
LOC: | 18 | | OK | 18 |
main(Begins at: 45, Ends at:176)
CalledNBR: | 57 | *** | MONSTER | 57 |
LOC: | 132 | ** | BABY-MONSTER | 132 |
round_c(Begins at: 179, Ends at:191)
ParamNBR: | 1 | | OK | 1 |
Conclusion: | this function is a OK |
metrics are OK
set_output_scale(Begins at: 194, Ends at:222)
Complexity: | 5 | | OK | 5 |
LOC: | 29 | | OK | 29 |
write_pca(Begins at: 346, Ends at:528)
Complexity: | 28 | *** | MONSTER | 28 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 52 | *** | MONSTER | 52 |
LOC: | 183 | *** | MONSTER | 183 |
Clone analysis:
File :grass/branches/develbranch_6/imagery/i.smap/bouman/model.c
Function
extract(Begins at: 68, Ends at:163)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 96 | ** | BABY-MONSTER | 96 |
extract_init(Begins at: 10, Ends at:65)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 56 | * | WARNING | 56 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/branches/develbranch_6/raster/r.gwflow/main.c
Function
copy_result(Begins at: 483, Ends at:517)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 35 | | OK | 35 |
create_solve_les(Begins at: 522, Ends at:571)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 50 | * | WARNING | 50 |
main(Begins at: 199, Ends at:477)
Complexity: | 33 | *** | MONSTER | 33 |
CalledNBR: | 100 | *** | MONSTER | 100 |
LOC: | 279 | *** | MONSTER | 279 |
set_params(Begins at: 51, Ends at:194)
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 144 | *** | MONSTER | 144 |
Clone analysis:
File :grass/branches/develbranch_6/raster3d/r3.gwflow/main.c
Function
main(Begins at: 150, Ends at:356)
CalledNBR: | 89 | *** | MONSTER | 89 |
LOC: | 207 | *** | MONSTER | 207 |
set_params(Begins at: 48, Ends at:145)
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
LOC: | 98 | ** | BABY-MONSTER | 98 |
write_result(Begins at: 362, Ends at:429)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Aug 27 16:53:05 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
