[GRASS-QA] GRASS QA: hamish |close_down.c main.c param.c param.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Feb 4 11:25:41 EST 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.param.scale/close_down.c
          Function
close_down(Begins at: 14, Ends at:127)
              |          New Metrics           |Old Metrics|
Complexity:   |      13 |    ** | BABY-MONSTER |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      36 |    ** | BABY-MONSTER |         5 |
LOC:          |     114 |    ** | BABY-MONSTER |        15 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.param.scale/main.c
          Function
main(Begins at: 36, Ends at:56)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.param.scale/param.c
          Function
param(Begins at: 20, Ends at:85)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      66 |     * |      WARNING |        66 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/param.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Wed Feb 04 11:49:27 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
