[GRASS-QA] GRASS QA: neteler |form.c driver.c form.c anim_support.c ...| 79 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Feb 6 11:35:50 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/form/form.c
          Function
Tcl_AppInit(Begins at: 267, Ends at:299)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      33 |       |           OK |        33 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 301, Ends at:308)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
reset_values(Begins at: 30, Ends at:40)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
set_value(Begins at: 42, Ends at:71)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      30 |       |           OK |        30 |
 at least 3 values are close to an outlier please consider revising code!
submit(Begins at: 74, Ends at:262)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      92 |   *** |      MONSTER |        92 |
LOC:          |     189 |   *** |      MONSTER |       189 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 3 potentially cloned functions:
  set_value  submit
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c clones of reset_values are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c  reset_values
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c clones of set_value are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c  set_value
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c clones of submit are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c  submit
          File :grass/branches/develbranch_6/vector/v.digit/driver.c
          Function
driver_close(Begins at: 118, Ends at:121)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
driver_cont_abs(Begins at: 30, Ends at:41)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
driver_line_width(Begins at: 16, Ends at:19)
metrics are OK
driver_move_abs(Begins at: 23, Ends at:28)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
driver_open(Begins at: 96, Ends at:116)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      21 |       |           OK |        21 |
driver_plot_icon(Begins at: 43, Ends at:55)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      13 |       |           OK |        13 |
driver_refresh(Begins at: 88, Ends at:94)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
driver_rgb_color(Begins at: 11, Ends at:14)
CalledNBR:    |       1 |       |           OK |         1 |
get_window(Begins at: 57, Ends at:69)
setup(Begins at: 71, Ends at:86)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/v.digit/form.c
          Function
Clone analysis:
  set_value  submit
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c clones of reset_values are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c  reset_values
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c clones of set_value are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c  set_value
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.digit/form.c clones of submit are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/form/form.c  submit
          File :grass/branches/develbranch_6/visualization/nviz/src/anim_support.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/visualization/nviz/src/cutplane_obj.c
          File :grass/branches/develbranch_6/visualization/nviz/src/do_zoom.c
          Function
Create_OS_Ctx(Begins at: 369, Ends at:422)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      54 |     * |      WARNING |        54 |
Destroy_OS_Ctx(Begins at: 428, Ends at:463)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      36 |       |           OK |        36 |
Error_Handler(Begins at: 360, Ends at:366)
metrics are OK
Nstart_zoom_cmd(Begins at: 46, Ends at:212)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
LOC:          |     167 |   *** |      MONSTER |       167 |
create_pbuffer(Begins at: 236, Ends at:307)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      72 |     * |      WARNING |        72 |
create_pixmap(Begins at: 309, Ends at:357)
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      49 |     * |      WARNING |        49 |
init_ctx(Begins at: 468, Ends at:501)
LOC:          |      34 |       |           OK |        34 |
swap_os(Begins at: 218, Ends at:230)
metrics are OK
Clone analysis:
          File :grass/branches/develbranch_6/visualization/nviz/src/draw.c
          Function
CancelFunc_Hook(Begins at: 32, Ends at:37)
metrics are OK
Nauto_draw_cmd(Begins at: 463, Ends at:472)
LOC:          |      10 |       |           OK |        10 |
Nclear_cmd(Begins at: 160, Ends at:171)
Ndelete_list_cmd(Begins at: 809, Ends at:839)
LOC:          |      31 |       |           OK |        31 |
 at least 2 values are close to an outlier please consider revising code!
Ndone_draw_cmd(Begins at: 718, Ends at:722)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Ndraw_Narrow_cmd(Begins at: 255, Ends at:281)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      27 |       |           OK |        27 |
Ndraw_ScaleBar_cmd(Begins at: 289, Ends at:314)
LOC:          |      26 |       |           OK |        26 |
Ndraw_X_cmd(Begins at: 190, Ends at:207)
LOC:          |      18 |       |           OK |        18 |
Ndraw_fringe_cmd(Begins at: 843, Ends at:864)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      22 |       |           OK |        22 |
Ndraw_legend_cmd(Begins at: 762, Ends at:807)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      46 |     * |      WARNING |        46 |
Ndraw_line_on_surf_cmd(Begins at: 318, Ends at:338)
Ndraw_model_cmd(Begins at: 340, Ends at:347)
Ndraw_wire_cmd(Begins at: 173, Ends at:187)
LOC:          |      15 |       |           OK |        15 |
Nget_def_color_cmd(Begins at: 148, Ends at:158)
Nhas_transparency_cmd(Begins at: 135, Ends at:146)
Nis_masked_cmd(Begins at: 114, Ends at:133)
LOC:          |      20 |       |           OK |        20 |
Nready_draw_cmd(Begins at: 712, Ends at:716)
metrics are OK
Nset_Narrow_cmd(Begins at: 214, Ends at:248)
LOC:          |      35 |       |           OK |        35 |
Nset_cancel_cmd(Begins at: 600, Ends at:613)
LOC:          |      14 |       |           OK |        14 |
Nset_cancel_func_cmd(Begins at: 58, Ends at:78)
Nset_draw_cmd(Begins at: 80, Ends at:100)
Nset_viewport_cmd(Begins at: 871, Ends at:892)
Nsite_draw_all_cmd(Begins at: 648, Ends at:679)
LOC:          |      32 |       |           OK |        32 |
Nsite_draw_one_cmd(Begins at: 412, Ends at:433)
CalledNBR:    |      10 |     * |      WARNING |        10 |
Nsurf_draw_all_cmd(Begins at: 496, Ends at:505)
Nsurf_draw_one_cmd(Begins at: 349, Ends at:386)
LOC:          |      38 |       |           OK |        38 |
Ntransp_is_set_cmd(Begins at: 102, Ends at:112)
Nunset_cancel_func_cmd(Begins at: 42, Ends at:53)
Nvect_draw_all_cmd(Begins at: 615, Ends at:646)
Nvect_draw_one_cmd(Begins at: 388, Ends at:410)
LOC:          |      23 |       |           OK |        23 |
Nvol_draw_all_cmd(Begins at: 681, Ends at:710)
Nvol_draw_one_cmd(Begins at: 435, Ends at:457)
auto_draw(Begins at: 479, Ends at:493)
metrics are OK
check_blank(Begins at: 730, Ends at:760)
metrics are OK
sort_surfs_max(Begins at: 511, Ends at:539)
LOC:          |      29 |       |           OK |        29 |
surf_draw_all(Begins at: 541, Ends at:597)
LOC:          |      57 |     * |      WARNING |        57 |
Clone analysis:
This file has 7 potentially cloned functions:
  Nvect_draw_one_cmd  Nvol_draw_one_cmd  Nsite_draw_one_cmd  Nvol_draw_one_cmd  Nvect_draw_one_cmd  Nsite_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c clones of Nget_def_color_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/misc.c  Nget_cancel_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c clones of Nsite_draw_one_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c  Nvect_draw_one_cmd
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c  Nvol_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c clones of Nvect_draw_one_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c  Nsite_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c clones of Nvol_draw_one_cmd are:
          File :grass/branches/develbranch_6/visualization/nviz/src/exag.c
          Function
Nget_first_exag_cmd(Begins at: 56, Ends at:83)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
Nget_height_cmd(Begins at: 86, Ends at:135)
LOC:          |      50 |     * |      WARNING |        50 |
init_default_slider_vals1(Begins at: 15, Ends at:53)
LOC:          |      39 |       |           OK |        39 |
Clone analysis:
          File :grass/branches/develbranch_6/visualization/nviz/src/lights.c
          Function
Nlight_obj_cmd(Begins at: 16, Ends at:41)
Nlights_cmd(Begins at: 61, Ends at:73)
Nnew_light_cmd(Begins at: 43, Ends at:59)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
get_light_num(Begins at: 259, Ends at:266)
metrics are OK
getlgt_ambient(Begins at: 106, Ends at:126)
getlgt_bright(Begins at: 93, Ends at:104)
getlgt_color(Begins at: 128, Ends at:148)
getlgt_position(Begins at: 150, Ends at:172)
init_new_light(Begins at: 268, Ends at:283)
metrics are OK
setlgt_ambient(Begins at: 75, Ends at:91)
setlgt_bright(Begins at: 175, Ends at:196)
setlgt_color(Begins at: 198, Ends at:221)
LOC:          |      24 |       |           OK |        24 |
setlgt_position(Begins at: 223, Ends at:243)
switchlight(Begins at: 245, Ends at:257)
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  getlgt_ambient
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/lights.c clones of getlgt_ambient are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/lights.c  getlgt_color
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/lights.c clones of getlgt_color are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/lights.c  getlgt_ambient
          File :grass/branches/develbranch_6/visualization/nviz/src/map_obj.c
          Function
Nget_site_list_cmd(Begins at: 372, Ends at:390)
LOC:          |      19 |       |           OK |        19 |
Nget_surf_list_cmd(Begins at: 322, Ends at:340)
Nget_vect_list_cmd(Begins at: 347, Ends at:365)
Nget_vol_list_cmd(Begins at: 397, Ends at:415)
Nliteral_from_logical_cmd(Begins at: 86, Ends at:189)
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |     104 |    ** | BABY-MONSTER |       104 |
Conclusion:   | this function is a  BABY-MONSTER           |
Nlogical_from_literal_cmd(Begins at: 196, Ends at:209)
Nmap_obj_cmd(Begins at: 708, Ends at:772)
Complexity:   |      28 |   *** |      MONSTER |        28 |
CalledNBR:    |      56 |   *** |      MONSTER |        56 |
LOC:          |      65 |     * |      WARNING |        65 |
Nnew_map_obj_cmd(Begins at: 432, Ends at:698)
Complexity:   |      39 |   *** |      MONSTER |        39 |
CalledNBR:    |      80 |   *** |      MONSTER |        80 |
LOC:          |     267 |   *** |      MONSTER |       267 |
att_atoi(Begins at: 2110, Ends at:2126)
delete_obj(Begins at: 951, Ends at:975)
LOC:          |      25 |       |           OK |        25 |
draw_obj(Begins at: 920, Ends at:944)
get_att(Begins at: 1552, Ends at:1699)
Complexity:   |      30 |   *** |      MONSTER |        30 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     148 |   *** |      MONSTER |       148 |
get_char_marker(Begins at: 2158, Ends at:2202)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      45 |     * |      WARNING |        45 |
get_drawmode(Begins at: 844, Ends at:912)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      69 |     * |      WARNING |        69 |
 at least 4 values are close to an outlier please consider revising code!
get_exag_guess(Begins at: 1470, Ends at:1489)
get_idnum(Begins at: 2072, Ends at:2085)
metrics are OK
get_int_marker(Begins at: 2208, Ends at:2248)
LOC:          |      41 |       |           OK |        41 |
get_logical_name(Begins at: 276, Ends at:315)
Complexity:   |       8 |     * |      WARNING |         8 |
LOC:          |      40 |       |           OK |        40 |
get_mask_mode(Begins at: 2020, Ends at:2034)
get_nozero(Begins at: 1285, Ends at:1319)
get_res(Begins at: 983, Ends at:1035)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      53 |     * |      WARNING |        53 |
get_trans(Begins at: 1162, Ends at:1200)
get_type(Begins at: 2092, Ends at:2104)
metrics are OK
get_wirecolor(Begins at: 1127, Ends at:1155)
isosurf(Begins at: 2255, Ends at:2299)
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
load_obj(Begins at: 1498, Ends at:1534)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      37 |       |           OK |        37 |
select_surf(Begins at: 1328, Ends at:1355)
set_att(Begins at: 1711, Ends at:1965)
Complexity:   |      33 |   *** |      MONSTER |        33 |
CalledNBR:    |      60 |   *** |      MONSTER |        60 |
LOC:          |     255 |   *** |      MONSTER |       255 |
set_drawmode(Begins at: 780, Ends at:837)
LOC:          |      58 |     * |      WARNING |        58 |
set_exag_obj(Begins at: 1440, Ends at:1463)
set_logical_name(Begins at: 216, Ends at:269)
set_mask_mode(Begins at: 2042, Ends at:2063)
set_nozero(Begins at: 1242, Ends at:1278)
set_res(Begins at: 1042, Ends at:1085)
LOC:          |      44 |     * |      WARNING |        44 |
set_trans(Begins at: 1207, Ends at:1235)
set_wirecolor(Begins at: 1092, Ends at:1119)
slice(Begins at: 2306, Ends at:2345)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
surf_is_selected(Begins at: 1400, Ends at:1432)
sv_att_atoi(Begins at: 2132, Ends at:2152)
unselect_surf(Begins at: 1364, Ends at:1392)
unset_att(Begins at: 1972, Ends at:2013)
LOC:          |      42 |     * |      WARNING |        42 |
Clone analysis:
This file has 15 potentially cloned functions:
  Nget_vect_list_cmd  Nget_vol_list_cmd  Nget_vect_list_cmd  Nget_site_list_cmd  Nget_vol_list_cmd  Nget_surf_list_cmd  Nget_site_list_cmd  Nget_vol_list_cmd  Nget_surf_list_cmd  Nget_vect_list_cmd  Nget_site_list_cmd  isosurf_att_atoi  unselect_surf  select_surf
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of Nget_site_list_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  Nget_surf_list_cmd
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  Nget_vect_list_cmd
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  Nget_vol_list_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of Nget_surf_list_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  Nget_site_list_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of Nget_vect_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of Nget_vol_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of att_atoi are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_att_atoi
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of select_surf are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  unselect_surf
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c clones of unselect_surf are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  select_surf
          File :grass/branches/develbranch_6/visualization/nviz/src/misc.c
          Function
Nget_cancel_cmd(Begins at: 13, Ends at:25)
Nlibinit_cmd(Begins at: 3, Ends at:11)
LOC:          |       9 |       |           OK |         9 |
Nset_SDscale_cmd(Begins at: 63, Ends at:84)
Nset_SDsurf_cmd(Begins at: 27, Ends at:46)
Nunset_SDsurf_cmd(Begins at: 48, Ends at:61)
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/misc.c clones of Nget_cancel_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/draw.c  Nget_def_color_cmd
          File :grass/branches/develbranch_6/visualization/nviz/src/nviz_init.c
          Function
Ngetargs(Begins at: 373, Ends at:421)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      26 |       |           OK |        26 |
LOC:          |      49 |       |           OK |        49 |
Ninit(Begins at: 506, Ends at:538)
Complexity:   |       1 |     * |      WARNING |         1 |
CalledNBR:    |       8 |    ** | BABY-MONSTER |         8 |
LOC:          |      33 |     * |      WARNING |        33 |
Ninitdata(Begins at: 542, Ends at:563)
metrics are OK
make_red_yellow_ramp(Begins at: 423, Ends at:434)
ParamNBR:     |       4 |       |           OK |         4 |
metrics are OK
parse_command(Begins at: 23, Ends at:363)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |      95 |   *** |      MONSTER |        95 |
LOC:          |     341 |   *** |      MONSTER |       341 |
set_default_wirecolors(Begins at: 473, Ends at:504)
metrics are OK
sort_surfs_mid(Begins at: 441, Ends at:471)
Clone analysis:
          File :grass/branches/develbranch_6/visualization/nviz/src/position.c
          Function
Nget_cat_at_xy_cmd(Begins at: 661, Ends at:694)
Nget_dist_along_surf_cmd(Begins at: 628, Ends at:655)
Nget_exag_cmd(Begins at: 843, Ends at:857)
Nget_focus_cmd(Begins at: 723, Ends at:749)
Nget_focus_gui_cmd(Begins at: 143, Ends at:184)
Nget_fov_cmd(Begins at: 447, Ends at:467)
Nget_from_cmd(Begins at: 44, Ends at:69)
Nget_longdim_cmd(Begins at: 752, Ends at:765)
Nget_point_on_surf_cmd(Begins at: 534, Ends at:576)
LOC:          |      43 |     * |      WARNING |        43 |
Nget_point_on_surf_vect(Begins at: 578, Ends at:626)
Nget_real_position_cmd(Begins at: 187, Ends at:229)
Nget_region_cmd(Begins at: 507, Ends at:532)
Nget_to_cmd(Begins at: 19, Ends at:42)
Nget_twist_cmd(Begins at: 486, Ends at:505)
Nget_val_at_xy_cmd(Begins at: 697, Ends at:721)
Nget_xyrange_cmd(Begins at: 799, Ends at:812)
Nget_zextents_cmd(Begins at: 814, Ends at:841)
Nget_zrange_cmd(Begins at: 767, Ends at:797)
Nhas_focus_cmd(Begins at: 83, Ends at:97)
Ninit_view_cmd(Begins at: 8, Ends at:15)
Nload_3dview_cmd(Begins at: 928, Ends at:963)
Nlook_here_cmd(Begins at: 71, Ends at:81)
Nmove_to_cmd(Begins at: 411, Ends at:428)
Nmove_to_real_cmd(Begins at: 391, Ends at:408)
Nsave_3dview_cmd(Begins at: 881, Ends at:917)
Nset_exag_cmd(Begins at: 859, Ends at:870)
Nset_focus_cmd(Begins at: 232, Ends at:248)
Nset_focus_gui_cmd(Begins at: 100, Ends at:139)
Nset_focus_map_cmd(Begins at: 339, Ends at:388)
Nset_focus_real_cmd(Begins at: 251, Ends at:267)
Nset_focus_state_cmd(Begins at: 269, Ends at:291)
Nset_focus_top_cmd(Begins at: 293, Ends at:336)
Nset_fov_cmd(Begins at: 431, Ends at:445)
Nset_twist_cmd(Begins at: 469, Ends at:484)
Clone analysis:
This file has 8 potentially cloned functions:
  Nget_fov_cmd  Nmove_to_real_cmd  Nmove_to_cmd  Nset_focus_real_cmd  Nset_focus_cmd  Nset_twist_cmd  Nset_fov_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nget_fov_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nget_twist_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nget_twist_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nget_fov_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nmove_to_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nmove_to_real_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nmove_to_real_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nmove_to_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nset_focus_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nset_focus_real_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nset_focus_real_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nset_focus_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nset_fov_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nset_twist_cmd
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c clones of Nset_twist_cmd are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/position.c  Nset_fov_cmd
          File :grass/branches/develbranch_6/visualization/nviz/src/togl_flythrough.c
          Class
cbData(Begins at: 91, Ends at:98)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
flyData(Begins at: 73, Ends at:89)
          Class
mouseData(Begins at: 65, Ends at:71)
Clone analysis:
          File :grass/branches/develbranch_6/visualization/nviz/src/volume.c
          Function
isosurf_add(Begins at: 127, Ends at:136)
isosurf_att_atoi(Begins at: 313, Ends at:329)
isosurf_del(Begins at: 139, Ends at:159)
isosurf_get_att(Begins at: 208, Ends at:245)
isosurf_get_drawmode(Begins at: 83, Ends at:111)
isosurf_get_flags(Begins at: 377, Ends at:397)
isosurf_get_mask_mode(Begins at: 332, Ends at:349)
isosurf_get_res(Begins at: 34, Ends at:55)
isosurf_move_down(Begins at: 185, Ends at:205)
isosurf_move_up(Begins at: 162, Ends at:182)
isosurf_num_isosurfs(Begins at: 114, Ends at:124)
isosurf_set_att(Begins at: 248, Ends at:290)
isosurf_set_drawmode(Begins at: 58, Ends at:80)
isosurf_set_flags(Begins at: 400, Ends at:416)
isosurf_set_mask_mode(Begins at: 352, Ends at:374)
isosurf_set_res(Begins at: 13, Ends at:31)
isosurf_unset_att(Begins at: 293, Ends at:310)
slice_add(Begins at: 621, Ends at:629)
slice_del(Begins at: 632, Ends at:650)
slice_get_drawmode(Begins at: 496, Ends at:524)
slice_get_pos(Begins at: 540, Ends at:584)
slice_get_res(Begins at: 440, Ends at:461)
slice_get_transp(Begins at: 699, Ends at:717)
slice_move_down(Begins at: 676, Ends at:696)
slice_move_up(Begins at: 653, Ends at:673)
slice_num_slices(Begins at: 527, Ends at:537)
slice_set_drawmode(Begins at: 464, Ends at:493)
slice_set_pos(Begins at: 587, Ends at:618)
slice_set_res(Begins at: 419, Ends at:437)
slice_set_transp(Begins at: 720, Ends at:738)
Clone analysis:
This file has 40 potentially cloned functions:
  isosurf_move_up  isosurf_move_down  slice_del  slice_move_up  slice_move_down  slice_get_transp  slice_get_res  isosurf_del  isosurf_move_up  slice_del  slice_move_up  slice_move_down  isosurf_del  isosurf_move_down  slice_del  slice_move_up  slice_move_down  slice_num_slices  slice_set_res  isosurf_add  isosurf_del  isosurf_move_up  isosurf_move_down  slice_move_up  slice_move_down  isosurf_get_res  isosurf_get_mask_mode  isosurf_del  isosurf_move_up  isosurf_move_down  slice_del  slice_move_up  isosurf_del  isosurf_move_up  isosurf_move_down  slice_del  slice_move_down  isosurf_num_isosurfs  isosurf_set_res
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_att_atoi are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/map_obj.c  att_atoi
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_del are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_move_up
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_move_down
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_del
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_move_up
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_move_down
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_get_mask_mode are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_get_transp
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_get_res are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_get_res
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_move_down are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_del
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_move_up are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_num_isosurfs are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_num_slices
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of isosurf_set_res are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  slice_set_res
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_add are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_add
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_del are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_get_res are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_get_res
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_get_transp are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_get_mask_mode
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_move_down are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_move_up are:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_num_slices are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_num_isosurfs
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c clones of slice_set_res are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/visualization/nviz/src/volume.c  isosurf_set_res
____________________________________________
Threshold grass key metrics values at Fri Feb 06 12:00:00 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
