[GRASS-QA] GRASS QA: neteler |form.c anim_support.c cutplane_obj.c
do_zoom.c ...| 96 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Feb 6 11:40:40 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/form/form.c
Function
Tcl_AppInit(Begins at: 267, Ends at:299)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 301, Ends at:308)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 8 | | OK | 8 |
metrics are OK
reset_values(Begins at: 30, Ends at:40)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
set_value(Begins at: 42, Ends at:71)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 30 | | OK | 30 |
at least 3 values are close to an outlier please consider revising code!
submit(Begins at: 74, Ends at:262)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 92 | *** | MONSTER | 92 |
LOC: | 189 | *** | MONSTER | 189 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file has 3 potentially cloned functions:
set_value submit
In /var/project-manager/grass/grassSVN/grass/trunk/lib/form/form.c clones of reset_values are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.digit/form.c reset_values
In /var/project-manager/grass/grassSVN/grass/trunk/lib/form/form.c clones of set_value are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.digit/form.c set_value
In /var/project-manager/grass/grassSVN/grass/trunk/lib/form/form.c clones of submit are:
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.digit/form.c submit
File :grass/trunk/visualization/nviz/src/anim_support.c
Function
Nadd_key_cmd(Begins at: 340, Ends at:418)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 79 | * | WARNING | 79 |
Conclusion: | this function is a BABY-MONSTER |
Nclear_keys_cmd(Begins at: 270, Ends at:288)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 19 | | OK | 19 |
Nclose_mpeg_cmd(Begins at: 889, Ends at:906)
LOC: | 18 | | OK | 18 |
Ndelete_key_cmd(Begins at: 439, Ends at:468)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
Ndo_framestep_cmd(Begins at: 539, Ends at:566)
Complexity: | 4 | | OK | 4 |
LOC: | 28 | | OK | 28 |
Ninit_mpeg_cmd(Begins at: 841, Ends at:862)
LOC: | 22 | | OK | 22 |
Nmove_key_cmd(Begins at: 488, Ends at:521)
LOC: | 34 | | OK | 34 |
Noff_screen_cmd(Begins at: 799, Ends at:835)
CalledNBR: | 4 | | OK | 4 |
LOC: | 37 | | OK | 37 |
Nprint_keys_cmd(Begins at: 607, Ends at:624)
Nset_interp_mode_cmd(Begins at: 32, Ends at:60)
LOC: | 29 | | OK | 29 |
Nset_numsteps_cmd(Begins at: 232, Ends at:254)
CalledNBR: | 2 | | OK | 2 |
LOC: | 23 | | OK | 23 |
Nset_tension_cmd(Begins at: 76, Ends at:103)
Nshow_lab_cmd(Begins at: 676, Ends at:699)
LOC: | 24 | | OK | 24 |
Nshow_path_cmd(Begins at: 702, Ends at:725)
Nshow_site_cmd(Begins at: 582, Ends at:605)
Nshow_vect_cmd(Begins at: 626, Ends at:649)
Nshow_vol_cmd(Begins at: 651, Ends at:674)
Nshowtension_start_cmd(Begins at: 123, Ends at:140)
Nshowtension_stop_cmd(Begins at: 161, Ends at:178)
Nupdate_frames_cmd(Begins at: 197, Ends at:215)
Nupdate_tension_cmd(Begins at: 142, Ends at:159)
Nwrite_mpeg_frame_cmd(Begins at: 867, Ends at:884)
Nwrite_ppm_cmd(Begins at: 741, Ends at:758)
Nwrite_tif_cmd(Begins at: 774, Ends at:796)
Clone analysis:
This file has 16 potentially cloned functions:
Nshow_vect_cmd Nshow_vol_cmd Nshow_path_cmd Nshow_vect_cmd Nshow_vol_cmd Nshow_lab_cmd Nshow_vol_cmd Nshow_lab_cmd Nshow_path_cmd Nshow_vect_cmd Nshow_lab_cmd Nshow_path_cmd Nupdate_tension_cmd Nshowtension_stop_cmd Nclose_mpeg_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nclose_mpeg_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nwrite_mpeg_frame_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nshow_lab_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nshow_vect_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nshow_vol_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nshow_path_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nshow_path_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nshow_lab_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nshow_vect_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nshow_vol_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nshowtension_stop_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nupdate_tension_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nupdate_tension_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nshowtension_stop_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c clones of Nwrite_mpeg_frame_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/anim_support.c Nclose_mpeg_cmd
File :grass/trunk/visualization/nviz/src/cutplane_obj.c
Function
Ncutplane_obj_cmd(Begins at: 130, Ends at:161)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 18 | | OK | 18 |
LOC: | 32 | * | WARNING | 32 |
Nget_current_cutplane_cmd(Begins at: 261, Ends at:277)
LOC: | 17 | | OK | 17 |
Nget_cutplane_list_cmd(Begins at: 284, Ends at:290)
LOC: | 7 | | OK | 7 |
Nget_fence_color_cmd(Begins at: 65, Ends at:104)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 40 | * | WARNING | 40 |
at least 2 values are close to an outlier please consider revising code!
Nnew_cutplane_obj_cmd(Begins at: 178, Ends at:212)
LOC: | 35 | * | WARNING | 35 |
Nnum_cutplane_obj_cmd(Begins at: 226, Ends at:236)
Nset_current_cutplane_cmd(Begins at: 240, Ends at:247)
ParamNBR: | 4 | | OK | 4 |
metrics are OK
Nset_fence_color_cmd(Begins at: 16, Ends at:51)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 36 | | OK | 36 |
cp_draw(Begins at: 306, Ends at:351)
Complexity: | 10 | | OK | 10 |
LOC: | 46 | | OK | 46 |
cp_get_rot(Begins at: 613, Ends at:632)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 20 | | OK | 20 |
cp_get_trans(Begins at: 640, Ends at:660)
Complexity: | 2 | * | WARNING | 2 |
LOC: | 21 | | OK | 21 |
cp_set_rot(Begins at: 504, Ends at:547)
CalledNBR: | 9 | | OK | 9 |
LOC: | 44 | | OK | 44 |
cp_set_trans(Begins at: 561, Ends at:605)
LOC: | 45 | | OK | 45 |
draw_cp_obj(Begins at: 365, Ends at:401)
CalledNBR: | 6 | | OK | 6 |
get_cp_idnum(Begins at: 675, Ends at:681)
Complexity: | 1 | * | WARNING | 1 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 1 | * | WARNING | 1 |
off_cp_obj(Begins at: 445, Ends at:459)
LOC: | 15 | | OK | 15 |
on_cp_obj(Begins at: 416, Ends at:431)
LOC: | 16 | | OK | 16 |
state_cp_obj(Begins at: 473, Ends at:490)
Clone analysis:
This file has 2 potentially cloned functions:
cp_get_rot
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/cutplane_obj.c clones of cp_get_rot are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/cutplane_obj.c cp_get_trans
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/cutplane_obj.c clones of cp_get_trans are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/cutplane_obj.c cp_get_rot
File :grass/trunk/visualization/nviz/src/do_zoom.c
Function
Create_OS_Ctx(Begins at: 369, Ends at:422)
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 54 | * | WARNING | 54 |
Destroy_OS_Ctx(Begins at: 428, Ends at:463)
Complexity: | 5 | * | WARNING | 5 |
LOC: | 36 | * | WARNING | 36 |
Error_Handler(Begins at: 360, Ends at:366)
LOC: | 7 | * | WARNING | 7 |
Nstart_zoom_cmd(Begins at: 46, Ends at:212)
Complexity: | 18 | | OK | 18 |
CalledNBR: | 49 | * | WARNING | 49 |
LOC: | 167 | | OK | 167 |
create_pbuffer(Begins at: 236, Ends at:307)
CalledNBR: | 17 | | OK | 17 |
LOC: | 72 | | OK | 72 |
metrics are OK
create_pixmap(Begins at: 309, Ends at:357)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 49 | | OK | 49 |
init_ctx(Begins at: 468, Ends at:501)
Complexity: | 2 | ** | BABY-MONSTER | 2 |
CalledNBR: | 12 | *** | MONSTER | 12 |
LOC: | 34 | *** | MONSTER | 34 |
swap_os(Begins at: 218, Ends at:230)
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/visualization/nviz/src/draw.c
Function
CancelFunc_Hook(Begins at: 33, Ends at:38)
LOC: | 6 | | OK | 6 |
metrics are OK
Nauto_draw_cmd(Begins at: 464, Ends at:473)
LOC: | 10 | | OK | 10 |
metrics are OK
Nclear_cmd(Begins at: 161, Ends at:172)
LOC: | 12 | | OK | 12 |
metrics are OK
Ndelete_list_cmd(Begins at: 810, Ends at:840)
Complexity: | 6 | | OK | 6 |
LOC: | 31 | | OK | 31 |
Ndone_draw_cmd(Begins at: 719, Ends at:723)
LOC: | 5 | | OK | 5 |
Ndraw_Narrow_cmd(Begins at: 256, Ends at:282)
Complexity: | 3 | * | WARNING | 3 |
LOC: | 27 | | OK | 27 |
Ndraw_ScaleBar_cmd(Begins at: 290, Ends at:315)
LOC: | 26 | | OK | 26 |
metrics are OK
Ndraw_X_cmd(Begins at: 191, Ends at:208)
Ndraw_fringe_cmd(Begins at: 844, Ends at:865)
CalledNBR: | 8 | * | WARNING | 8 |
LOC: | 22 | * | WARNING | 22 |
Ndraw_legend_cmd(Begins at: 763, Ends at:808)
Ndraw_line_on_surf_cmd(Begins at: 319, Ends at:339)
Ndraw_model_cmd(Begins at: 341, Ends at:348)
Ndraw_wire_cmd(Begins at: 174, Ends at:188)
Nget_def_color_cmd(Begins at: 149, Ends at:159)
Nhas_transparency_cmd(Begins at: 136, Ends at:147)
Nis_masked_cmd(Begins at: 115, Ends at:134)
Nready_draw_cmd(Begins at: 713, Ends at:717)
Nset_Narrow_cmd(Begins at: 215, Ends at:249)
LOC: | 35 | | OK | 35 |
Nset_cancel_cmd(Begins at: 601, Ends at:614)
LOC: | 14 | | OK | 14 |
metrics are OK
Nset_cancel_func_cmd(Begins at: 59, Ends at:79)
Nset_draw_cmd(Begins at: 81, Ends at:101)
Nset_viewport_cmd(Begins at: 872, Ends at:893)
Nsite_draw_all_cmd(Begins at: 649, Ends at:680)
CalledNBR: | 13 | | OK | 13 |
LOC: | 32 | | OK | 32 |
Nsite_draw_one_cmd(Begins at: 413, Ends at:434)
CalledNBR: | 10 | | OK | 10 |
Nsurf_draw_all_cmd(Begins at: 497, Ends at:506)
CalledNBR: | 3 | * | WARNING | 3 |
Nsurf_draw_one_cmd(Begins at: 350, Ends at:387)
LOC: | 38 | | OK | 38 |
Ntransp_is_set_cmd(Begins at: 103, Ends at:113)
Nunset_cancel_func_cmd(Begins at: 43, Ends at:54)
Nvect_draw_all_cmd(Begins at: 616, Ends at:647)
Nvect_draw_one_cmd(Begins at: 389, Ends at:411)
Nvol_draw_all_cmd(Begins at: 682, Ends at:711)
CalledNBR: | 10 | * | WARNING | 10 |
Nvol_draw_one_cmd(Begins at: 436, Ends at:458)
auto_draw(Begins at: 480, Ends at:494)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 4 | * | WARNING | 4 |
check_blank(Begins at: 731, Ends at:761)
sort_surfs_max(Begins at: 512, Ends at:540)
surf_draw_all(Begins at: 542, Ends at:598)
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 57 | * | WARNING | 57 |
Clone analysis:
This file has 7 potentially cloned functions:
Nvect_draw_one_cmd Nvol_draw_one_cmd Nsite_draw_one_cmd Nvol_draw_one_cmd Nvect_draw_one_cmd Nsite_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c clones of Nget_def_color_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/misc.c Nget_cancel_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c clones of Nsite_draw_one_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c Nvect_draw_one_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c Nvol_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c clones of Nvect_draw_one_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c Nsite_draw_one_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c clones of Nvol_draw_one_cmd are:
File :grass/trunk/visualization/nviz/src/exag.c
Function
Nget_first_exag_cmd(Begins at: 56, Ends at:83)
Nget_height_cmd(Begins at: 86, Ends at:135)
LOC: | 50 | | OK | 50 |
init_default_slider_vals1(Begins at: 15, Ends at:53)
LOC: | 39 | * | WARNING | 39 |
Clone analysis:
File :grass/trunk/visualization/nviz/src/lights.c
Function
Nlight_obj_cmd(Begins at: 16, Ends at:41)
Nlights_cmd(Begins at: 61, Ends at:73)
Nnew_light_cmd(Begins at: 43, Ends at:59)
get_light_num(Begins at: 259, Ends at:266)
getlgt_ambient(Begins at: 106, Ends at:126)
metrics are OK
getlgt_bright(Begins at: 93, Ends at:104)
metrics are OK
getlgt_color(Begins at: 128, Ends at:148)
getlgt_position(Begins at: 150, Ends at:172)
CalledNBR: | 6 | * | WARNING | 6 |
init_new_light(Begins at: 268, Ends at:283)
metrics are OK
setlgt_ambient(Begins at: 75, Ends at:91)
setlgt_bright(Begins at: 175, Ends at:196)
setlgt_color(Begins at: 198, Ends at:221)
setlgt_position(Begins at: 223, Ends at:243)
switchlight(Begins at: 245, Ends at:257)
metrics are OK
Clone analysis:
getlgt_ambient
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/lights.c clones of getlgt_ambient are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/lights.c getlgt_color
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/lights.c clones of getlgt_color are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/lights.c getlgt_ambient
File :grass/trunk/visualization/nviz/src/map_obj.c
Function
Nget_site_list_cmd(Begins at: 372, Ends at:390)
Nget_surf_list_cmd(Begins at: 322, Ends at:340)
Nget_vect_list_cmd(Begins at: 347, Ends at:365)
Nget_vol_list_cmd(Begins at: 397, Ends at:415)
Complexity: | 3 | *** | MONSTER | 3 |
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 4 | *** | MONSTER | 4 |
LOC: | 19 | *** | MONSTER | 19 |
Nliteral_from_logical_cmd(Begins at: 86, Ends at:189)
CalledNBR: | 32 | * | WARNING | 32 |
LOC: | 104 | * | WARNING | 104 |
Nlogical_from_literal_cmd(Begins at: 196, Ends at:209)
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 14 | * | WARNING | 14 |
at least 4 values are close to an outlier please consider revising code!
Nmap_obj_cmd(Begins at: 708, Ends at:772)
Complexity: | 28 | | OK | 28 |
CalledNBR: | 56 | | OK | 56 |
LOC: | 65 | | OK | 65 |
Nnew_map_obj_cmd(Begins at: 432, Ends at:698)
Complexity: | 39 | | OK | 39 |
CalledNBR: | 80 | | OK | 80 |
LOC: | 267 | | OK | 267 |
metrics are OK
att_atoi(Begins at: 2110, Ends at:2126)
delete_obj(Begins at: 951, Ends at:975)
LOC: | 25 | | OK | 25 |
draw_obj(Begins at: 920, Ends at:944)
ParamNBR: | 3 | * | WARNING | 3 |
get_att(Begins at: 1552, Ends at:1699)
Complexity: | 30 | | OK | 30 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 41 | | OK | 41 |
LOC: | 148 | | OK | 148 |
get_char_marker(Begins at: 2158, Ends at:2202)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 45 | * | WARNING | 45 |
get_drawmode(Begins at: 844, Ends at:912)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 69 | | OK | 69 |
get_exag_guess(Begins at: 1470, Ends at:1489)
ParamNBR: | 3 | | OK | 3 |
metrics are OK
get_idnum(Begins at: 2072, Ends at:2085)
get_int_marker(Begins at: 2208, Ends at:2248)
Complexity: | 11 | ** | BABY-MONSTER | 11 |
CalledNBR: | 11 | ** | BABY-MONSTER | 11 |
LOC: | 41 | * | WARNING | 41 |
get_logical_name(Begins at: 276, Ends at:315)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 40 | | OK | 40 |
get_mask_mode(Begins at: 2020, Ends at:2034)
get_nozero(Begins at: 1285, Ends at:1319)
ParamNBR: | 6 | * | WARNING | 6 |
get_res(Begins at: 983, Ends at:1035)
CalledNBR: | 11 | | OK | 11 |
LOC: | 53 | | OK | 53 |
get_trans(Begins at: 1162, Ends at:1200)
LOC: | 39 | | OK | 39 |
get_type(Begins at: 2092, Ends at:2104)
Complexity: | 5 | ** | BABY-MONSTER | 5 |
CalledNBR: | 4 | ** | BABY-MONSTER | 4 |
LOC: | 13 | ** | BABY-MONSTER | 13 |
get_wirecolor(Begins at: 1127, Ends at:1155)
isosurf(Begins at: 2255, Ends at:2299)
Complexity: | 18 | *** | MONSTER | 18 |
CalledNBR: | 34 | *** | MONSTER | 34 |
load_obj(Begins at: 1498, Ends at:1534)
Complexity: | 9 | *** | MONSTER | 9 |
CalledNBR: | 7 | *** | MONSTER | 7 |
LOC: | 37 | *** | MONSTER | 37 |
select_surf(Begins at: 1328, Ends at:1355)
set_att(Begins at: 1711, Ends at:1965)
Complexity: | 33 | *** | MONSTER | 33 |
CalledNBR: | 60 | *** | MONSTER | 60 |
LOC: | 255 | *** | MONSTER | 255 |
set_drawmode(Begins at: 780, Ends at:837)
Complexity: | 10 | * | WARNING | 10 |
LOC: | 58 | * | WARNING | 58 |
set_exag_obj(Begins at: 1440, Ends at:1463)
set_logical_name(Begins at: 216, Ends at:269)
set_mask_mode(Begins at: 2042, Ends at:2063)
set_nozero(Begins at: 1242, Ends at:1278)
set_res(Begins at: 1042, Ends at:1085)
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 44 | * | WARNING | 44 |
set_trans(Begins at: 1207, Ends at:1235)
set_wirecolor(Begins at: 1092, Ends at:1119)
slice(Begins at: 2306, Ends at:2345)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 28 | ** | BABY-MONSTER | 28 |
surf_is_selected(Begins at: 1400, Ends at:1432)
sv_att_atoi(Begins at: 2132, Ends at:2152)
unselect_surf(Begins at: 1364, Ends at:1392)
unset_att(Begins at: 1972, Ends at:2013)
LOC: | 42 | * | WARNING | 42 |
Clone analysis:
This file has 15 potentially cloned functions:
Nget_vect_list_cmd Nget_vol_list_cmd Nget_vect_list_cmd Nget_site_list_cmd Nget_vol_list_cmd Nget_surf_list_cmd Nget_site_list_cmd Nget_vol_list_cmd Nget_surf_list_cmd Nget_vect_list_cmd Nget_site_list_cmd isosurf_att_atoi unselect_surf select_surf
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_site_list_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_surf_list_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_vect_list_cmd
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_vol_list_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_surf_list_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c Nget_site_list_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_vect_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of Nget_vol_list_cmd are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of att_atoi are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_att_atoi
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of select_surf are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c unselect_surf
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c clones of unselect_surf are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c select_surf
File :grass/trunk/visualization/nviz/src/misc.c
Function
Nget_cancel_cmd(Begins at: 13, Ends at:25)
Nlibinit_cmd(Begins at: 3, Ends at:11)
LOC: | 9 | | OK | 9 |
Nset_SDscale_cmd(Begins at: 63, Ends at:84)
Nset_SDsurf_cmd(Begins at: 27, Ends at:46)
Nunset_SDsurf_cmd(Begins at: 48, Ends at:61)
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/misc.c clones of Nget_cancel_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/draw.c Nget_def_color_cmd
File :grass/trunk/visualization/nviz/src/nviz_init.c
Function
Ngetargs(Begins at: 372, Ends at:420)
CalledNBR: | 26 | | OK | 26 |
Ninit(Begins at: 505, Ends at:537)
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 33 | * | WARNING | 33 |
Ninitdata(Begins at: 541, Ends at:562)
metrics are OK
make_red_yellow_ramp(Begins at: 422, Ends at:433)
metrics are OK
parse_command(Begins at: 23, Ends at:362)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 95 | *** | MONSTER | 95 |
LOC: | 340 | *** | MONSTER | 340 |
set_default_wirecolors(Begins at: 472, Ends at:503)
metrics are OK
sort_surfs_mid(Begins at: 440, Ends at:470)
Clone analysis:
File :grass/trunk/visualization/nviz/src/position.c
Function
Nget_cat_at_xy_cmd(Begins at: 661, Ends at:694)
Nget_dist_along_surf_cmd(Begins at: 628, Ends at:655)
Nget_exag_cmd(Begins at: 843, Ends at:857)
Nget_focus_cmd(Begins at: 723, Ends at:749)
Nget_focus_gui_cmd(Begins at: 143, Ends at:184)
Nget_fov_cmd(Begins at: 447, Ends at:467)
Nget_from_cmd(Begins at: 44, Ends at:69)
Nget_longdim_cmd(Begins at: 752, Ends at:765)
Nget_point_on_surf_cmd(Begins at: 534, Ends at:576)
LOC: | 43 | * | WARNING | 43 |
Nget_point_on_surf_vect(Begins at: 578, Ends at:626)
LOC: | 49 | * | WARNING | 49 |
Nget_real_position_cmd(Begins at: 187, Ends at:229)
Nget_region_cmd(Begins at: 507, Ends at:532)
Nget_to_cmd(Begins at: 19, Ends at:42)
Nget_twist_cmd(Begins at: 486, Ends at:505)
Nget_val_at_xy_cmd(Begins at: 697, Ends at:721)
Nget_xyrange_cmd(Begins at: 799, Ends at:812)
Nget_zextents_cmd(Begins at: 814, Ends at:841)
Nget_zrange_cmd(Begins at: 767, Ends at:797)
Nhas_focus_cmd(Begins at: 83, Ends at:97)
Ninit_view_cmd(Begins at: 8, Ends at:15)
Nload_3dview_cmd(Begins at: 928, Ends at:963)
Nlook_here_cmd(Begins at: 71, Ends at:81)
Nmove_to_cmd(Begins at: 411, Ends at:428)
Nmove_to_real_cmd(Begins at: 391, Ends at:408)
Nsave_3dview_cmd(Begins at: 881, Ends at:917)
Nset_exag_cmd(Begins at: 859, Ends at:870)
Nset_focus_cmd(Begins at: 232, Ends at:248)
Nset_focus_gui_cmd(Begins at: 100, Ends at:139)
Nset_focus_map_cmd(Begins at: 339, Ends at:388)
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 50 | * | WARNING | 50 |
Nset_focus_real_cmd(Begins at: 251, Ends at:267)
Nset_focus_state_cmd(Begins at: 269, Ends at:291)
Nset_focus_top_cmd(Begins at: 293, Ends at:336)
Nset_fov_cmd(Begins at: 431, Ends at:445)
Nset_twist_cmd(Begins at: 469, Ends at:484)
Clone analysis:
This file has 8 potentially cloned functions:
Nget_fov_cmd Nmove_to_real_cmd Nmove_to_cmd Nset_focus_real_cmd Nset_focus_cmd Nset_twist_cmd Nset_fov_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nget_fov_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nget_twist_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nget_twist_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nget_fov_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nmove_to_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nmove_to_real_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nmove_to_real_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nmove_to_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nset_focus_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nset_focus_real_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nset_focus_real_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nset_focus_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nset_fov_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nset_twist_cmd
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c clones of Nset_twist_cmd are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/position.c Nset_fov_cmd
File :grass/trunk/visualization/nviz/src/togl_flythrough.c
Class
cbData(Begins at: 91, Ends at:98)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
flyData(Begins at: 73, Ends at:89)
Class
mouseData(Begins at: 65, Ends at:71)
Function
Ndraw_all_together_cmd(Begins at: 722, Ends at:877)
Complexity: | 17 | | OK | 17 |
CalledNBR: | 78 | | OK | 78 |
LOC: | 156 | | OK | 156 |
metrics are OK
Nget_fly_scale_cmd(Begins at: 181, Ends at:199)
CalledNBR: | 3 | ** | BABY-MONSTER | 3 |
LOC: | 19 | ** | BABY-MONSTER | 19 |
Nget_viewdir_cmd(Begins at: 901, Ends at:923)
Nset_fly_mode_cmd(Begins at: 145, Ends at:168)
metrics are OK
Nset_fly_scale_cmd(Begins at: 170, Ends at:179)
metrics are OK
Nset_viewdir_cmd(Begins at: 883, Ends at:898)
calc_mxmy(Begins at: 358, Ends at:385)
LOC: | 28 | * | WARNING | 28 |
do_navigation(Begins at: 479, Ends at:617)
CalledNBR: | 30 | *** | MONSTER | 30 |
LOC: | 139 | *** | MONSTER | 139 |
event_proc(Begins at: 324, Ends at:356)
Complexity: | 8 | | OK | 8 |
flythrough_postdraw_cb(Begins at: 110, Ends at:116)
ParamNBR: | 0 | * | WARNING | 0 |
flythrough_postdraw_cb_remove(Begins at: 129, Ends at:139)
flythrough_postdraw_cb_set(Begins at: 118, Ends at:127)
mouse_valuator(Begins at: 388, Ends at:475)
Complexity: | 15 | | OK | 15 |
LOC: | 88 | | OK | 88 |
site_draw_all_together(Begins at: 679, Ends at:697)
metrics are OK
surf_draw_all_together(Begins at: 622, Ends at:658)
metrics are OK
this_time(Begins at: 309, Ends at:322)
metrics are OK
togl_flythrough_init(Begins at: 205, Ends at:245)
LOC: | 41 | | OK | 41 |
metrics are OK
togl_flythrough_init_tcl(Begins at: 251, Ends at:281)
metrics are OK
togl_flythrough_timer_cb(Begins at: 286, Ends at:303)
metrics are OK
vect_draw_all_together(Begins at: 660, Ends at:677)
metrics are OK
vol_draw_all_cmd(Begins at: 699, Ends at:720)
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/togl_flythrough.c clones of site_draw_all_together are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/togl_flythrough.c vect_draw_all_together
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/togl_flythrough.c clones of vect_draw_all_together are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/togl_flythrough.c site_draw_all_together
File :grass/trunk/visualization/nviz/src/volume.c
Function
isosurf_add(Begins at: 127, Ends at:136)
isosurf_att_atoi(Begins at: 313, Ends at:329)
isosurf_del(Begins at: 139, Ends at:159)
isosurf_get_att(Begins at: 208, Ends at:245)
isosurf_get_drawmode(Begins at: 83, Ends at:111)
isosurf_get_flags(Begins at: 377, Ends at:397)
isosurf_get_mask_mode(Begins at: 332, Ends at:349)
isosurf_get_res(Begins at: 34, Ends at:55)
isosurf_move_down(Begins at: 185, Ends at:205)
isosurf_move_up(Begins at: 162, Ends at:182)
isosurf_num_isosurfs(Begins at: 114, Ends at:124)
isosurf_set_att(Begins at: 248, Ends at:290)
isosurf_set_drawmode(Begins at: 58, Ends at:80)
isosurf_set_flags(Begins at: 400, Ends at:416)
isosurf_set_mask_mode(Begins at: 352, Ends at:374)
isosurf_set_res(Begins at: 13, Ends at:31)
isosurf_unset_att(Begins at: 293, Ends at:310)
slice_add(Begins at: 621, Ends at:629)
slice_del(Begins at: 632, Ends at:650)
slice_get_drawmode(Begins at: 496, Ends at:524)
slice_get_pos(Begins at: 540, Ends at:584)
slice_get_res(Begins at: 440, Ends at:461)
slice_get_transp(Begins at: 699, Ends at:717)
slice_move_down(Begins at: 676, Ends at:696)
slice_move_up(Begins at: 653, Ends at:673)
slice_num_slices(Begins at: 527, Ends at:537)
slice_set_drawmode(Begins at: 464, Ends at:493)
slice_set_pos(Begins at: 587, Ends at:618)
slice_set_res(Begins at: 419, Ends at:437)
slice_set_transp(Begins at: 720, Ends at:738)
Clone analysis:
This file has 40 potentially cloned functions:
isosurf_move_up isosurf_move_down slice_del slice_move_up slice_move_down slice_get_transp slice_get_res isosurf_del isosurf_move_up slice_del slice_move_up slice_move_down isosurf_del isosurf_move_down slice_del slice_move_up slice_move_down slice_num_slices slice_set_res isosurf_add isosurf_del isosurf_move_up isosurf_move_down slice_move_up slice_move_down isosurf_get_res isosurf_get_mask_mode isosurf_del isosurf_move_up isosurf_move_down slice_del slice_move_up isosurf_del isosurf_move_up isosurf_move_down slice_del slice_move_down isosurf_num_isosurfs isosurf_set_res
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_att_atoi are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/map_obj.c att_atoi
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_del are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_move_up
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_move_down
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_del
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_move_up
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_move_down
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_get_mask_mode are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_get_transp
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_get_res are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_get_res
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_move_down are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_del
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_move_up are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_num_isosurfs are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_num_slices
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of isosurf_set_res are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c slice_set_res
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_add are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_add
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_del are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_get_res are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_get_res
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_get_transp are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_get_mask_mode
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_move_down are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_move_up are:
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_num_slices are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_num_isosurfs
In /var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c clones of slice_set_res are:
/var/project-manager/grass/grassSVN/grass/trunk/visualization/nviz/src/volume.c isosurf_set_res
____________________________________________
Threshold grass key metrics values at Fri Feb 06 12:04:51 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
