[GRASS-QA] GRASS QA: martinl |init.cpp | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Feb 24 14:30:24 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/gui/wxpython/nviz/init.cpp
Class
Nviz(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 7 | 54 | 0 | 15 |
|OLD Metrics | 1 | 0 | 7 | 54 | 0 | 15 |
Method
InitView(Begins at: 91, Ends at:113)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a OK |
metrics are OK
Nviz(Begins at: 35, Ends at:56)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 22 | | OK | 22 |
metrics are OK
Reset(Begins at: 122, Ends at:131)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 10 | | OK | 10 |
metrics are OK
SetBgColor(Begins at: 143, Ends at:148)
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
SetDisplay(Begins at: 81, Ends at:89)
LOC: | 9 | | OK | 9 |
metrics are OK
~Nviz(Begins at: 61, Ends at:73)
LOC: | 13 | | OK | 13 |
metrics are OK
Function
print_error(Begins at: 150, Ends at:160)
ParamNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
metrics are OK
print_percent(Begins at: 221, Ends at:229)
metrics are OK
print_sentence(Begins at: 167, Ends at:219)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 53 | * | WARNING | 53 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
swap_gl(Begins at: 133, Ends at:136)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Feb 24 14:34:03 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
