[GRASS-QA] GRASS QA: mmetz |heap.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Feb 27 09:34:40 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/dglib/heap.c
Function
dglHeapExtractMax(Begins at: 138, Ends at:168)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a OK |
metrics are OK
dglHeapExtractMin(Begins at: 79, Ends at:109)
metrics are OK
dglHeapFree(Begins at: 37, Ends at:50)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 14 | | OK | 14 |
metrics are OK
dglHeapInit(Begins at: 29, Ends at:35)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
dglHeapInsertMax(Begins at: 111, Ends at:136)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 26 | | OK | 26 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
dglHeapInsertMin(Begins at: 52, Ends at:77)
Clone analysis:
This file has 2 potentially cloned functions:
dglHeapInsertMax
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c clones of dglHeapInsertMax are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c dglHeapInsertMin
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c clones of dglHeapInsertMin are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/dglib/heap.c dglHeapInsertMax
____________________________________________
Threshold grass key metrics values at Fri Feb 27 09:38:55 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
