[GRASS-QA] GRASS QA: neteler |analyze.c main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Feb 27 09:36:48 EST 2009
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/imagery/i.points.auto/analyze.c
          Class
box(Begins at: 9, Ends at:12)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
analyze(Begins at: 61, Ends at:434)
              |          New Metrics           |Old Metrics|
Complexity:   |      33 |   *** |      MONSTER |        33 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      94 |   *** |      MONSTER |        94 |
LOC:          |     374 |   *** |      MONSTER |       374 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
askfile(Begins at: 738, Ends at:759)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
cancel_which(Begins at: 562, Ends at:574)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
compute_transformation(Begins at: 597, Ends at:708)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
LOC:          |     112 |    ** | BABY-MONSTER |       112 |
Conclusion:   | this function is a  BABY-MONSTER           |
do_report(Begins at: 773, Ends at:817)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      45 |     * |      WARNING |        45 |
 at least 3 values are close to an outlier please consider revising code!
done(Begins at: 556, Ends at:560)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
dotext(Begins at: 581, Ends at:595)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      15 |       |           OK |        15 |
downarrow(Begins at: 445, Ends at:451)
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
inbox(Begins at: 576, Ends at:579)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
new_control_line(Begins at: 913, Ends at:935)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      23 |       |           OK |        23 |
pick(Begins at: 453, Ends at:554)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |     102 |    ** | BABY-MONSTER |       102 |
points_to_line(Begins at: 903, Ends at:911)
LOC:          |       9 |       |           OK |         9 |
printcentered(Begins at: 819, Ends at:836)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      18 |       |           OK |        18 |
show_point(Begins at: 838, Ends at:900)
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |      63 |     * |      WARNING |        63 |
to_file(Begins at: 710, Ends at:736)
LOC:          |      27 |       |           OK |        27 |
to_printer(Begins at: 761, Ends at:771)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
uparrow(Begins at: 437, Ends at:443)
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass-addons/imagery/i.points.auto/main.c
          Function
error(Begins at: 180, Ends at:203)
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      24 |       |           OK |        24 |
main(Begins at: 34, Ends at:155)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      63 |   *** |      MONSTER |        63 |
LOC:          |     122 |    ** | BABY-MONSTER |       122 |
quit(Begins at: 157, Ends at:178)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Feb 27 09:41:03 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
