[GRASS-QA] GRASS QA: mmetz |net.c | 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Feb 27 09:39:04 EST 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/net.c
          Function
Vect_net_build_graph(Begins at: 90, Ends at:442)
              |          New Metrics           |Old Metrics|
Complexity:   |      51 |       |           OK |        51 |
ParamNBR:     |       9 |     * |      WARNING |         9 |
CalledNBR:    |     126 |     * |      WARNING |       126 |
LOC:          |     353 |       |           OK |       353 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Vect_net_get_line_cost(Begins at: 551, Ends at:594)
Complexity:   |       5 |   *** |      MONSTER |         5 |
ParamNBR:     |       4 |   *** |      MONSTER |         4 |
CalledNBR:    |       4 |   *** |      MONSTER |         4 |
LOC:          |      44 |   *** |      MONSTER |        44 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_net_get_node_cost(Begins at: 605, Ends at:614)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      10 |     * |      WARNING |        10 |
Vect_net_nearest_nodes(Begins at: 634, Ends at:832)
Complexity:   |      45 |       |           OK |        45 |
ParamNBR:     |      14 |     * |      WARNING |        14 |
CalledNBR:    |      39 |       |           OK |        39 |
LOC:          |     199 |       |           OK |       199 |
 at least 1 values are close to an outlier please consider revising code!
Vect_net_shortest_path(Begins at: 463, Ends at:537)
Complexity:   |      13 |   *** |      MONSTER |        13 |
ParamNBR:     |       5 |   *** |      MONSTER |         5 |
CalledNBR:    |      12 |   *** |      MONSTER |        12 |
LOC:          |      75 |   *** |      MONSTER |        75 |
Vect_net_shortest_path_coor(Begins at: 852, Ends at:1055)
Complexity:   |      34 |    ** | BABY-MONSTER |        34 |
ParamNBR:     |      16 |     * |      WARNING |        16 |
CalledNBR:    |      47 |     * |      WARNING |        47 |
LOC:          |     204 |     * |      WARNING |       204 |
Conclusion:   | this function is a  BABY-MONSTER           |
clipper(Begins at: 30, Ends at:65)
Complexity:   |       4 |   *** |      MONSTER |         4 |
LOC:          |      36 |   *** |      MONSTER |        36 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/net.c clones of clipper are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/graph.c  clipper
____________________________________________
Threshold grass key metrics values at Fri Feb 27 09:43:19 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
