[GRASS-QA] GRASS QA: mmetz |card.c card.h gammavol.c index.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jul 13 08:32:02 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/rtree/card.c
          Function
RTreeGetLeafMax(Begins at: 44, Ends at:47)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
RTreeGetNodeMax(Begins at: 40, Ends at:43)
metrics are OK
RTreeSetLeafMax(Begins at: 36, Ends at:39)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
RTreeSetNodeMax(Begins at: 32, Ends at:35)
metrics are OK
set_max(Begins at: 24, Ends at:30)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/rtree/card.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/vector/rtree/gammavol.c
          Function
main(Begins at: 36, Ends at:48)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
sphere_volume(Begins at: 27, Ends at:34)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/index.c
          Function
RTreeDeleteRect(Begins at: 262, Ends at:311)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      50 |     * |      WARNING |        50 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
RTreeDeleteRect2(Begins at: 210, Ends at:254)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      45 |     * |      WARNING |        45 |
 at least 3 values are close to an outlier please consider revising code!
RTreeFreeListNode(Begins at: 184, Ends at:188)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
RTreeInsertRect(Begins at: 138, Ends at:172)
LOC:          |      35 |       |           OK |        35 |
 at least 1 values are close to an outlier please consider revising code!
RTreeInsertRect2(Begins at: 81, Ends at:128)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      48 |     * |      WARNING |        48 |
RTreeNewIndex(Begins at: 25, Ends at:32)
metrics are OK
RTreeNewListNode(Begins at: 178, Ends at:182)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
RTreeReInsert(Begins at: 194, Ends at:202)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
RTreeSearch(Begins at: 39, Ends at:70)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      32 |       |           OK |        32 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/lib/vector/rtree/index.h
          Class
Branch(Begins at: 47, Ends at:51)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
ListNode(Begins at: 63, Ends at:67)
          Class
Node(Begins at: 56, Ends at:61)
          Class
Rect(Begins at: 40, Ends at:43)
Clone analysis:
          File :grass/trunk/lib/vector/rtree/node.c
          Function
RTreeAddBranch(Begins at: 179, Ends at:204)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      26 |       |           OK |        26 |
RTreeDestroyNode(Begins at: 217, Ends at:231)
LOC:          |      15 |       |           OK |        15 |
metrics are OK
RTreeDisconnectBranch(Begins at: 207, Ends at:214)
CalledNBR:    |       4 |       |           OK |         4 |
metrics are OK
RTreeFreeNode(Begins at: 55, Ends at:60)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
RTreeInitBranch(Begins at: 25, Ends at:29)
metrics are OK
RTreeInitNode(Begins at: 32, Ends at:41)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
RTreeNewNode(Begins at: 44, Ends at:53)
metrics are OK
RTreeNodeCover(Begins at: 111, Ends at:130)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
RTreePickBranch(Begins at: 139, Ends at:171)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
RTreePrintBranch(Begins at: 62, Ends at:66)
metrics are OK
RTreePrintNode(Begins at: 77, Ends at:105)
LOC:          |      29 |       |           OK |        29 |
RTreeTabIn(Begins at: 68, Ends at:74)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/rect.c
          Function
RTreeCombineRect(Begins at: 305, Ends at:325)
LOC:          |      21 |       |           OK |        21 |
metrics are OK
RTreeContained(Begins at: 352, Ends at:374)
LOC:          |      23 |       |           OK |        23 |
metrics are OK
RTreeInitRect(Begins at: 38, Ends at:45)
metrics are OK
RTreeNullRect(Begins at: 52, Ends at:62)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
RTreeOverlap(Begins at: 331, Ends at:346)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
RTreePrintRect(Begins at: 130, Ends at:143)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
RTreeRectSphericalVolume(Begins at: 253, Ends at:269)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
RTreeRectSurfaceArea(Begins at: 275, Ends at:298)
LOC:          |      24 |       |           OK |        24 |
metrics are OK
RTreeRectVolume(Begins at: 148, Ends at:162)
metrics are OK
sphere_volume(Begins at: 178, Ends at:185)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/rtree/rtree.h
          File :grass/trunk/lib/vector/rtree/split.c
          File :grass/trunk/lib/vector/rtree/split.h
          File :grass/trunk/lib/vector/rtree/split_q.c
          Function
RTreeClassify(Begins at: 61, Ends at:76)
RTreeGetBranches(Begins at: 30, Ends at:53)
RTreeInitPVars(Begins at: 142, Ends at:157)
RTreeLoadNodes(Begins at: 118, Ends at:134)
RTreeMethodZero(Begins at: 216, Ends at:278)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      63 |     * |      WARNING |        63 |
RTreePickSeeds(Begins at: 85, Ends at:110)
metrics are OK
RTreePrintPVars(Begins at: 165, Ends at:200)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      36 |       |           OK |        36 |
RTreeSplitNode(Begins at: 287, Ends at:312)
Clone analysis:
          File :grass/trunk/lib/vector/rtree/split_q.h
          File :grass/trunk/lib/vector/rtree/docs/test.c
____________________________________________
Threshold grass key metrics values at Mon Jul 13 08:14:47 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
