[GRASS-QA] GRASS QA: mmetz |plus.c spindex.c spindex_rw.c | 32 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jul 13 08:39:11 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/plus.c
          Function
dig_free_plus(Begins at: 241, Ends at:250)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
dig_free_plus_areas(Begins at: 173, Ends at:200)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
dig_free_plus_isles(Begins at: 207, Ends at:232)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
dig_free_plus_lines(Begins at: 137, Ends at:166)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
dig_free_plus_nodes(Begins at: 105, Ends at:130)
metrics are OK
dig_init_plus(Begins at: 31, Ends at:98)
LOC:          |      68 |     * |      WARNING |        68 |
dig_load_plus(Begins at: 262, Ends at:327)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
dig_write_areas(Begins at: 437, Ends at:451)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
dig_write_isles(Begins at: 462, Ends at:476)
metrics are OK
dig_write_lines(Begins at: 412, Ends at:426)
metrics are OK
dig_write_nodes(Begins at: 388, Ends at:401)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
dig_write_plus_file(Begins at: 338, Ends at:377)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      40 |       |           OK |        40 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file has 12 potentially cloned functions:
  dig_write_lines  dig_write_isles  dig_write_nodes  dig_write_lines  dig_write_areas  dig_write_nodes  dig_write_areas  dig_write_isles  dig_write_lines  dig_write_areas  dig_write_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_areas are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c  dig_write_nodes
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c  dig_write_lines
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c  dig_write_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_isles are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c  dig_write_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_lines are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus.c clones of dig_write_nodes are:
          File :grass/trunk/lib/vector/diglib/spindex.c
          Function
_add_item(Begins at: 368, Ends at:372)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
_add_node(Begins at: 405, Ends at:409)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
dig_find_node(Begins at: 420, Ends at:441)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      22 |       |           OK |        22 |
dig_select_areas(Begins at: 481, Ends at:499)
LOC:          |      19 |       |           OK |        19 |
dig_select_isles(Begins at: 510, Ends at:528)
dig_select_lines(Begins at: 452, Ends at:470)
dig_select_nodes(Begins at: 384, Ends at:402)
dig_spidx_add_area(Begins at: 174, Ends at:189)
LOC:          |      16 |       |           OK |        16 |
dig_spidx_add_isle(Begins at: 201, Ends at:216)
dig_spidx_add_line(Begins at: 148, Ends at:163)
dig_spidx_add_node(Begins at: 119, Ends at:137)
ParamNBR:     |       5 |     * |      WARNING |         5 |
dig_spidx_del_area(Begins at: 303, Ends at:330)
metrics are OK
dig_spidx_del_isle(Begins at: 342, Ends at:365)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
dig_spidx_del_line(Begins at: 263, Ends at:291)
LOC:          |      29 |       |           OK |        29 |
metrics are OK
dig_spidx_del_node(Begins at: 228, Ends at:251)
metrics are OK
dig_spidx_free(Begins at: 101, Ends at:107)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
dig_spidx_free_areas(Begins at: 79, Ends at:83)
metrics are OK
dig_spidx_free_isles(Begins at: 90, Ends at:94)
metrics are OK
dig_spidx_free_lines(Begins at: 68, Ends at:72)
metrics are OK
dig_spidx_free_nodes(Begins at: 57, Ends at:61)
metrics are OK
dig_spidx_init(Begins at: 31, Ends at:50)
LOC:          |      20 |       |           OK |        20 |
metrics are OK
Clone analysis:
This file has 20 potentially cloned functions:
  dig_select_lines  dig_select_isles  dig_select_nodes  dig_select_lines  dig_select_areas  dig_select_nodes  dig_select_areas  dig_select_isles  dig_select_lines  dig_select_areas  dig_select_isles  dig_spidx_add_line  dig_spidx_add_isle  dig_spidx_add_line  dig_spidx_add_area  dig_spidx_add_area  dig_spidx_add_isle  dig_spidx_del_node  dig_spidx_del_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_areas are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_select_nodes
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_select_lines
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_select_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_isles are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_select_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_lines are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_select_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_area are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_spidx_add_line
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_spidx_add_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_isle are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_spidx_add_area
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_add_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_isle are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_spidx_del_node
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c clones of dig_spidx_del_node are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/spindex.c  dig_spidx_del_isle
          File :grass/trunk/lib/vector/diglib/spindex_rw.c
          Function
dig_Rd_spindx_head(Begins at: 79, Ends at:162)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
LOC:          |      84 |     * |      WARNING |        84 |
dig_Wr_spindx_head(Begins at: 23, Ends at:76)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      54 |     * |      WARNING |        54 |
 at least 3 values are close to an outlier please consider revising code!
dig_dump_spidx(Begins at: 383, Ends at:399)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      17 |       |           OK |        17 |
metrics are OK
dig_read_spidx(Begins at: 356, Ends at:380)
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      25 |       |           OK |        25 |
dig_write_spidx(Begins at: 330, Ends at:353)
rtree_dump_branch(Begins at: 167, Ends at:183)
rtree_dump_node(Begins at: 186, Ends at:205)
rtree_read_branch(Begins at: 268, Ends at:302)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      35 |       |           OK |        35 |
rtree_read_node(Begins at: 305, Ends at:327)
LOC:          |      23 |       |           OK |        23 |
rtree_write_branch(Begins at: 210, Ends at:237)
rtree_write_node(Begins at: 240, Ends at:263)
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Jul 13 08:21:56 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
