[GRASS-QA] GRASS QA: mmetz |build.c build_nat.c close.c intersect.c
	...| 1 clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Mon Jul 13 08:46:27 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/build.c
          Function
Vect_build(Begins at: 73, Ends at:76)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity:   |      20 |       |           OK |        20 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      46 |       |           OK |        46 |
LOC:          |     121 |       |           OK |       121 |
metrics are OK
Vect_get_built(Begins at: 86, Ends at:89)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity:   |       3 |    ** | BABY-MONSTER |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |      14 |   *** |      MONSTER |        14 |
LOC:          |      33 |    ** | BABY-MONSTER |        33 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Vect_save_topo(Begins at: 257, Ends at:289)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |     * |      WARNING |         3 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_topo_dump(Begins at: 300, Ends at:398)
Complexity:   |      13 |       |           OK |        13 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      99 |       |           OK |        99 |
format(Begins at: 29, Ends at:33)
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
Complexity:   |       2 |    ** | BABY-MONSTER |         2 |
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |      15 |    ** | BABY-MONSTER |        15 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/build_nat.c
          Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      82 |     * |      WARNING |        82 |
 at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      28 |       |           OK |        28 |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      79 |     * |      WARNING |        79 |
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity:   |      42 |   *** |      MONSTER |        42 |
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     123 |    ** | BABY-MONSTER |       123 |
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/close.c
          Function
Vect_close(Begins at: 64, Ends at:148)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      33 |    ** | BABY-MONSTER |        33 |
LOC:          |      85 |     * |      WARNING |        85 |
clo_dummy(Begins at: 30, Ends at:33)
metrics are OK
format(Begins at: 36, Ends at:40)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/intersect.c
          Function
Vect_line_check_intersection(Begins at: 1110, Ends at:1248)
Complexity:   |      18 |       |           OK |        18 |
ParamNBR:     |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |     139 |       |           OK |       139 |
Vect_line_intersection(Begins at: 600, Ends at:1066)
Complexity:   |      44 |       |           OK |        44 |
ParamNBR:     |       7 |       |           OK |         7 |
CalledNBR:    |      48 |       |           OK |        48 |
LOC:          |     467 |       |           OK |       467 |
metrics are OK
Vect_segment_intersection(Begins at: 109, Ends at:456)
Complexity:   |      41 |       |           OK |        41 |
ParamNBR:     |      19 |       |           OK |        19 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |     348 |       |           OK |       348 |
metrics are OK
add_cross(Begins at: 474, Ends at:498)
ParamNBR:     |       6 |     * |      WARNING |         6 |
cmp_cross(Begins at: 500, Ends at:515)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
cross_seg(Begins at: 545, Ends at:580)
Complexity:   |       4 |    ** | BABY-MONSTER |         4 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      36 |    ** | BABY-MONSTER |        36 |
dist2(Begins at: 517, Ends at:524)
Complexity:   |       1 |   *** |      MONSTER |         1 |
ParamNBR:     |       4 |    ** | BABY-MONSTER |         4 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       8 |   *** |      MONSTER |         8 |
find_cross(Begins at: 1073, Ends at:1096)
Complexity:   |       2 |   *** |      MONSTER |         2 |
ParamNBR:     |       2 |   *** |      MONSTER |         2 |
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
LOC:          |      24 |   *** |      MONSTER |        24 |
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 124, Ends at:396)
Complexity:   |      31 |       |           OK |        31 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |     102 |       |           OK |       102 |
LOC:          |     273 |       |           OK |       273 |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity:   |       6 |   *** |      MONSTER |         6 |
CalledNBR:    |      11 |   *** |      MONSTER |        11 |
LOC:          |      39 |   *** |      MONSTER |        39 |
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity:   |       5 |     * |      WARNING |         5 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      18 |       |           OK |        18 |
Vect_open_new(Begins at: 514, Ends at:597)
Complexity:   |       8 |       |           OK |         8 |
LOC:          |      84 |       |           OK |        84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
Complexity:   |       1 |     * |      WARNING |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
Vect_open_old_head(Begins at: 464, Ends at:468)
Vect_open_spatial_index(Begins at: 767, Ends at:832)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      66 |       |           OK |        66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      72 |     * |      WARNING |        72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity:   |       2 |     * |      WARNING |         2 |
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      23 |     * |      WARNING |        23 |
 at least 3 values are close to an outlier please consider revising code!
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC:          |      21 |       |           OK |        21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
fatal_error(Begins at: 59, Ends at:71)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
format(Begins at: 38, Ends at:42)
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/select.c
          Function
Vect_select_areas_by_box(Begins at: 91, Ends at:115)
Vect_select_areas_by_polygon(Begins at: 293, Ends at:351)
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      59 |     * |      WARNING |        59 |
 at least 4 values are close to an outlier please consider revising code!
Vect_select_isles_by_box(Begins at: 130, Ends at:147)
Vect_select_lines_by_box(Begins at: 37, Ends at:77)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      41 |       |           OK |        41 |
Vect_select_lines_by_polygon(Begins at: 197, Ends at:274)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      78 |     * |      WARNING |        78 |
Vect_select_nodes_by_box(Begins at: 158, Ends at:181)
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/sindex.c
          Function
Vect_build_sidx_from_topo(Begins at: 145, Ends at:236)
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      92 |    ** | BABY-MONSTER |        92 |
Vect_build_spatial_index(Begins at: 124, Ends at:134)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Vect_spatial_index_add_item(Begins at: 66, Ends at:79)
LOC:          |      14 |       |           OK |        14 |
Vect_spatial_index_del_item(Begins at: 89, Ends at:110)
LOC:          |      22 |       |           OK |        22 |
metrics are OK
Vect_spatial_index_destroy(Begins at: 50, Ends at:55)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Vect_spatial_index_init(Begins at: 34, Ends at:39)
metrics are OK
Vect_spatial_index_select(Begins at: 255, Ends at:275)
_add_item(Begins at: 240, Ends at:244)
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/sindex.c clones of Vect_build_spatial_index are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_driver/d_mkdir.c  make_dir
____________________________________________
Threshold grass key metrics values at Mon Jul 13 08:29:12 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
