[GRASS-QA] GRASS QA: hamish |cell_stats.c global.h main.c stats.c |
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Jun 5 04:50:47 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.stats/cell_stats.c
Function
cell_stats(Begins at: 4, Ends at:67)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 64 | * | WARNING | 64 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.stats/global.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.stats/main.c
Function
main(Begins at: 42, Ends at:354)
Complexity: | 28 | *** | MONSTER | 28 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 106 | *** | MONSTER | 106 |
LOC: | 313 | *** | MONSTER | 313 |
Conclusion: | this function is a MONSTER |
Clone analysis:
File :grass/trunk/raster/r.stats/stats.c
Class
Node(Begins at: 19, Ends at:27)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
NewNode(Begins at: 65, Ends at:88)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
allocate_values(Begins at: 56, Ends at:63)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 8 | | OK | 8 |
metrics are OK
initialize_cell_stats(Begins at: 33, Ends at:54)
Complexity: | 2 | | OK | 2 |
LOC: | 22 | | OK | 22 |
metrics are OK
node_compare(Begins at: 157, Ends at:169)
CalledNBR: | 0 | | OK | 0 |
LOC: | 13 | | OK | 13 |
metrics are OK
print_cell_stats(Begins at: 195, Ends at:314)
Complexity: | 26 | *** | MONSTER | 26 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 120 | ** | BABY-MONSTER | 120 |
print_node_count(Begins at: 188, Ends at:193)
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
reset_null_vals(Begins at: 90, Ends at:98)
LOC: | 9 | | OK | 9 |
metrics are OK
sort_cell_stats(Begins at: 171, Ends at:186)
LOC: | 16 | | OK | 16 |
metrics are OK
update_cell_stats(Begins at: 100, Ends at:155)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 56 | * | WARNING | 56 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Jun 05 04:48:08 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
