[GRASS-QA] GRASS QA: glynn |dbdriver.h dbdriver.h dbdriver.h
dbdriver.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Jun 5 04:57:56 EDT 2009
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/db/drivers/dbf/dbdriver.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/db/drivers/mysql/dbdriver.h
File :grass/trunk/db/drivers/odbc/dbdriver.h
File :grass/trunk/db/drivers/ogr/dbdriver.h
File :grass/trunk/db/drivers/postgres/dbdriver.h
File :grass/trunk/db/drivers/sqlite/dbdriver.h
File :grass/trunk/lib/gis/fmode.c
____________________________________________
Threshold grass key metrics values at Fri Jun 05 04:55:17 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
