[GRASS-QA] GRASS QA: hamish |edgedetection.c edgedetection.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 12:51:59 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/edgedetection.c
          Function
Create_AuxEdge_Table(Begins at: 517, Ends at:552)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      36 |       |           OK |        36 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Create_Interpolation_Table(Begins at: 566, Ends at:594)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      29 |       |           OK |        29 |
Drop_Aux_Table(Begins at: 554, Ends at:563)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
Get_Gradient(Begins at: 146, Ends at:169)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      24 |       |           OK |        24 |
Insert(Begins at: 411, Ends at:427)
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      17 |       |           OK |        17 |
Insert_Interpolation(Begins at: 429, Ends at:443)
LOC:          |      15 |       |           OK |        15 |
Select(Begins at: 462, Ends at:514)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |      53 |     * |      WARNING |        53 |
 at least 4 values are close to an outlier please consider revising code!
UpDate(Begins at: 446, Ends at:460)
classification(Begins at: 171, Ends at:409)
Complexity:   |      25 |   *** |      MONSTER |        25 |
ParamNBR:     |      16 |   *** |      MONSTER |        16 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     239 |   *** |      MONSTER |       239 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
edge_detection(Begins at: 34, Ends at:144)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |     111 |    ** | BABY-MONSTER |       111 |
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/lidar/v.lidar.edgedetection/edgedetection.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold grass key metrics values at Tue Jun 30 12:39:51 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
