[GRASS-QA] GRASS QA: hamish |edgedetection.c edgedetection.h | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 12:54:47 EDT 2009
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
Function
Create_AuxEdge_Table(Begins at: 507, Ends at:542)
| New Metrics |Old Metrics|
Complexity: | 2 | *** | MONSTER | 2 |
ParamNBR: | 1 | *** | MONSTER | 1 |
CalledNBR: | 18 | *** | MONSTER | 18 |
LOC: | 36 | *** | MONSTER | 36 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Create_Interpolation_Table(Begins at: 556, Ends at:584)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 29 | | OK | 29 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Drop_Aux_Table(Begins at: 544, Ends at:553)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 10 | | OK | 10 |
Get_Gradient(Begins at: 146, Ends at:169)
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
Insert(Begins at: 401, Ends at:417)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 17 | | OK | 17 |
Insert_Interpolation(Begins at: 419, Ends at:433)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 15 | | OK | 15 |
Select(Begins at: 452, Ends at:504)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 22 | | OK | 22 |
LOC: | 53 | | OK | 53 |
UpDate(Begins at: 436, Ends at:450)
Complexity: | 1 | * | WARNING | 1 |
LOC: | 15 | * | WARNING | 15 |
at least 4 values are close to an outlier please consider revising code!
classification(Begins at: 171, Ends at:399)
Complexity: | 25 | | OK | 25 |
ParamNBR: | 16 | * | WARNING | 16 |
CalledNBR: | 58 | | OK | 58 |
LOC: | 229 | | OK | 229 |
edge_detection(Begins at: 34, Ends at:144)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 10 | *** | MONSTER | 10 |
CalledNBR: | 32 | ** | BABY-MONSTER | 32 |
LOC: | 111 | ** | BABY-MONSTER | 111 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
The system don't find class, method and function
in this file during analysis!
____________________________________________
Threshold grass key metrics values at Tue Jun 30 12:42:39 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
