[GRASS-QA] GRASS QA: martinl |main.cpp | 2 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Jun 30 15:49:46 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/imagery/i.atcorr/main.cpp
Class
IntPair(Begins at: 202, Ends at:216)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 5 | 2 | 0 | 1 |
|OLD Metrics | 1 | 0 | 5 | 2 | 0 | 1 |
Method
IntPair(Begins at: 207, Ends at:207)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 1 | | OK | 1 |
Conclusion: | this function is a OK |
metrics are OK
operator<(Begins at: 209, Ends at:215)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 7 | | OK | 7 |
metrics are OK
Class
Options(Begins at: 41, Ends at:60)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Position(Begins at: 171, Ends at:177)
|NEW Metrics | 1 | 0 | 2 | 2 | 0 | 1 |
|OLD Metrics | 1 | 0 | 2 | 2 | 0 | 1 |
Method
Position(Begins at: 175, Ends at:175)
metrics are OK
valid(Begins at: 176, Ends at:176)
ParamNBR: | 0 | | OK | 0 |
metrics are OK
Class
ScaleRange(Begins at: 62, Ends at:66)
Class
TICache(Begins at: 123, Ends at:153)
|NEW Metrics | 1 | 0 | 8 | 4 | 0 | 2 |
|OLD Metrics | 1 | 0 | 8 | 4 | 0 | 2 |
Method
TICache(Begins at: 134, Ends at:134)
Complexity: | 2 | | OK | 2 |
metrics are OK
add(Begins at: 147, Ends at:152)
LOC: | 6 | | OK | 6 |
metrics are OK
get(Begins at: 146, Ends at:146)
metrics are OK
search(Begins at: 135, Ends at:144)
Complexity: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
Class
TIMap(Begins at: 159, Ends at:199)
|NEW Metrics | 1 | 0 | 8 | 10 | 0 | 4 |
|OLD Metrics | 1 | 0 | 8 | 10 | 0 | 4 |
Method
TIMap(Begins at: 179, Ends at:179)
ParamNBR: | 0 | * | WARNING | 0 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
add(Begins at: 193, Ends at:198)
ParamNBR: | 3 | | OK | 2 |
CalledNBR: | 1 | | OK | 0 |
metrics are OK
get(Begins at: 191, Ends at:191)
metrics are OK
search(Begins at: 180, Ends at:189)
ParamNBR: | 2 | | OK | 1 |
CalledNBR: | 2 | | OK | 0 |
metrics are OK
Function
adjust_region(Begins at: 88, Ends at:97)
CalledNBR: | 4 | | OK | 4 |
metrics are OK
copy_colors(Begins at: 392, Ends at:398)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 3 | | OK | 3 |
define_module(Begins at: 402, Ends at:426)
LOC: | 25 | | OK | 25 |
metrics are OK
define_options(Begins at: 430, Ends at:499)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 70 | * | WARNING | 70 |
at least 2 values are close to an outlier please consider revising code!
main(Begins at: 533, Ends at:619)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
CalledNBR: | 35 | ** | BABY-MONSTER | 35 |
LOC: | 87 | * | WARNING | 87 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
optimize_va(Begins at: 222, Ends at:242)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 21 | | OK | 21 |
process_raster(Begins at: 259, Ends at:387)
Complexity: | 23 | *** | MONSTER | 23 |
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 42 | *** | MONSTER | 42 |
LOC: | 129 | ** | BABY-MONSTER | 129 |
Conclusion: | this function is a MONSTER |
read_scale(Begins at: 502, Ends at:530)
LOC: | 29 | | OK | 29 |
metrics are OK
round_c(Begins at: 101, Ends at:107)
metrics are OK
write_fp_to_cell(Begins at: 111, Ends at:120)
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
/tmp/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp
In /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of 135 are:
144 /tmp/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp
In /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of 180 are:
189 /tmp/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp
____________________________________________
Threshold grass key metrics values at Tue Jun 30 15:37:35 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
