[GRASS-QA] GRASS QA: martinl |main.c main.c main.c main.c ...| 78 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Jun 30 15:50:17 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/db/db.columns/main.c
          Function
main(Begins at: 33, Ends at:66)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      34 |       |           OK |        34 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
parse_command_line(Begins at: 69, Ends at:101)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      33 |       |           OK |        33 |
Clone analysis:
This file has 4 potentially cloned functions:
  main  parse_command_line  parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.columns/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/columns.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.columns/columns.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.columns/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/columns.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.columns/columns.c  parse_command_line
          File :grass/trunk/db/db.connect/main.c
          Function
main(Begins at: 30, Ends at:174)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
LOC:          |     145 |   *** |      MONSTER |       145 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 2 potentially cloned functions:
  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.connect/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/connect.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.connect/connect.c  main
          File :grass/trunk/db/db.copy/main.c
          Function
main(Begins at: 23, Ends at:129)
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     107 |    ** | BABY-MONSTER |       107 |
Clone analysis:
  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.copy/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/copy.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.copy/copy.c  main
          File :grass/trunk/db/db.createdb/main.c
          Function
main(Begins at: 33, Ends at:51)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a            OK           |
metrics are OK
parse_command_line(Begins at: 54, Ends at:79)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
This file has 10 potentially cloned functions:
  main  main  main  main  parse_command_line  parse_command_line  parse_command_line  parse_command_line  parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/createdb.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/dropdb.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/createdb.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/dropdb.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/main.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/createdb.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/dropdb.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/createdb.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/dropdb.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/main.c  parse_command_line
          File :grass/trunk/db/db.databases/main.c
          Function
main(Begins at: 34, Ends at:66)
CalledNBR:    |      14 |     * |      WARNING |        14 |
parse_command_line(Begins at: 69, Ends at:99)
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      31 |       |           OK |        31 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.databases/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/databases.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.databases/databases.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.databases/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/databases.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.databases/databases.c  parse_command_line
          File :grass/trunk/db/db.describe/main.c
          Function
main(Begins at: 38, Ends at:89)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |      52 |     * |      WARNING |        52 |
Conclusion:   | this function is a  BABY-MONSTER           |
parse_command_line(Begins at: 92, Ends at:135)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      44 |     * |      WARNING |        44 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.describe/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/describe.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.describe/describe.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.describe/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/describe.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.describe/describe.c  parse_command_line
          File :grass/trunk/db/db.drivers/main.c
          Function
main(Begins at: 33, Ends at:53)
LOC:          |      21 |       |           OK |        21 |
metrics are OK
parse_command_line(Begins at: 56, Ends at:81)
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.drivers/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/drivers.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.drivers/drivers.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.drivers/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/drivers.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.drivers/drivers.c  parse_command_line
          File :grass/trunk/db/db.dropdb/main.c
          Function
metrics are OK
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/main.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.dropdb/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.createdb/main.c  parse_command_line
          File :grass/trunk/db/db.droptable/main.c
          Function
main(Begins at: 33, Ends at:57)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      25 |       |           OK |        25 |
parse_command_line(Begins at: 60, Ends at:87)
LOC:          |      28 |       |           OK |        28 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.droptable/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/droptable.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.droptable/droptable.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.droptable/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/droptable.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.droptable/droptable.c  parse_command_line
          File :grass/trunk/db/db.execute/main.c
          Function
get_stmt(Begins at: 136, Ends at:163)
CalledNBR:    |       7 |       |           OK |         7 |
metrics are OK
main(Begins at: 37, Ends at:91)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      55 |     * |      WARNING |        55 |
parse_command_line(Begins at: 94, Ends at:133)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      40 |       |           OK |        40 |
stmt_is_empty(Begins at: 166, Ends at:171)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/execute.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.execute/execute.c  parse_command_line
          File :grass/trunk/db/db.login/main.c
          Function
main(Begins at: 29, Ends at:115)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      40 |   *** |      MONSTER |        40 |
LOC:          |      87 |     * |      WARNING |        87 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/db/db.select/main.c
          Function
get_stmt(Begins at: 269, Ends at:288)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
main(Begins at: 38, Ends at:91)
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |      54 |     * |      WARNING |        54 |
parse_command_line(Begins at: 165, Ends at:266)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      38 |   *** |      MONSTER |        38 |
LOC:          |     102 |    ** | BABY-MONSTER |       102 |
sel(Begins at: 94, Ends at:162)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
LOC:          |      69 |     * |      WARNING |        69 |
stmt_is_empty(Begins at: 291, Ends at:296)
metrics are OK
Clone analysis:
This file has 7 potentially cloned functions:
  get_stmt  main  main  parse_command_line  sel  sel
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/main.c clones of get_stmt are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/select.c  get_stmt
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/select.c  get_stmt
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/select.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/select.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/select.c  parse_command_line
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/main.c clones of sel are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/select.c  sel
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.select/select.c  sel
          File :grass/trunk/db/db.tables/main.c
          Function
main(Begins at: 34, Ends at:63)
LOC:          |      30 |       |           OK |        30 |
parse_command_line(Begins at: 66, Ends at:104)
LOC:          |      39 |       |           OK |        39 |
Clone analysis:
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.tables/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/tables.c  main
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.tables/tables.c  main
In /var/project-manager/grass/grassSVN/grass/trunk/db/db.tables/main.c clones of parse_command_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/db/base/tables.c  parse_command_line
          /var/project-manager/grass/grassSVN/grass/trunk/db/db.tables/tables.c  parse_command_line
          File :grass/trunk/display/d.barscale/main.c
          Function
main(Begins at: 42, Ends at:163)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |     122 |    ** | BABY-MONSTER |       122 |
Clone analysis:
          File :grass/trunk/display/d.colorlist/main.c
          Function
main(Begins at: 24, Ends at:62)
Clone analysis:
          File :grass/trunk/display/d.colors/main.c
          Function
main(Begins at: 26, Ends at:90)
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      65 |     * |      WARNING |        65 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/display/d.colortable/main.c
          Function
main(Begins at: 30, Ends at:270)
Complexity:   |      25 |   *** |      MONSTER |        25 |
CalledNBR:    |      70 |   *** |      MONSTER |        70 |
LOC:          |     241 |   *** |      MONSTER |       241 |
Clone analysis:
          File :grass/trunk/display/d.erase/main.c
          Function
main(Begins at: 21, Ends at:62)
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      42 |     * |      WARNING |        42 |
Clone analysis:
          File :grass/trunk/display/d.extract/main.c
          Function
main(Begins at: 32, Ends at:149)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      55 |   *** |      MONSTER |        55 |
LOC:          |     118 |    ** | BABY-MONSTER |       118 |
Clone analysis:
          File :grass/trunk/display/d.font/main.c
          Function
main(Begins at: 37, Ends at:137)
Complexity:   |      13 |       |           OK |        13 |
CalledNBR:    |      41 |       |           OK |        41 |
LOC:          |     101 |       |           OK |       101 |
metrics are OK
print_font_list(Begins at: 159, Ends at:168)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
read_freetype_fonts(Begins at: 139, Ends at:157)
Complexity:   |       4 |    ** | BABY-MONSTER |         4 |
CalledNBR:    |       4 |   *** |      MONSTER |         4 |
LOC:          |      19 |    ** | BABY-MONSTER |        19 |
Clone analysis:
          File :grass/trunk/display/d.fontlist/main.c
          Function
main(Begins at: 27, Ends at:66)
CalledNBR:    |      18 |     * |      WARNING |        18 |
Clone analysis:
          File :grass/trunk/display/d.geodesic/main.c
          Function
main(Begins at: 29, Ends at:124)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
LOC:          |      96 |    ** | BABY-MONSTER |        96 |
Clone analysis:
          File :grass/trunk/display/d.graph/main.c
          Function
main(Begins at: 47, Ends at:139)
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
LOC:          |      93 |    ** | BABY-MONSTER |        93 |
Clone analysis:
          File :grass/trunk/display/d.grid/main.c
          Function
main(Begins at: 33, Ends at:222)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
CalledNBR:    |      75 |   *** |      MONSTER |        75 |
LOC:          |     190 |   *** |      MONSTER |       190 |
Clone analysis:
          File :grass/trunk/display/d.his/main.c
          Function
main(Begins at: 31, Ends at:271)
Complexity:   |      27 |   *** |      MONSTER |        27 |
CalledNBR:    |      84 |   *** |      MONSTER |        84 |
Clone analysis:
          File :grass/trunk/display/d.histogram/main.c
          Function
main(Begins at: 59, Ends at:229)
CalledNBR:    |      64 |   *** |      MONSTER |        64 |
LOC:          |     171 |   *** |      MONSTER |       171 |
Clone analysis:
          File :grass/trunk/display/d.info/main.c
          Function
main(Begins at: 22, Ends at:127)
CalledNBR:    |      52 |   *** |      MONSTER |        52 |
LOC:          |     106 |    ** | BABY-MONSTER |       106 |
Clone analysis:
          File :grass/trunk/display/d.labels/main.c
          Function
main(Begins at: 27, Ends at:138)
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
LOC:          |     112 |    ** | BABY-MONSTER |       112 |
Clone analysis:
          File :grass/trunk/display/d.legend/main.c
          Function
main(Begins at: 38, Ends at:885)
Complexity:   |     130 |   *** |      MONSTER |       130 |
CalledNBR:    |     211 |   *** |      MONSTER |       211 |
LOC:          |     848 |   *** |      MONSTER |       848 |
Clone analysis:
          File :grass/trunk/display/d.linegraph/main.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/display/d.measure/main.c
          Function
main(Begins at: 30, Ends at:98)
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
Clone analysis:
          File :grass/trunk/display/d.nviz/main.c
          Function
do_profile(Begins at: 333, Ends at:405)
Complexity:   |      10 |       |           OK |        10 |
ParamNBR:     |       7 |       |           OK |         7 |
CalledNBR:    |      29 |       |           OK |        29 |
LOC:          |      73 |       |           OK |        73 |
metrics are OK
main(Begins at: 43, Ends at:326)
Complexity:   |      22 |   *** |      MONSTER |        22 |
CalledNBR:    |     125 |   *** |      MONSTER |       125 |
LOC:          |     284 |   *** |      MONSTER |       284 |
read_rast(Begins at: 413, Ends at:517)
Complexity:   |      15 |       |           OK |        15 |
ParamNBR:     |       6 |       |           OK |         6 |
CalledNBR:    |      24 |       |           OK |        24 |
LOC:          |     105 |       |           OK |       105 |
metrics are OK
Clone analysis:
          File :grass/trunk/display/d.path/main.c
          Function
main(Begins at: 31, Ends at:205)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
CalledNBR:    |      79 |   *** |      MONSTER |        79 |
LOC:          |     175 |   *** |      MONSTER |       175 |
Clone analysis:
          File :grass/trunk/display/d.profile/main.c
          Function
main(Begins at: 51, Ends at:425)
Complexity:   |      36 |   *** |      MONSTER |        36 |
CalledNBR:    |     176 |   *** |      MONSTER |       176 |
LOC:          |     375 |   *** |      MONSTER |       375 |
myDcell(Begins at: 427, Ends at:467)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      41 |       |           OK |        41 |
Clone analysis:
          File :grass/trunk/display/d.rast/main.c
          Function
main(Begins at: 35, Ends at:137)
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |     103 |       |           OK |       103 |
parse_catlist(Begins at: 139, Ends at:169)
CalledNBR:    |       9 |     * |      WARNING |         9 |
parse_d_mask_rule(Begins at: 234, Ends at:263)
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      11 |       |           OK |        11 |
parse_mask_rule(Begins at: 203, Ends at:232)
parse_vallist(Begins at: 171, Ends at:201)
CalledNBR:    |       9 |    ** | BABY-MONSTER |         9 |
LOC:          |      31 |    ** | BABY-MONSTER |        31 |
Clone analysis:
          File :grass/trunk/display/d.rast.arrow/main.c
          File :grass/trunk/display/d.rast.num/main.c
          File :grass/trunk/display/d.rgb/main.c
          Class
band(Begins at: 28, Ends at:35)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 39, Ends at:143)
LOC:          |     105 |    ** | BABY-MONSTER |       105 |
Clone analysis:
          File :grass/trunk/display/d.rhumbline/main.c
          Function
main(Begins at: 30, Ends at:127)
LOC:          |      98 |    ** | BABY-MONSTER |        98 |
Clone analysis:
          File :grass/trunk/display/d.text/main.c
          File :grass/trunk/display/d.thematic.area/main.c
          Function
main(Begins at: 33, Ends at:536)
Complexity:   |      51 |   *** |      MONSTER |        51 |
CalledNBR:    |     164 |   *** |      MONSTER |       164 |
LOC:          |     504 |   *** |      MONSTER |       504 |
Clone analysis:
          File :grass/trunk/display/d.title/main.c
          Function
main(Begins at: 34, Ends at:146)
CalledNBR:    |      48 |   *** |      MONSTER |        48 |
LOC:          |     113 |    ** | BABY-MONSTER |       113 |
Clone analysis:
          File :grass/trunk/display/d.vect/main.c
          Function
icon_files(Begins at: 32, Ends at:76)
LOC:          |      45 |     * |      WARNING |        45 |
main(Begins at: 78, Ends at:720)
Complexity:   |      80 |   *** |      MONSTER |        80 |
CalledNBR:    |     202 |   *** |      MONSTER |       202 |
LOC:          |     643 |   *** |      MONSTER |       643 |
Clone analysis:
          File :grass/trunk/display/d.vect.chart/main.c
          Function
main(Begins at: 30, Ends at:284)
Complexity:   |      21 |   *** |      MONSTER |        21 |
CalledNBR:    |      65 |   *** |      MONSTER |        65 |
LOC:          |     255 |   *** |      MONSTER |       255 |
Clone analysis:
          File :grass/trunk/display/d.what.rast/main.c
          Function
main(Begins at: 30, Ends at:143)
LOC:          |     114 |    ** | BABY-MONSTER |       114 |
Clone analysis:
          File :grass/trunk/display/d.what.vect/main.c
          Function
main(Begins at: 44, Ends at:156)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      45 |   *** |      MONSTER |        45 |
Clone analysis:
          File :grass/trunk/display/d.where/main.c
          Function
main(Begins at: 32, Ends at:174)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
LOC:          |     143 |   *** |      MONSTER |       143 |
Clone analysis:
          File :grass/trunk/display/d.zoom/main.c
          Function
main(Begins at: 38, Ends at:280)
Complexity:   |      33 |   *** |      MONSTER |        33 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     243 |   *** |      MONSTER |       243 |
Clone analysis:
          File :grass/trunk/doc/raster/r.example/main.c
          Function
c_calc(Begins at: 36, Ends at:40)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
d_calc(Begins at: 48, Ends at:52)
metrics are OK
f_calc(Begins at: 42, Ends at:46)
metrics are OK
main(Begins at: 59, Ends at:199)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
LOC:          |     141 |   *** |      MONSTER |       141 |
Clone analysis:
          File :grass/trunk/doc/vector/v.example/main.c
          Function
main(Begins at: 27, Ends at:223)
CalledNBR:    |      89 |   *** |      MONSTER |        89 |
LOC:          |     197 |   *** |      MONSTER |       197 |
Clone analysis:
          File :grass/trunk/general/g.access/main.c
          Function
main(Begins at: 25, Ends at:85)
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      61 |     * |      WARNING |        61 |
Clone analysis:
          File :grass/trunk/general/g.cairocomp/main.c
          File :grass/trunk/general/g.copy/main.c
          File :grass/trunk/general/g.dirseps/main.c
          Function
main(Begins at: 23, Ends at:107)
LOC:          |      85 |     * |      WARNING |        85 |
Clone analysis:
          File :grass/trunk/general/g.filename/main.c
          Function
main(Begins at: 25, Ends at:82)
LOC:          |      58 |     * |      WARNING |        58 |
Clone analysis:
          File :grass/trunk/general/g.findetc/main.c
          Function
main(Begins at: 20, Ends at:51)
LOC:          |      32 |       |           OK |        32 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/g.findfile/main.c
          Function
main(Begins at: 24, Ends at:102)
CalledNBR:    |      33 |    ** | BABY-MONSTER |        33 |
LOC:          |      79 |     * |      WARNING |        79 |
Clone analysis:
          File :grass/trunk/general/g.gisenv/main.c
          Function
main(Begins at: 25, Ends at:130)
CalledNBR:    |      31 |    ** | BABY-MONSTER |        31 |
Clone analysis:
          File :grass/trunk/general/g.gui/main.c
          Function
main(Begins at: 25, Ends at:111)
Clone analysis:
          File :grass/trunk/general/g.list/main.c
          File :grass/trunk/general/g.mapset/main.c
          Function
main(Begins at: 28, Ends at:204)
LOC:          |     177 |   *** |      MONSTER |       177 |
Clone analysis:
          File :grass/trunk/general/g.mapsets/main.c
          File :grass/trunk/general/g.message/main.c
          Function
main(Begins at: 22, Ends at:112)
LOC:          |      91 |    ** | BABY-MONSTER |        91 |
Clone analysis:
          File :grass/trunk/general/g.mkfontcap/main.c
          Function
add_search_dir(Begins at: 157, Ends at:182)
metrics are OK
compare_fonts(Begins at: 184, Ends at:198)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      15 |       |           OK |        15 |
metrics are OK
main(Begins at: 54, Ends at:155)
Clone analysis:
          File :grass/trunk/general/g.mlist/main.c
          File :grass/trunk/general/g.mremove/main.c
          File :grass/trunk/general/g.parser/main.c
          Class
context(Begins at: 36, Ends at:46)
          Function
main(Begins at: 258, Ends at:421)
LOC:          |     164 |   *** |      MONSTER |       164 |
parse_boolean(Begins at: 171, Ends at:183)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
parse_flag(Begins at: 118, Ends at:153)
LOC:          |      36 |       |           OK |        36 |
parse_module(Begins at: 89, Ends at:116)
parse_option(Begins at: 185, Ends at:256)
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      72 |     * |      WARNING |        72 |
parse_toplevel(Begins at: 62, Ends at:87)
parse_type(Begins at: 155, Ends at:169)
metrics are OK
translate(Begins at: 52, Ends at:60)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/g.pnmcomp/main.c
          Function
erase(Begins at: 29, Ends at:47)
metrics are OK
main(Begins at: 268, Ends at:385)
CalledNBR:    |      37 |   *** |      MONSTER |        37 |
overlay(Begins at: 165, Ends at:201)
LOC:          |      37 |       |           OK |        37 |
overlay_alpha(Begins at: 203, Ends at:232)
metrics are OK
read_header(Begins at: 60, Ends at:83)
LOC:          |      24 |       |           OK |        24 |
read_line(Begins at: 49, Ends at:58)
read_pnm(Begins at: 85, Ends at:163)
Complexity:   |      26 |   *** |      MONSTER |        26 |
CalledNBR:    |      23 |    ** | BABY-MONSTER |        23 |
write_pgm(Begins at: 251, Ends at:266)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
write_ppm(Begins at: 234, Ends at:249)
metrics are OK
Clone analysis:
          File :grass/trunk/general/g.proj/main.c
          Function
main(Begins at: 27, Ends at:241)
LOC:          |     215 |   *** |      MONSTER |       215 |
Clone analysis:
          File :grass/trunk/general/g.region/main.c
          Function
die(Begins at: 826, Ends at:832)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
llinfo(Begins at: 845, Ends at:854)
main(Begins at: 29, Ends at:824)
Complexity:   |     120 |   *** |      MONSTER |       120 |
CalledNBR:    |     259 |   *** |      MONSTER |       259 |
LOC:          |     796 |   *** |      MONSTER |       796 |
nsew(Begins at: 834, Ends at:843)
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
Clone analysis:
          File :grass/trunk/general/g.remove/main.c
          File :grass/trunk/general/g.rename/main.c
          File :grass/trunk/general/g.setproj/main.c
          Function
leave(Begins at: 660, Ends at:663)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
main(Begins at: 50, Ends at:650)
Complexity:   |     108 |   *** |      MONSTER |       108 |
CalledNBR:    |     289 |   *** |      MONSTER |       289 |
LOC:          |     601 |   *** |      MONSTER |       601 |
min1(Begins at: 652, Ends at:658)
metrics are OK
Clone analysis:
          File :grass/trunk/general/g.tempfile/main.c
          Function
main(Begins at: 25, Ends at:60)
Clone analysis:
          File :grass/trunk/general/g.transform/main.c
          Class
Max(Begins at: 32, Ends at:36)
          Class
Stats(Begins at: 38, Ends at:42)
          Function
analyze(Begins at: 189, Ends at:204)
compute_transformation(Begins at: 83, Ends at:173)
Complexity:   |      24 |   *** |      MONSTER |        24 |
diagonal(Begins at: 77, Ends at:81)
do_max(Begins at: 175, Ends at:178)
metrics are OK
do_stats(Begins at: 180, Ends at:187)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
main(Begins at: 239, Ends at:303)
parse_format(Begins at: 206, Ends at:237)
update_max(Begins at: 60, Ends at:66)
update_stats(Begins at: 68, Ends at:75)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
Clone analysis:
          File :grass/trunk/general/g.version/main.c
          Function
main(Begins at: 26, Ends at:65)
Clone analysis:
          File :grass/trunk/imagery/i.albedo/main.c
          File :grass/trunk/imagery/i.biomass/main.c
          File :grass/trunk/imagery/i.cca/main.c
          Function
main(Begins at: 47, Ends at:221)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      76 |   *** |      MONSTER |        76 |
Clone analysis:
          File :grass/trunk/imagery/i.class/main.c
          Function
check_files(Begins at: 238, Ends at:307)
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |      70 |     * |      WARNING |        70 |
error(Begins at: 207, Ends at:235)
LOC:          |      29 |       |           OK |        29 |
main(Begins at: 75, Ends at:194)
CalledNBR:    |      51 |   *** |      MONSTER |        51 |
LOC:          |     120 |    ** | BABY-MONSTER |       120 |
quit(Begins at: 197, Ends at:204)
metrics are OK
Clone analysis:
          File :grass/trunk/imagery/i.cluster/main.c
          Function
main(Begins at: 54, Ends at:357)
Complexity:   |      28 |   *** |      MONSTER |        28 |
CalledNBR:    |     171 |   *** |      MONSTER |       171 |
LOC:          |     304 |   *** |      MONSTER |       304 |
Clone analysis:
          File :grass/trunk/imagery/i.eb.eta/main.c
          File :grass/trunk/imagery/i.eb.evapfr/main.c
          File :grass/trunk/imagery/i.eb.h_SEBAL01/main.c
          File :grass/trunk/imagery/i.eb.soilheatflux/main.c
          File :grass/trunk/imagery/i.emissivity/main.c
          File :grass/trunk/imagery/i.evapo.time_integration/main.c
          File :grass/trunk/imagery/i.fft/main.c
          File :grass/trunk/imagery/i.gensig/main.c
          Function
main(Begins at: 29, Ends at:54)
CalledNBR:    |      13 |     * |      WARNING |        13 |
Clone analysis:
          File :grass/trunk/imagery/i.gensigset/main.c
          Function
main(Begins at: 28, Ends at:60)
Clone analysis:
          File :grass/trunk/imagery/i.group/main.c
          Function
add_or_update_group(Begins at: 194, Ends at:228)
LOC:          |      35 |       |           OK |        35 |
add_or_update_subgroup(Begins at: 231, Ends at:267)
main(Begins at: 40, Ends at:191)
CalledNBR:    |      60 |   *** |      MONSTER |        60 |
LOC:          |     152 |   *** |      MONSTER |       152 |
remove_group_files(Begins at: 270, Ends at:323)
 at least 4 values are close to an outlier please consider revising code!
remove_subgroup_files(Begins at: 326, Ends at:382)
LOC:          |      57 |     * |      WARNING |        57 |
Clone analysis:
          File :grass/trunk/imagery/i.his.rgb/main.c
          File :grass/trunk/imagery/i.ifft/main.c
          File :grass/trunk/imagery/i.latlong/main.c
          File :grass/trunk/imagery/i.maxlik/main.c
          Function
main(Begins at: 29, Ends at:184)
CalledNBR:    |      74 |   *** |      MONSTER |        74 |
LOC:          |     156 |   *** |      MONSTER |       156 |
Clone analysis:
          File :grass/trunk/imagery/i.modis.qc/main.c
          File :grass/trunk/imagery/i.pca/main.c
          Function
calc_covariance(Begins at: 275, Ends at:342)
LOC:          |      68 |     * |      WARNING |        68 |
calc_mu(Begins at: 224, Ends at:272)
LOC:          |      49 |     * |      WARNING |        49 |
dump_eigen(Begins at: 530, Ends at:547)
LOC:          |      18 |       |           OK |        18 |
main(Begins at: 45, Ends at:176)
CalledNBR:    |      57 |   *** |      MONSTER |        57 |
LOC:          |     132 |    ** | BABY-MONSTER |       132 |
round_c(Begins at: 179, Ends at:191)
metrics are OK
set_output_scale(Begins at: 194, Ends at:221)
write_pca(Begins at: 345, Ends at:526)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
LOC:          |     182 |   *** |      MONSTER |       182 |
Clone analysis:
  ele_round
In /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.pca/main.c clones of round_c are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/ram/init_vars.c  ele_round
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.watershed/seg/init_vars.c  ele_round
          File :grass/trunk/imagery/i.points/main.c
          Function
error(Begins at: 192, Ends at:217)
main(Begins at: 40, Ends at:167)
LOC:          |     128 |    ** | BABY-MONSTER |       128 |
quit(Begins at: 169, Ends at:190)
LOC:          |      22 |       |           OK |        22 |
Clone analysis:
          File :grass/trunk/imagery/i.rectify/main.c
          Function
err_exit(Begins at: 186, Ends at:198)
metrics are OK
main(Begins at: 36, Ends at:183)
CalledNBR:    |      50 |   *** |      MONSTER |        50 |
LOC:          |     148 |   *** |      MONSTER |       148 |
Clone analysis:
          File :grass/trunk/imagery/i.rgb.his/main.c
          File :grass/trunk/imagery/i.smap/main.c
          File :grass/trunk/imagery/i.sunhours/main.c
          File :grass/trunk/imagery/i.target/main.c
          Function
main(Begins at: 34, Ends at:121)
LOC:          |      88 |     * |      WARNING |        88 |
Clone analysis:
          File :grass/trunk/imagery/i.vi/main.c
          File :grass/trunk/imagery/i.vpoints/main.c
          Function
error(Begins at: 196, Ends at:222)
LOC:          |      27 |       |           OK |        27 |
main(Begins at: 36, Ends at:171)
LOC:          |     136 |    ** | BABY-MONSTER |       136 |
quit(Begins at: 173, Ends at:194)
Clone analysis:
          File :grass/trunk/imagery/i.zc/main.c
          Function
main(Begins at: 29, Ends at:208)
CalledNBR:    |      71 |   *** |      MONSTER |        71 |
LOC:          |     180 |   *** |      MONSTER |       180 |
Clone analysis:
          File :grass/trunk/include/gis.h
          Class
Categories(Begins at: 452, Ends at:476)
          Class
Cell_head(Begins at: 257, Ends at:279)
          Class
Cell_stats(Begins at: 492, Ends at:507)
          Class
Cell_stats_node(Begins at: 494, Ends at:500)
          Class
Colors(Begins at: 322, Ends at:340)
          Class
FPRange(Begins at: 527, Ends at:532)
          Class
FPReclass(Begins at: 377, Ends at:399)
          Class
FPReclass_table(Begins at: 367, Ends at:373)
          Class
Flag(Begins at: 600, Ends at:608)
          Class
GModule(Begins at: 610, Ends at:618)
          Class
G_3dview(Begins at: 537, Ends at:562)
          Class
Histogram(Begins at: 509, Ends at:518)
          Class
Histogram_list(Begins at: 513, Ends at:517)
          Class
History(Begins at: 478, Ends at:490)
          Class
Key_Value(Begins at: 564, Ends at:570)
          Class
Option(Begins at: 572, Ends at:598)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Quant(Begins at: 409, Ends at:450)
          Class
Quant_table(Begins at: 401, Ends at:407)
          Class
Range(Begins at: 520, Ends at:525)
          Class
Reclass(Begins at: 356, Ends at:365)
          Class
TimeStamp(Begins at: 620, Ends at:624)
          Class
_Color_Info_(Begins at: 295, Ends at:320)
          Class
_Color_Rule_(Begins at: 281, Ends at:293)
Clone analysis:
          File :grass/trunk/include/gisdefs.h
          File :grass/trunk/lib/gis/parser.c
          Class
Item(Begins at: 109, Ends at:114)
          Function
G_define_flag(Begins at: 176, Ends at:213)
Complexity:   |       3 |     * |      WARNING |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      38 |     * |      WARNING |        38 |
G_define_module(Begins at: 649, Ends at:662)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
LOC:          |      14 |       |           OK |        14 |
G_define_option(Begins at: 232, Ends at:283)
Complexity:   |       3 |    ** | BABY-MONSTER |         3 |
LOC:          |      52 |       |           OK |        52 |
G_define_standard_option(Begins at: 312, Ends at:640)
Complexity:   |      38 |     * |      WARNING |        38 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |     329 |       |           OK |       329 |
G_disable_interactive(Begins at: 155, Ends at:160)
Complexity:   |       1 |     * |      WARNING |         1 |
G_gui(Begins at: 1973, Ends at:1988)
CalledNBR:    |       5 |     * |      WARNING |         5 |
LOC:          |      16 |     * |      WARNING |        16 |
G_gui_tcltk(Begins at: 1918, Ends at:1947)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      12 |       |           OK |        12 |
metrics are OK
G_gui_wx(Begins at: 1952, Ends at:1964)
G_parser(Begins at: 701, Ends at:955)
Complexity:   |      41 |       |           OK |        41 |
CalledNBR:    |      83 |       |           OK |        83 |
LOC:          |     255 |       |           OK |       255 |
metrics are OK
G_recreate_command(Begins at: 2600, Ends at:2699)
Complexity:   |      14 |     * |      WARNING |        14 |
LOC:          |     100 |    ** | BABY-MONSTER |       100 |
G_script(Begins at: 1696, Ends at:1808)
Complexity:   |      24 |     * |      WARNING |        24 |
CalledNBR:    |      46 |     * |      WARNING |        46 |
LOC:          |     113 |     * |      WARNING |       113 |
G_tcltk(Begins at: 1993, Ends at:2001)
metrics are OK
G_usage(Begins at: 1008, Ends at:1179)
Complexity:   |      34 |       |           OK |        34 |
CalledNBR:    |      53 |       |           OK |        53 |
LOC:          |     172 |       |           OK |       172 |
metrics are OK
G_usage_html(Begins at: 1472, Ends at:1691)
Complexity:   |      42 |       |           OK |        42 |
CalledNBR:    |      85 |       |           OK |        85 |
LOC:          |     220 |     * |      WARNING |       220 |
G_usage_xml(Begins at: 1234, Ends at:1467)
Complexity:   |      31 |   *** |      MONSTER |        31 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     234 |   *** |      MONSTER |       234 |
check_an_opt(Begins at: 2201, Ends at:2243)
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      43 |       |           OK |        43 |
metrics are OK
check_double(Begins at: 2309, Ends at:2345)
Complexity:   |      14 |       |           OK |        14 |
metrics are OK
check_int(Begins at: 2245, Ends at:2281)
CalledNBR:    |       6 |     * |      WARNING |         6 |
check_multiple_opts(Begins at: 2457, Ends at:2492)
Complexity:   |       8 |       |           OK |         8 |
metrics are OK
check_opts(Begins at: 2165, Ends at:2199)
Complexity:   |       7 |   *** |      MONSTER |         7 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |      35 |   *** |      MONSTER |        35 |
check_overwrite(Begins at: 2495, Ends at:2560)
Complexity:   |      12 |    ** | BABY-MONSTER |        12 |
CalledNBR:    |      16 |    ** | BABY-MONSTER |        16 |
LOC:          |      66 |    ** | BABY-MONSTER |        66 |
check_required(Begins at: 2373, Ends at:2395)
Complexity:   |       4 |   *** |      MONSTER |         4 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |      23 |    ** | BABY-MONSTER |        23 |
check_string(Begins at: 2347, Ends at:2371)
Complexity:   |       9 |       |           OK |         9 |
metrics are OK
contains(Begins at: 2083, Ends at:2091)
Complexity:   |       3 |   *** |      MONSTER |         3 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |       9 |   *** |      MONSTER |         9 |
generate_tcl(Begins at: 1815, Ends at:1913)
Complexity:   |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |      34 |   *** |      MONSTER |        34 |
LOC:          |      99 |   *** |      MONSTER |        99 |
is_option(Begins at: 2093, Ends at:2106)
LOC:          |      14 |   *** |      MONSTER |        14 |
print_escaped_for_html(Begins at: 1213, Ends at:1227)
Complexity:   |       4 |     * |      WARNING |         4 |
print_escaped_for_xml(Begins at: 1189, Ends at:1206)
Complexity:   |       7 |       |           OK |         7 |
metrics are OK
set_flag(Begins at: 2054, Ends at:2078)
LOC:          |      25 |    ** | BABY-MONSTER |        25 |
set_option(Begins at: 2108, Ends at:2163)
LOC:          |      56 |       |           OK |        56 |
metrics are OK
show(Begins at: 2040, Ends at:2052)
metrics are OK
show_options(Begins at: 2010, Ends at:2038)
split_gisprompt(Begins at: 2562, Ends at:2590)
metrics are OK
split_opts(Begins at: 2397, Ends at:2455)
LOC:          |      59 |     * |      WARNING |        59 |
uses_new_gisprompt(Begins at: 958, Ends at:983)
metrics are OK
Clone analysis:
  check_double
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_double are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_int
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c clones of check_int are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/parser.c  check_double
          File :grass/trunk/misc/m.cogo/main.c
          Class
survey_record(Begins at: 35, Ends at:49)
          Function
main(Begins at: 205, Ends at:336)
next_line(Begins at: 74, Ends at:83)
metrics are OK
parse_forward(Begins at: 86, Ends at:136)
LOC:          |      51 |     * |      WARNING |        51 |
parse_reverse(Begins at: 139, Ends at:202)
LOC:          |      64 |     * |      WARNING |        64 |
print_cogo(Begins at: 61, Ends at:71)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
print_coordinates(Begins at: 52, Ends at:58)
metrics are OK
Clone analysis:
          File :grass/trunk/ps/ps.map/main.c
          Function
main(Begins at: 88, Ends at:753)
Complexity:   |     102 |   *** |      MONSTER |       102 |
CalledNBR:    |     220 |   *** |      MONSTER |       220 |
LOC:          |     666 |   *** |      MONSTER |       666 |
Clone analysis:
          File :grass/trunk/raster/r.basins.fill/main.c
          Function
main(Begins at: 37, Ends at:161)
LOC:          |     125 |    ** | BABY-MONSTER |       125 |
Clone analysis:
          File :grass/trunk/raster/r.bitpattern/main.c
          Function
main(Begins at: 43, Ends at:152)
LOC:          |     110 |    ** | BABY-MONSTER |       110 |
Clone analysis:
          File :grass/trunk/raster/r.buffer/main.c
          Function
main(Begins at: 42, Ends at:175)
LOC:          |     134 |    ** | BABY-MONSTER |       134 |
Clone analysis:
          File :grass/trunk/raster/r.carve/main.c
          Function
init_projection(Begins at: 195, Ends at:224)
metrics are OK
main(Begins at: 56, Ends at:192)
LOC:          |     137 |    ** | BABY-MONSTER |       137 |
Clone analysis:
          File :grass/trunk/raster/r.category/main.c
          Function
main(Begins at: 31, Ends at:296)
Complexity:   |      41 |   *** |      MONSTER |        41 |
CalledNBR:    |     111 |   *** |      MONSTER |       111 |
LOC:          |     266 |   *** |      MONSTER |       266 |
print_d_label(Begins at: 310, Ends at:322)
metrics are OK
print_label(Begins at: 300, Ends at:308)
metrics are OK
scan_cats(Begins at: 324, Ends at:337)
scan_vals(Begins at: 339, Ends at:347)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.circle/main.c
          Function
distance(Begins at: 165, Ends at:185)
ParamNBR:     |       5 |     * |      WARNING |         5 |
main(Begins at: 34, Ends at:159)
CalledNBR:    |      47 |   *** |      MONSTER |        47 |
LOC:          |     126 |    ** | BABY-MONSTER |       126 |
Clone analysis:
          File :grass/trunk/raster/r.clump/main.c
          Function
main(Begins at: 25, Ends at:100)
LOC:          |      76 |     * |      WARNING |        76 |
Clone analysis:
          File :grass/trunk/raster/r.coin/main.c
          Function
main(Begins at: 45, Ends at:136)
LOC:          |      92 |    ** | BABY-MONSTER |        92 |
Clone analysis:
          File :grass/trunk/raster/r.colors/main.c
          Function
find_rule(Begins at: 124, Ends at:133)
metrics are OK
list_rules(Begins at: 116, Ends at:122)
metrics are OK
main(Begins at: 135, Ends at:385)
Complexity:   |      39 |   *** |      MONSTER |        39 |
CalledNBR:    |     105 |   *** |      MONSTER |       105 |
LOC:          |     251 |   *** |      MONSTER |       251 |
rules_descriptions(Begins at: 76, Ends at:114)
metrics are OK
rules_list(Begins at: 50, Ends at:74)
metrics are OK
scan_rules(Begins at: 35, Ends at:48)
CalledNBR:    |       8 |     * |      WARNING |         8 |
Clone analysis:
          File :grass/trunk/raster/r.colors.out/main.c
          Function
main(Begins at: 42, Ends at:143)
CalledNBR:    |      34 |       |           OK |        34 |
LOC:          |     102 |       |           OK |       102 |
write_rule(Begins at: 27, Ends at:40)
CalledNBR:    |       2 |    ** | BABY-MONSTER |         2 |
LOC:          |      14 |    ** | BABY-MONSTER |        14 |
Clone analysis:
          File :grass/trunk/raster/r.composite/main.c
          Class
band(Begins at: 25, Ends at:39)
          Function
main(Begins at: 49, Ends at:267)
LOC:          |     219 |   *** |      MONSTER |       219 |
make_color_cube(Begins at: 275, Ends at:306)
metrics are OK
quantize(Begins at: 269, Ends at:273)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.compress/main.c
          Function
doit(Begins at: 167, Ends at:237)
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |      71 |     * |      WARNING |        71 |
main(Begins at: 49, Ends at:84)
process(Begins at: 87, Ends at:165)
Clone analysis:
          File :grass/trunk/raster/r.contour/main.c
          Function
displaceMatrix(Begins at: 325, Ends at:345)
get_z_array(Begins at: 211, Ends at:226)
Complexity:   |       2 |     * |      WARNING |         2 |
ParamNBR:     |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |       8 |    ** | BABY-MONSTER |         8 |
getlevels(Begins at: 230, Ends at:316)
Complexity:   |      12 |       |           OK |        12 |
ParamNBR:     |       6 |     * |      WARNING |         6 |
LOC:          |      87 |       |           OK |        87 |
main(Begins at: 53, Ends at:208)
CalledNBR:    |      67 |   *** |      MONSTER |        67 |
Clone analysis:
          File :grass/trunk/raster/r.cost/main.c
          Class
variables(Begins at: 70, Ends at:78)
          Function
main(Begins at: 86, Ends at:1028)
Complexity:   |     137 |   *** |      MONSTER |       137 |
CalledNBR:    |     276 |   *** |      MONSTER |       276 |
LOC:          |     943 |   *** |      MONSTER |       943 |
process_answers(Begins at: 1030, Ends at:1080)
time_to_stop(Begins at: 1082, Ends at:1102)
Clone analysis:
  time_to_stop
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c clones of process_answers are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c  process_answers
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c clones of time_to_stop are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c  time_to_stop
          File :grass/trunk/raster/r.covar/main.c
          Function
main(Begins at: 27, Ends at:136)
Clone analysis:
          File :grass/trunk/raster/r.cross/main.c
          Function
cmp(Begins at: 191, Ends at:203)
metrics are OK
main(Begins at: 41, Ends at:189)
CalledNBR:    |      66 |   *** |      MONSTER |        66 |
LOC:          |     149 |   *** |      MONSTER |       149 |
Clone analysis:
          File :grass/trunk/raster/r.describe/main.c
          Function
main(Begins at: 27, Ends at:116)
LOC:          |      90 |     * |      WARNING |        90 |
Clone analysis:
          File :grass/trunk/raster/r.digit/main.c
          Function
main(Begins at: 29, Ends at:102)
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
LOC:          |      74 |     * |      WARNING |        74 |
Clone analysis:
          File :grass/trunk/raster/r.distance/main.c
          Function
main(Begins at: 25, Ends at:54)
Clone analysis:
          File :grass/trunk/raster/r.drain/main.c
          Class
point(Begins at: 60, Ends at:66)
          Function
drain(Begins at: 447, Ends at:504)
main(Begins at: 68, Ends at:445)
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |     127 |   *** |      MONSTER |       127 |
LOC:          |     378 |   *** |      MONSTER |       378 |
Clone analysis:
          File :grass/trunk/raster/r.external/main.c
          Class
band_info(Begins at: 35, Ends at:43)
          Function
check_projection(Begins at: 72, Ends at:184)
create_map(Begins at: 402, Ends at:440)
list_formats(Begins at: 45, Ends at:70)
metrics are OK
main(Begins at: 442, Ends at:565)
LOC:          |     124 |    ** | BABY-MONSTER |       124 |
make_cell(Begins at: 347, Ends at:365)
metrics are OK
make_link(Begins at: 367, Ends at:400)
query_band(Begins at: 260, Ends at:345)
LOC:          |      86 |     * |      WARNING |        86 |
setup_window(Begins at: 186, Ends at:232)
LOC:          |      47 |     * |      WARNING |        47 |
update_default_window(Begins at: 234, Ends at:258)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.external.out/main.c
          File :grass/trunk/raster/r.fill.dir/main.c
          Function
dir_type(Begins at: 299, Ends at:364)
LOC:          |      66 |     * |      WARNING |        66 |
main(Begins at: 59, Ends at:297)
CalledNBR:    |     113 |   *** |      MONSTER |       113 |
LOC:          |     239 |   *** |      MONSTER |       239 |
Clone analysis:
          File :grass/trunk/raster/r.flow/main.c
          Function
add_to_line(Begins at: 160, Ends at:167)
metrics are OK
calculate(Begins at: 300, Ends at:399)
height_angle_bounding_box(Begins at: 94, Ends at:136)
LOC:          |      43 |     * |      WARNING |        43 |
main(Begins at: 401, Ends at:592)
LOC:          |     192 |   *** |      MONSTER |       192 |
next_point(Begins at: 198, Ends at:294)
LOC:          |      97 |    ** | BABY-MONSTER |        97 |
on_map(Begins at: 147, Ends at:153)
rectify(Begins at: 172, Ends at:189)
Clone analysis:
          File :grass/trunk/raster/r.grow/main.c
          Function
distance_euclidean_squared(Begins at: 36, Ends at:39)
metrics are OK
distance_manhattan(Begins at: 46, Ends at:49)
metrics are OK
distance_maximum(Begins at: 41, Ends at:44)
metrics are OK
main(Begins at: 95, Ends at:294)
Complexity:   |      29 |   *** |      MONSTER |        29 |
LOC:          |     200 |   *** |      MONSTER |       200 |
setup_neighbors(Begins at: 51, Ends at:76)
setup_neighbors_euclidean(Begins at: 78, Ends at:83)
metrics are OK
setup_neighbors_manhattan(Begins at: 90, Ends at:93)
metrics are OK
setup_neighbors_maximum(Begins at: 85, Ends at:88)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.grow.distance/main.c
          Function
check(Begins at: 84, Ends at:118)
distance_euclidean_squared(Begins at: 41, Ends at:44)
metrics are OK
distance_manhattan(Begins at: 51, Ends at:54)
metrics are OK
distance_maximum(Begins at: 46, Ends at:49)
metrics are OK
geodesic_distance(Begins at: 56, Ends at:64)
Complexity:   |       1 |   *** |      MONSTER |         1 |
CalledNBR:    |       5 |   *** |      MONSTER |         5 |
main(Begins at: 120, Ends at:372)
Complexity:   |      38 |       |           OK |        38 |
CalledNBR:    |     101 |       |           OK |       101 |
LOC:          |     253 |       |           OK |       253 |
metrics are OK
swap_rows(Begins at: 66, Ends at:82)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.gwflow/main.c
          Function
copy_result(Begins at: 477, Ends at:511)
create_solve_les(Begins at: 516, Ends at:564)
main(Begins at: 199, Ends at:471)
CalledNBR:    |     100 |   *** |      MONSTER |       100 |
LOC:          |     273 |   *** |      MONSTER |       273 |
set_params(Begins at: 51, Ends at:194)
LOC:          |     144 |   *** |      MONSTER |       144 |
Clone analysis:
          File :grass/trunk/raster/r.his/main.c
          Function
main(Begins at: 25, Ends at:306)
CalledNBR:    |      97 |   *** |      MONSTER |        97 |
LOC:          |     282 |   *** |      MONSTER |       282 |
Clone analysis:
          File :grass/trunk/raster/r.horizon/main.c
          File :grass/trunk/raster/r.in.arc/main.c
          Function
file_cpy(Begins at: 212, Ends at:234)
LOC:          |      23 |       |           OK |        23 |
metrics are OK
main(Begins at: 31, Ends at:210)
Clone analysis:
          File :grass/trunk/raster/r.in.ascii/main.c
          Function
file_cpy(Begins at: 267, Ends at:291)
metrics are OK
main(Begins at: 36, Ends at:264)
CalledNBR:    |      96 |   *** |      MONSTER |        96 |
LOC:          |     229 |   *** |      MONSTER |       229 |
Clone analysis:
          File :grass/trunk/raster/r.in.bin/main.c
          Function
SwabDouble(Begins at: 53, Ends at:70)
LOC:          |      18 |   *** |      MONSTER |        18 |
SwabFloat(Begins at: 48, Ends at:51)
metrics are OK
SwabLong(Begins at: 35, Ends at:46)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
SwabShort(Begins at: 25, Ends at:33)
metrics are OK
main(Begins at: 72, Ends at:593)
Complexity:   |      73 |       |           OK |        73 |
CalledNBR:    |     213 |       |           OK |       213 |
LOC:          |     522 |       |           OK |       522 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.in.gdal/main.c
          Function
ImportBand(Begins at: 642, Ends at:922)
Complexity:   |      42 |   *** |      MONSTER |        42 |
LOC:          |     281 |   *** |      MONSTER |       281 |
SetupReprojector(Begins at: 585, Ends at:634)
Complexity:   |       6 |   *** |      MONSTER |         6 |
CalledNBR:    |      21 |   *** |      MONSTER |        21 |
LOC:          |      50 |   *** |      MONSTER |        50 |
main(Begins at: 49, Ends at:578)
Complexity:   |      55 |     * |      WARNING |        55 |
CalledNBR:    |     196 |     * |      WARNING |       196 |
LOC:          |     530 |     * |      WARNING |       530 |
Clone analysis:
          File :grass/trunk/raster/r.in.gridatb/main.c
          Function
main(Begins at: 29, Ends at:76)
LOC:          |      48 |     * |      WARNING |        48 |
Clone analysis:
          File :grass/trunk/raster/r.in.mat/main.c
          Function
SwabDouble(Begins at: 571, Ends at:588)
SwabFloat(Begins at: 566, Ends at:569)
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
LOC:          |       4 |   *** |      MONSTER |         4 |
SwabLong(Begins at: 553, Ends at:564)
metrics are OK
SwabShort(Begins at: 543, Ends at:551)
metrics are OK
is_nan(Begins at: 504, Ends at:538)
metrics are OK
main(Begins at: 48, Ends at:500)
Complexity:   |      68 |       |           OK |        68 |
CalledNBR:    |     196 |       |           OK |       196 |
LOC:          |     453 |       |           OK |       453 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.in.poly/main.c
          Function
main(Begins at: 20, Ends at:65)
LOC:          |      46 |     * |      WARNING |        46 |
Clone analysis:
          File :grass/trunk/raster/r.in.xyz/main.c
          Class
node(Begins at: 28, Ends at:32)
          Function
add_node(Begins at: 55, Ends at:90)
metrics are OK
main(Begins at: 94, Ends at:1064)
Complexity:   |     147 |   *** |      MONSTER |       147 |
CalledNBR:    |     286 |   *** |      MONSTER |       286 |
LOC:          |     971 |   *** |      MONSTER |       971 |
new_node(Begins at: 40, Ends at:50)
metrics are OK
scan_bounds(Begins at: 1068, Ends at:1187)
Clone analysis:
          File :grass/trunk/raster/r.info/main.c
          Function
compose_line(Begins at: 420, Ends at:434)
format_double(Begins at: 413, Ends at:417)
metrics are OK
main(Begins at: 39, Ends at:410)
Complexity:   |      45 |   *** |      MONSTER |        45 |
CalledNBR:    |     132 |   *** |      MONSTER |       132 |
LOC:          |     372 |   *** |      MONSTER |       372 |
Clone analysis:
          File :grass/trunk/raster/r.kappa/main.c
          Function
layer(Begins at: 134, Ends at:149)
metrics are OK
main(Begins at: 50, Ends at:131)
LOC:          |      82 |     * |      WARNING |        82 |
Clone analysis:
          File :grass/trunk/raster/r.lake/main.c
          Function
is_near_water(Begins at: 85, Ends at:100)
metrics are OK
load_window_values(Begins at: 103, Ends at:130)
main(Begins at: 132, Ends at:393)
Complexity:   |      37 |   *** |      MONSTER |        37 |
CalledNBR:    |     103 |   *** |      MONSTER |       103 |
LOC:          |     262 |   *** |      MONSTER |       262 |
save_map(Begins at: 42, Ends at:82)
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
Clone analysis:
          File :grass/trunk/raster/r.le/r.le.patch/main.c
          Function
main(Begins at: 37, Ends at:202)
Complexity:   |      60 |   *** |      MONSTER |        60 |
CalledNBR:    |      73 |   *** |      MONSTER |        73 |
LOC:          |     166 |   *** |      MONSTER |       166 |
Clone analysis:
          File :grass/trunk/raster/r.le/r.le.pixel/main.c
          Function
main(Begins at: 33, Ends at:157)
Complexity:   |      40 |   *** |      MONSTER |        40 |
Clone analysis:
          File :grass/trunk/raster/r.le/r.le.setup/main.c
          Function
get_pwd(Begins at: 130, Ends at:140)
metrics are OK
main(Begins at: 43, Ends at:124)
Clone analysis:
          File :grass/trunk/raster/r.le/r.le.trace/main.c
          Function
cell_clip(Begins at: 502, Ends at:727)
LOC:          |     226 |   *** |      MONSTER |       226 |
cell_clip_drv(Begins at: 377, Ends at:495)
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
clockwise(Begins at: 1655, Ends at:1662)
metrics are OK
draw_patch(Begins at: 334, Ends at:352)
metrics are OK
get_bd(Begins at: 850, Ends at:1502)
Complexity:   |      97 |   *** |      MONSTER |        97 |
CalledNBR:    |      43 |   *** |      MONSTER |        43 |
LOC:          |     653 |   *** |      MONSTER |       653 |
main(Begins at: 40, Ends at:106)
LOC:          |      67 |     * |      WARNING |        67 |
patch_attr(Begins at: 282, Ends at:325)
scr_cell(Begins at: 362, Ends at:367)
set_map(Begins at: 115, Ends at:147)
show_patch(Begins at: 157, Ends at:277)
LOC:          |     121 |    ** | BABY-MONSTER |       121 |
trace(Begins at: 735, Ends at:838)
LOC:          |     104 |    ** | BABY-MONSTER |       104 |
yes_nb(Begins at: 1517, Ends at:1646)
LOC:          |     130 |    ** | BABY-MONSTER |       130 |
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.cwed/cwed.c
          Function
addCoppia(Begins at: 716, Ends at:811)
calculate(Begins at: 300, Ends at:437)
CalledNBR:    |      26 |   *** |      MONSTER |        26 |
LOC:          |     138 |   *** |      MONSTER |       138 |
calculateD(Begins at: 440, Ends at:572)
Complexity:   |      21 |       |           OK |        21 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |      25 |     * |      WARNING |        25 |
LOC:          |     133 |     * |      WARNING |       133 |
calculateF(Begins at: 576, Ends at:712)
Complexity:   |      22 |    ** | BABY-MONSTER |        22 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |     137 |     * |      WARNING |       137 |
contrastWeightedEdgeDensity(Begins at: 85, Ends at:295)
CalledNBR:    |      38 |    ** | BABY-MONSTER |        38 |
LOC:          |     211 |    ** | BABY-MONSTER |       211 |
main(Begins at: 37, Ends at:82)
CalledNBR:    |      12 |    ** | BABY-MONSTER |        12 |
LOC:          |      46 |    ** | BABY-MONSTER |        46 |
updateCoppia(Begins at: 815, Ends at:877)
Complexity:   |      14 |   *** |      MONSTER |        14 |
CalledNBR:    |      10 |    ** | BABY-MONSTER |        10 |
LOC:          |      63 |    ** | BABY-MONSTER |        63 |
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.dominance/dominance.c
          Function
calculate(Begins at: 113, Ends at:317)
Complexity:   |      32 |   *** |      MONSTER |        32 |
LOC:          |     205 |   *** |      MONSTER |       205 |
calculateD(Begins at: 325, Ends at:526)
LOC:          |     202 |   *** |      MONSTER |       202 |
calculateF(Begins at: 529, Ends at:732)
LOC:          |     204 |   *** |      MONSTER |       204 |
dominance(Begins at: 67, Ends at:110)
main(Begins at: 33, Ends at:64)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
          Function
calculate(Begins at: 121, Ends at:379)
LOC:          |     259 |   *** |      MONSTER |       259 |
calculateD(Begins at: 381, Ends at:645)
LOC:          |     265 |   *** |      MONSTER |       265 |
calculateF(Begins at: 647, Ends at:908)
edgedensity(Begins at: 78, Ends at:117)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.mpa/mpa.c
          Function
calculate(Begins at: 110, Ends at:172)
LOC:          |      63 |     * |      WARNING |        63 |
calculateD(Begins at: 173, Ends at:236)
calculateF(Begins at: 238, Ends at:302)
main(Begins at: 31, Ends at:62)
meanPixelAttribute(Begins at: 65, Ends at:106)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.mps/mps.c
          Function
calculate(Begins at: 107, Ends at:475)
LOC:          |     369 |   *** |      MONSTER |       369 |
calculateD(Begins at: 478, Ends at:844)
LOC:          |     367 |   *** |      MONSTER |       367 |
calculateF(Begins at: 847, Ends at:1212)
LOC:          |     366 |   *** |      MONSTER |       366 |
main(Begins at: 32, Ends at:61)
meanPatchSize(Begins at: 65, Ends at:104)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.padcv/padcv.c
          Function
calculate(Begins at: 97, Ends at:518)
Complexity:   |      61 |   *** |      MONSTER |        61 |
LOC:          |     422 |   *** |      MONSTER |       422 |
calculateD(Begins at: 519, Ends at:939)
LOC:          |     421 |   *** |      MONSTER |       421 |
calculateF(Begins at: 940, Ends at:1362)
LOC:          |     423 |   *** |      MONSTER |       423 |
main(Begins at: 29, Ends at:53)
patchAreaDistributionCV(Begins at: 54, Ends at:96)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.padrange/padrange.c
          Function
calculate(Begins at: 101, Ends at:506)
LOC:          |     406 |   *** |      MONSTER |       406 |
calculateD(Begins at: 510, Ends at:898)
LOC:          |     389 |   *** |      MONSTER |       389 |
calculateF(Begins at: 902, Ends at:1295)
LOC:          |     394 |   *** |      MONSTER |       394 |
main(Begins at: 31, Ends at:55)
patchAreaDistributionRANGE(Begins at: 56, Ends at:98)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.padsd/padsd.c
          Function
calculate(Begins at: 97, Ends at:515)
LOC:          |     419 |   *** |      MONSTER |       419 |
calculateD(Begins at: 519, Ends at:936)
LOC:          |     418 |   *** |      MONSTER |       418 |
calculateF(Begins at: 937, Ends at:1354)
patchAreaDistributionSD(Begins at: 54, Ends at:96)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.patchdensity/main.c
          Function
main(Begins at: 24, Ends at:56)
patch_density(Begins at: 59, Ends at:200)
LOC:          |     142 |   *** |      MONSTER |       142 |
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.patchnum/main.c
          Function
main(Begins at: 25, Ends at:56)
patch_number(Begins at: 58, Ends at:178)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.richness/richness.c
          Function
calculate(Begins at: 108, Ends at:264)
LOC:          |     157 |   *** |      MONSTER |       157 |
calculateD(Begins at: 267, Ends at:425)
LOC:          |     159 |   *** |      MONSTER |       159 |
calculateF(Begins at: 429, Ends at:591)
LOC:          |     163 |   *** |      MONSTER |       163 |
dominance(Begins at: 64, Ends at:104)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.shannon/shannon.c
          Function
calculate(Begins at: 109, Ends at:309)
LOC:          |     201 |   *** |      MONSTER |       201 |
calculateD(Begins at: 317, Ends at:517)
calculateF(Begins at: 520, Ends at:716)
main(Begins at: 30, Ends at:61)
shannon(Begins at: 64, Ends at:106)
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.shape/main.c
          Function
main(Begins at: 26, Ends at:57)
shape_index(Begins at: 59, Ends at:114)
LOC:          |      56 |     * |      WARNING |        56 |
Clone analysis:
          File :grass/trunk/raster/r.li/r.li.simpson/simpson.c
          Function
calculate(Begins at: 108, Ends at:295)
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     188 |   *** |      MONSTER |       188 |
calculateD(Begins at: 298, Ends at:483)
LOC:          |     186 |   *** |      MONSTER |       186 |
calculateF(Begins at: 487, Ends at:677)
LOC:          |     191 |   *** |      MONSTER |       191 |
simpson(Begins at: 64, Ends at:104)
Clone analysis:
          File :grass/trunk/raster/r.los/main.c
          Function
main(Begins at: 63, Ends at:427)
CalledNBR:    |     128 |   *** |      MONSTER |       128 |
LOC:          |     365 |   *** |      MONSTER |       365 |
Clone analysis:
          File :grass/trunk/raster/r.mapcalc/main.c
          Function
handle_fpe(Begins at: 40, Ends at:44)
metrics are OK
main(Begins at: 102, Ends at:167)
CalledNBR:    |      25 |       |           OK |        25 |
LOC:          |      66 |       |           OK |        66 |
metrics are OK
parse_file(Begins at: 81, Ends at:98)
CalledNBR:    |       7 |    ** | BABY-MONSTER |         7 |
LOC:          |      18 |     * |      WARNING |        18 |
post_exec(Begins at: 64, Ends at:77)
metrics are OK
pre_exec(Begins at: 46, Ends at:62)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter/main.c
          Function
main(Begins at: 33, Ends at:137)
Clone analysis:
          File :grass/trunk/raster/r.mode/main.c
          Function
main(Begins at: 30, Ends at:126)
Clone analysis:
          File :grass/trunk/raster/r.neighbors/main.c
          Class
menu(Begins at: 32, Ends at:41)
          Function
main(Begins at: 64, Ends at:316)
Complexity:   |      30 |   *** |      MONSTER |        30 |
CalledNBR:    |      91 |   *** |      MONSTER |        91 |
LOC:          |     253 |   *** |      MONSTER |       253 |
Clone analysis:
          File :grass/trunk/raster/r.null/main.c
          Function
doit(Begins at: 308, Ends at:356)
main(Begins at: 28, Ends at:202)
parse_d_mask_rule(Begins at: 236, Ends at:264)
parse_vallist(Begins at: 204, Ends at:234)
process(Begins at: 266, Ends at:306)
Clone analysis:
          File :grass/trunk/raster/r.out.arc/main.c
          Function
main(Begins at: 24, Ends at:222)
LOC:          |     199 |   *** |      MONSTER |       199 |
Clone analysis:
          File :grass/trunk/raster/r.out.ascii/main.c
          Function
main(Begins at: 28, Ends at:199)
CalledNBR:    |      59 |   *** |      MONSTER |        59 |
LOC:          |     172 |   *** |      MONSTER |       172 |
Clone analysis:
          File :grass/trunk/raster/r.out.bin/main.c
          Function
main(Begins at: 21, Ends at:389)
Complexity:   |      49 |   *** |      MONSTER |        49 |
CalledNBR:    |     205 |   *** |      MONSTER |       205 |
set_type(Begins at: 392, Ends at:411)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.out.gdal/main.c
          Function
AttachMetadata(Begins at: 85, Ends at:101)
metrics are OK
main(Begins at: 104, Ends at:499)
Complexity:   |      50 |   *** |      MONSTER |        50 |
ParamNBR:     |       2 |    ** | BABY-MONSTER |         2 |
CalledNBR:    |     110 |   *** |      MONSTER |       110 |
LOC:          |     396 |   *** |      MONSTER |       396 |
supported_formats(Begins at: 37, Ends at:82)
Complexity:   |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      19 |   *** |      MONSTER |        19 |
LOC:          |      46 |   *** |      MONSTER |        46 |
Clone analysis:
          File :grass/trunk/raster/r.out.gridatb/main.c
          Function
main(Begins at: 30, Ends at:80)
Clone analysis:
          File :grass/trunk/raster/r.out.mat/main.c
          Function
main(Begins at: 22, Ends at:385)
CalledNBR:    |     163 |   *** |      MONSTER |       163 |
LOC:          |     364 |   *** |      MONSTER |       364 |
Clone analysis:
          File :grass/trunk/raster/r.out.mpeg/main.c
          Function
gee_wildfiles(Begins at: 378, Ends at:427)
LOC:          |      50 |     * |      WARNING |        50 |
load_files(Begins at: 224, Ends at:353)
Complexity:   |      16 |     * |      WARNING |        16 |
CalledNBR:    |      42 |       |           OK |        42 |
LOC:          |     130 |       |           OK |       130 |
main(Begins at: 74, Ends at:221)
Complexity:   |      17 |       |           OK |        17 |
CalledNBR:    |      35 |       |           OK |        35 |
LOC:          |     148 |       |           OK |       148 |
metrics are OK
parse_command(Begins at: 431, Ends at:464)
Complexity:   |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      34 |    ** | BABY-MONSTER |        34 |
use_r_out(Begins at: 356, Ends at:374)
LOC:          |      19 |   *** |      MONSTER |        19 |
Clone analysis:
          File :grass/trunk/raster/r.out.png/main.c
          Function
main(Begins at: 48, Ends at:321)
LOC:          |     274 |   *** |      MONSTER |       274 |
Clone analysis:
          File :grass/trunk/raster/r.out.pov/main.c
          Function
main(Begins at: 94, Ends at:233)
LOC:          |     140 |    ** | BABY-MONSTER |       140 |
processProfiles(Begins at: 264, Ends at:299)
writeHeader(Begins at: 238, Ends at:258)
Clone analysis:
          File :grass/trunk/raster/r.out.ppm/main.c
          Function
main(Begins at: 32, Ends at:230)
CalledNBR:    |      78 |   *** |      MONSTER |        78 |
Clone analysis:
          File :grass/trunk/raster/r.out.ppm3/main.c
          Class
band(Begins at: 27, Ends at:36)
          Function
main(Begins at: 40, Ends at:197)
CalledNBR:    |      63 |   *** |      MONSTER |        63 |
LOC:          |     158 |   *** |      MONSTER |       158 |
Clone analysis:
          File :grass/trunk/raster/r.out.tiff/main.c
          Function
main(Begins at: 70, Ends at:378)
Complexity:   |      34 |   *** |      MONSTER |        34 |
LOC:          |     309 |   *** |      MONSTER |       309 |
write_tfw(Begins at: 381, Ends at:405)
Clone analysis:
          File :grass/trunk/raster/r.out.vrml/main.c
          Function
do_coordcnv(Begins at: 218, Ends at:242)
init_coordcnv(Begins at: 193, Ends at:216)
main(Begins at: 28, Ends at:168)
Clone analysis:
          File :grass/trunk/raster/r.out.vtk/main.c
          Function
main(Begins at: 37, Ends at:291)
Complexity:   |      33 |    ** | BABY-MONSTER |        33 |
CalledNBR:    |      65 |     * |      WARNING |        65 |
LOC:          |     255 |     * |      WARNING |       255 |
Clone analysis:
          File :grass/trunk/raster/r.param.scale/interface.c
          Function
interface(Begins at: 20, Ends at:172)
LOC:          |     153 |   *** |      MONSTER |       153 |
Clone analysis:
          File :grass/trunk/raster/r.patch/main.c
          Function
main(Begins at: 24, Ends at:176)
Clone analysis:
          File :grass/trunk/raster/r.profile/main.c
          Function
do_profile(Begins at: 226, Ends at:332)
Complexity:   |      23 |       |           OK |        23 |
ParamNBR:     |      11 |       |           OK |        11 |
CalledNBR:    |      31 |       |           OK |        31 |
LOC:          |     107 |       |           OK |       107 |
metrics are OK
main(Begins at: 22, Ends at:222)
Complexity:   |      20 |   *** |      MONSTER |        20 |
ParamNBR:     |       2 |   *** |      MONSTER |         2 |
CalledNBR:    |      72 |    ** | BABY-MONSTER |        72 |
LOC:          |     201 |    ** | BABY-MONSTER |       201 |
Clone analysis:
          File :grass/trunk/raster/r.proj/main.c
          File :grass/trunk/raster/r.quant/main.c
          Function
main(Begins at: 31, Ends at:188)
CalledNBR:    |      68 |   *** |      MONSTER |        68 |
Clone analysis:
          File :grass/trunk/raster/r.quantile/main.c
          Class
bin(Begins at: 19, Ends at:24)
          Function
compare_dcell(Begins at: 162, Ends at:172)
metrics are OK
compute_quantiles(Begins at: 191, Ends at:235)
fill_bins(Begins at: 128, Ends at:160)
metrics are OK
get_quantile(Begins at: 52, Ends at:55)
metrics are OK
get_slot(Begins at: 41, Ends at:50)
metrics are OK
get_slot_counts(Begins at: 57, Ends at:86)
metrics are OK
initialize_bins(Begins at: 88, Ends at:126)
metrics are OK
main(Begins at: 237, Ends at:340)
sort_bins(Begins at: 174, Ends at:189)
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
  egcmp  cmp  fcmp  dcmp  dcmp  cmp_along  cmp
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.quantile/main.c clones of compare_dcell are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/db/dbmi_client/select.c  cmpcatkey
          /var/project-manager/grass/grassSVN/grass/trunk/lib/gmath/la.c  egcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.coin/make_coin.c  cmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  fcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmedian.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mapcalc/xmode.c  dcmp
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.lrs/v.lrs.label/main.c  cmp_along
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.path/path.c  cmp
          File :grass/trunk/raster/r.random/main.c
          Function
has_percent(Begins at: 175, Ends at:182)
metrics are OK
main(Begins at: 30, Ends at:172)
Clone analysis:
          File :grass/trunk/raster/r.random.cells/main.c
          Function
main(Begins at: 38, Ends at:75)
LOC:          |      38 |       |           OK |        38 |
Clone analysis:
          File :grass/trunk/raster/r.random.surface/main.c
          File :grass/trunk/raster/r.reclass/main.c
          File :grass/trunk/raster/r.recode/main.c
          File :grass/trunk/raster/r.region/main.c
          File :grass/trunk/raster/r.report/main.c
          File :grass/trunk/raster/r.resamp.interp/main.c
          File :grass/trunk/raster/r.resamp.rst/main.c
          File :grass/trunk/raster/r.resamp.stats/main.c
          File :grass/trunk/raster/r.resample/main.c
          File :grass/trunk/raster/r.rescale/main.c
          File :grass/trunk/raster/r.rescale.eq/main.c
          File :grass/trunk/raster/r.ros/main.c
          File :grass/trunk/raster/r.series/main.c
          Class
input(Begins at: 55, Ends at:60)
          Class
menu(Begins at: 24, Ends at:53)
          Class
output(Begins at: 62, Ends at:68)
Clone analysis:
          File :grass/trunk/raster/r.slope.aspect/main.c
          File :grass/trunk/raster/r.spread/main.c
          File :grass/trunk/raster/r.spreadpath/main.c
          File :grass/trunk/raster/r.statistics/main.c
          File :grass/trunk/raster/r.statistics2/main.c
          File :grass/trunk/raster/r.statistics3/main.c
          File :grass/trunk/raster/r.stats/main.c
          File :grass/trunk/raster/r.sun/main.c
          File :grass/trunk/raster/r.sun2/main.c
          File :grass/trunk/raster/r.sunmask/main.c
          Class
RASTER_PTR(Begins at: 68, Ends at:74)
Clone analysis:
          File :grass/trunk/raster/r.support/main.c
          File :grass/trunk/raster/r.support.stats/main.c
          File :grass/trunk/raster/r.surf.area/main.c
          Function
add_null_area(Begins at: 263, Ends at:272)
              |          New Metrics           |Old Metrics|
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
add_row_area(Begins at: 176, Ends at:259)
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      84 |     * |      WARNING |        84 |
main(Begins at: 74, Ends at:172)
LOC:          |      99 |       |           OK |        99 |
v3cross(Begins at: 276, Ends at:281)
metrics are OK
v3mag(Begins at: 285, Ends at:288)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |    ** | BABY-MONSTER |         1 |
LOC:          |       4 |    ** | BABY-MONSTER |         4 |
Clone analysis:
          File :grass/trunk/raster/r.surf.contour/main.c
          Function
main(Begins at: 43, Ends at:145)
CalledNBR:    |      44 |   *** |      MONSTER |        44 |
LOC:          |     103 |    ** | BABY-MONSTER |       103 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/raster/r.surf.fractal/main.c
          Function
main(Begins at: 28, Ends at:86)
Clone analysis:
          File :grass/trunk/raster/r.surf.gauss/main.c
          Function
main(Begins at: 24, Ends at:69)
Clone analysis:
          File :grass/trunk/raster/r.surf.idw/main.c
          Function
add_neighbor(Begins at: 605, Ends at:620)
completed_row(Begins at: 479, Ends at:482)
metrics are OK
exhaust(Begins at: 442, Ends at:468)
Complexity:   |       4 |       |           OK |         4 |
exhaust_search(Begins at: 565, Ends at:587)
Complexity:   |       5 |       |           OK |         5 |
find_neighbors(Begins at: 529, Ends at:558)
first_west(Begins at: 508, Ends at:522)
metrics are OK
free_row_lists(Begins at: 665, Ends at:682)
metrics are OK
interpolate(Begins at: 233, Ends at:313)
LOC:          |      81 |     * |      WARNING |        81 |
lookup_and_function_ptrs(Begins at: 198, Ends at:224)
Complexity:   |       2 |       |           OK |         2 |
Conclusion:   | this function is a            OK           |
metrics are OK
lookup_tables(Begins at: 753, Ends at:772)
metrics are OK
main(Begins at: 80, Ends at:189)
make_neighbors_list(Begins at: 325, Ends at:388)
next_row(Begins at: 485, Ends at:500)
offset_distance(Begins at: 470, Ends at:473)
metrics are OK
replace_neighbor(Begins at: 623, Ends at:645)
row_lists(Begins at: 685, Ends at:746)
LOC:          |      62 |     * |      WARNING |        62 |
search(Begins at: 393, Ends at:439)
sort_neighbors(Begins at: 648, Ends at:661)
metrics are OK
triangulate(Begins at: 594, Ends at:602)
Clone analysis:
          File :grass/trunk/raster/r.surf.idw2/main.c
          Class
Point(Begins at: 29, Ends at:34)
          Function
main(Begins at: 39, Ends at:193)
LOC:          |     155 |   *** |      MONSTER |       155 |
newpoint(Begins at: 195, Ends at:209)
Clone analysis:
          File :grass/trunk/raster/r.surf.random/main.c
          Function
main(Begins at: 22, Ends at:67)
Clone analysis:
          File :grass/trunk/raster/r.texture/main.c
          Function
main(Begins at: 48, Ends at:365)
CalledNBR:    |     108 |   *** |      MONSTER |       108 |
LOC:          |     318 |   *** |      MONSTER |       318 |
Clone analysis:
          File :grass/trunk/raster/r.thin/main.c
          Function
main(Begins at: 44, Ends at:88)
CalledNBR:    |      19 |     * |      WARNING |        19 |
Clone analysis:
          File :grass/trunk/raster/r.timestamp/main.c
          Function
main(Begins at: 23, Ends at:74)
CalledNBR:    |      22 |     * |      WARNING |        22 |
Clone analysis:
          File :grass/trunk/raster/r.to.rast3/main.c
          Function
close_input_raster_map(Begins at: 360, Ends at:364)
metrics are OK
fatal_error(Begins at: 50, Ends at:69)
main(Begins at: 176, Ends at:333)
open_input_raster_map(Begins at: 340, Ends at:355)
metrics are OK
raster_to_g3d(Begins at: 92, Ends at:170)
set_params(Begins at: 74, Ends at:85)
ParamNBR:     |       0 |       |           OK |         0 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.to.rast3elev/main.c
          Function
check_input_maps(Begins at: 80, Ends at:103)
close_input_raster_map(Begins at: 126, Ends at:130)
metrics are OK
elev_raster_to_g3d(Begins at: 198, Ends at:331)
fatal_error(Begins at: 135, Ends at:152)
metrics are OK
get_raster_value_as_double(Begins at: 64, Ends at:75)
main(Begins at: 336, Ends at:498)
open_input_raster_map(Begins at: 108, Ends at:121)
metrics are OK
set_params(Begins at: 157, Ends at:193)
Clone analysis:
          File :grass/trunk/raster/r.to.vect/main.c
          Function
main(Begins at: 59, Ends at:295)
CalledNBR:    |      93 |   *** |      MONSTER |        93 |
LOC:          |     237 |   *** |      MONSTER |       237 |
Clone analysis:
          File :grass/trunk/raster/r.topidx/main.c
          Function
main(Begins at: 29, Ends at:71)
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/raster/r.topmodel/main.c
          Function
main(Begins at: 31, Ends at:230)
Clone analysis:
          File :grass/trunk/raster/r.transect/main.c
          Function
main(Begins at: 28, Ends at:121)
LOC:          |      94 |    ** | BABY-MONSTER |        94 |
Clone analysis:
          File :grass/trunk/raster/r.univar/r.univar_main.c
          Function
main(Begins at: 60, Ends at:137)
LOC:          |      78 |     * |      WARNING |        78 |
open_raster(Begins at: 139, Ends at:148)
metrics are OK
process_raster(Begins at: 167, Ends at:237)
set_params(Begins at: 26, Ends at:50)
metrics are OK
univar_stat_with_percentiles(Begins at: 150, Ends at:165)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.univar/r3.univar_main.c
          Function
main(Begins at: 55, Ends at:187)
LOC:          |     133 |    ** | BABY-MONSTER |       133 |
set_params(Begins at: 25, Ends at:49)
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.uslek/main.c
          File :grass/trunk/raster/r.usler/main.c
          File :grass/trunk/raster/r.volume/main.c
          Function
main(Begins at: 33, Ends at:242)
CalledNBR:    |      61 |   *** |      MONSTER |        61 |
LOC:          |     210 |   *** |      MONSTER |       210 |
Clone analysis:
          File :grass/trunk/raster/r.walk/main.c
          Class
variables(Begins at: 108, Ends at:116)
          Function
main(Begins at: 127, Ends at:1514)
Complexity:   |     209 |   *** |      MONSTER |       209 |
CalledNBR:    |     391 |   *** |      MONSTER |       391 |
LOC:          |    1388 |   *** |      MONSTER |      1388 |
process_answers(Begins at: 1519, Ends at:1569)
time_to_stop(Begins at: 1574, Ends at:1594)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      21 |       |           OK |        21 |
Clone analysis:
This file has 2 potentially cloned functions:
  time_to_stop
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c clones of process_answers are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c  process_answers
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.walk/main.c clones of time_to_stop are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.cost/main.c  time_to_stop
          File :grass/trunk/raster/r.water.outlet/main.c
          Function
main(Begins at: 51, Ends at:170)
Clone analysis:
          File :grass/trunk/raster/r.watershed/front/main.c
          Function
main(Begins at: 25, Ends at:438)
CalledNBR:    |     147 |   *** |      MONSTER |       147 |
LOC:          |     414 |   *** |      MONSTER |       414 |
write_hist(Begins at: 441, Ends at:458)
Clone analysis:
          File :grass/trunk/raster/r.what/main.c
          Class
order(Begins at: 26, Ends at:37)
          Function
by_point(Begins at: 465, Ends at:470)
metrics are OK
by_row(Begins at: 452, Ends at:457)
metrics are OK
main(Begins at: 48, Ends at:425)
Complexity:   |      59 |   *** |      MONSTER |        59 |
oops(Begins at: 430, Ends at:444)
Complexity:   |       3 |       |           OK |         3 |
Clone analysis:
          File :grass/trunk/raster/r.what.color/main.c
          Function
do_value(Begins at: 27, Ends at:67)
main(Begins at: 69, Ends at:152)
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :grass/trunk/raster/simwe/r.sim.sediment/main.c
          Function
main(Begins at: 100, Ends at:429)
LOC:          |     330 |   *** |      MONSTER |       330 |
Clone analysis:
          File :grass/trunk/raster/simwe/r.sim.water/main.c
          Function
main(Begins at: 107, Ends at:537)
CalledNBR:    |     117 |   *** |      MONSTER |       117 |
LOC:          |     431 |   *** |      MONSTER |       431 |
Clone analysis:
          File :grass/trunk/raster3d/base/r3.mask.main.c
          Function
getParams(Begins at: 37, Ends at:41)
Complexity:   |       1 |       |           OK |         1 |
metrics are OK
main(Begins at: 124, Ends at:164)
CalledNBR:    |      16 |     * |      WARNING |        16 |
makeMask(Begins at: 47, Ends at:120)
Clone analysis:
          File :grass/trunk/raster3d/base/r3.null.main.c
          Function
getParams(Begins at: 75, Ends at:86)
main(Begins at: 192, Ends at:214)
CalledNBR:    |      10 |     * |      WARNING |        10 |
modifyNull(Begins at: 90, Ends at:188)
LOC:          |      99 |    ** | BABY-MONSTER |        99 |
setParams(Begins at: 46, Ends at:71)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster3d/r3.cross.rast/main.c
          Function
close_output_map(Begins at: 74, Ends at:78)
metrics are OK
fatal_error(Begins at: 48, Ends at:68)
CalledNBR:    |       7 |       |           OK |         7 |
main(Begins at: 255, Ends at:398)
rast3d_cross_section(Begins at: 118, Ends at:249)
set_params(Begins at: 84, Ends at:111)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      28 |       |           OK |        28 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster3d/r3.gwflow/main.c
          Function
main(Begins at: 146, Ends at:347)
set_params(Begins at: 48, Ends at:141)
write_result(Begins at: 353, Ends at:420)
Clone analysis:
          File :grass/trunk/raster3d/r3.in.ascii/main.c
          Function
asciiToG3d(Begins at: 161, Ends at:219)
fatalError(Begins at: 52, Ends at:60)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
getParams(Begins at: 95, Ends at:106)
CalledNBR:    |       4 |       |           OK |         4 |
main(Begins at: 223, Ends at:289)
openAscii(Begins at: 125, Ends at:155)
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      31 |       |           OK |        31 |
readHeaderString(Begins at: 110, Ends at:121)
setParams(Begins at: 71, Ends at:91)
metrics are OK
Clone analysis:
          File :grass/trunk/raster3d/r3.in.v5d/main.c
          Function
convert(Begins at: 104, Ends at:174)
fatalError(Begins at: 45, Ends at:52)
metrics are OK
getParams(Begins at: 91, Ends at:100)
main(Begins at: 178, Ends at:224)
setParams(Begins at: 63, Ends at:87)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster3d/r3.info/r3.info.main.c
          Function
format_double(Begins at: 432, Ends at:438)
metrics are OK
main(Begins at: 46, Ends at:429)
CalledNBR:    |     187 |   *** |      MONSTER |       187 |
LOC:          |     384 |   *** |      MONSTER |       384 |
Clone analysis:
          File :grass/trunk/raster3d/r3.mkdspf/main.c
          Function
main(Begins at: 55, Ends at:234)
Clone analysis:
          File :grass/trunk/raster3d/r3.out.ascii/main.c
          Function
G3dToascii(Begins at: 181, Ends at:226)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      46 |       |           OK |        46 |
metrics are OK
fatalError(Begins at: 53, Ends at:63)
LOC:          |      11 |     * |      WARNING |        11 |
getParams(Begins at: 113, Ends at:118)
LOC:          |       6 |       |           OK |         6 |
main(Begins at: 232, Ends at:308)
LOC:          |      77 |     * |      WARNING |        77 |
openAscii(Begins at: 147, Ends at:175)
setParams(Begins at: 68, Ends at:108)
writeHeaderString(Begins at: 124, Ends at:131)
writeHeaderString2(Begins at: 134, Ends at:141)
Clone analysis:
          File :grass/trunk/raster3d/r3.out.v5d/main.c
          Function
convert(Begins at: 104, Ends at:272)
LOC:          |     169 |   *** |      MONSTER |       169 |
fatalError(Begins at: 49, Ends at:58)
metrics are OK
getParams(Begins at: 93, Ends at:97)
main(Begins at: 278, Ends at:333)
setParams(Begins at: 63, Ends at:88)
metrics are OK
Clone analysis:
          File :grass/trunk/raster3d/r3.out.vtk/main.c
          Function
check_input_maps(Begins at: 113, Ends at:186)
create_input_maps_struct(Begins at: 62, Ends at:87)
metrics are OK
main(Begins at: 361, Ends at:570)
open_input_map(Begins at: 92, Ends at:107)
metrics are OK
open_write_rgb_maps(Begins at: 192, Ends at:271)
LOC:          |      80 |     * |      WARNING |        80 |
open_write_vector_maps(Begins at: 276, Ends at:355)
Clone analysis:
          File :grass/trunk/raster3d/r3.stats/main.c
          Function
add_equal_val_to_array(Begins at: 94, Ends at:123)
LOC:          |      30 |       |           OK |        30 |
metrics are OK
alloc_equal_val_array(Begins at: 73, Ends at:89)
metrics are OK
check_equal_value(Begins at: 128, Ends at:148)
metrics are OK
check_range_value(Begins at: 361, Ends at:378)
metrics are OK
create_stat_table(Begins at: 173, Ends at:249)
CalledNBR:    |      11 |     * |      WARNING |        11 |
 at least 3 values are close to an outlier please consider revising code!
downheap_eqvals(Begins at: 513, Ends at:538)
free_equal_val_array(Begins at: 154, Ends at:167)
metrics are OK
free_stat_table(Begins at: 254, Ends at:269)
metrics are OK
heapsort_eqvals(Begins at: 486, Ends at:507)
metrics are OK
main(Begins at: 544, Ends at:719)
Complexity:   |      23 |   *** |      MONSTER |        23 |
LOC:          |     176 |   *** |      MONSTER |       176 |
print_stat_table(Begins at: 302, Ends at:356)
LOC:          |      55 |     * |      WARNING |        55 |
tree_search_range(Begins at: 411, Ends at:480)
Complexity:   |      10 |     * |      WARNING |        10 |
update_stat_table(Begins at: 274, Ends at:297)
metrics are OK
Clone analysis:
          File :grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
          Function
main(Begins at: 31, Ends at:95)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |      65 |     * |      WARNING |        65 |
Clone analysis:
          File :grass/trunk/raster3d/r3.to.rast/main.c
          Function
close_output_map(Begins at: 191, Ends at:195)
metrics are OK
fatal_error(Begins at: 48, Ends at:66)
LOC:          |      19 |       |           OK |        19 |
g3d_to_raster(Begins at: 102, Ends at:172)
main(Begins at: 200, Ends at:392)
LOC:          |     193 |   *** |      MONSTER |       193 |
open_output_map(Begins at: 177, Ends at:186)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
set_params(Begins at: 71, Ends at:97)
metrics are OK
Clone analysis:
          File :grass/trunk/sites/s.in.ascii/main.c
          Function
G_site_put_new(Begins at: 168, Ends at:255)
format_double(Begins at: 149, Ends at:156)
metrics are OK
main(Begins at: 31, Ends at:148)
LOC:          |     118 |    ** | BABY-MONSTER |       118 |
Clone analysis:
          File :grass/trunk/sites/s.out.ascii/main.c
          Function
main(Begins at: 22, Ends at:138)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
LOC:          |     117 |    ** | BABY-MONSTER |       117 |
Clone analysis:
          File :grass/trunk/swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c
          Function
r_slope_aspect(Begins at: 60, Ends at:1418)
Complexity:   |     159 |   *** |      MONSTER |       159 |
CalledNBR:    |     511 |   *** |      MONSTER |       511 |
LOC:          |    1359 |   *** |      MONSTER |      1359 |
Clone analysis:
          File :grass/trunk/vector/lidar/v.lidar.correction/main.c
          Function
main(Begins at: 32, Ends at:347)
CalledNBR:    |     124 |   *** |      MONSTER |       124 |
LOC:          |     316 |   *** |      MONSTER |       316 |
Clone analysis:
          File :grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
          Function
main(Begins at: 41, Ends at:386)
CalledNBR:    |     138 |   *** |      MONSTER |       138 |
LOC:          |     346 |   *** |      MONSTER |       346 |
Clone analysis:
          File :grass/trunk/vector/lidar/v.lidar.growing/main.c
          Function
main(Begins at: 36, Ends at:499)
Complexity:   |      48 |   *** |      MONSTER |        48 |
CalledNBR:    |     123 |   *** |      MONSTER |       123 |
LOC:          |     464 |   *** |      MONSTER |       464 |
Clone analysis:
          File :grass/trunk/vector/lidar/v.outlier/main.c
          Function
main(Begins at: 35, Ends at:361)
CalledNBR:    |     118 |   *** |      MONSTER |       118 |
LOC:          |     327 |   *** |      MONSTER |       327 |
Clone analysis:
          File :grass/trunk/vector/lidar/v.surf.bspline/main.c
          Function
main(Begins at: 35, Ends at:719)
Complexity:   |      68 |   *** |      MONSTER |        68 |
CalledNBR:    |     229 |   *** |      MONSTER |       229 |
LOC:          |     685 |   *** |      MONSTER |       685 |
Clone analysis:
          File :grass/trunk/vector/v.buffer/main.c
          Function
area_in_buffer(Begins at: 137, Ends at:217)
input_distance(Begins at: 36, Ends at:130)
LOC:          |      95 |    ** | BABY-MONSTER |        95 |
main(Begins at: 229, Ends at:756)
Complexity:   |      65 |   *** |      MONSTER |        65 |
CalledNBR:    |     192 |   *** |      MONSTER |       192 |
LOC:          |     528 |   *** |      MONSTER |       528 |
stop(Begins at: 219, Ends at:227)
metrics are OK
Clone analysis:
          File :grass/trunk/vector/v.build/main.c
          Function
main(Begins at: 24, Ends at:167)
Complexity:   |      27 |   *** |      MONSTER |        27 |
Clone analysis:
          File :grass/trunk/vector/v.build.polylines/main.c
          Function
main(Begins at: 84, Ends at:236)
Complexity:   |      12 |     * |      WARNING |        12 |
Clone analysis:
          File :grass/trunk/vector/v.category/main.c
          Function
main(Begins at: 48, Ends at:501)
Complexity:   |      84 |   *** |      MONSTER |        84 |
CalledNBR:    |     122 |   *** |      MONSTER |       122 |
LOC:          |     454 |   *** |      MONSTER |       454 |
Clone analysis:
          File :grass/trunk/vector/v.class/main.c
          Function
main(Begins at: 26, Ends at:227)
Clone analysis:
          File :grass/trunk/vector/v.clean/main.c
          Function
main(Begins at: 25, Ends at:398)
Complexity:   |      62 |   *** |      MONSTER |        62 |
CalledNBR:    |     175 |   *** |      MONSTER |       175 |
LOC:          |     374 |   *** |      MONSTER |       374 |
Clone analysis:
          File :grass/trunk/vector/v.clean/test/topocheck.c
          Function
main(Begins at: 23, Ends at:54)
metrics are OK
Clone analysis:
          File :grass/trunk/vector/v.convert/main.c
          Function
main(Begins at: 28, Ends at:76)
CalledNBR:    |      14 |     * |      WARNING |        14 |
Clone analysis:
          File :grass/trunk/vector/v.db.connect/main.c
          Function
main(Begins at: 31, Ends at:325)
Complexity:   |      36 |   *** |      MONSTER |        36 |
CalledNBR:    |     130 |   *** |      MONSTER |       130 |
LOC:          |     295 |   *** |      MONSTER |       295 |
Clone analysis:
          File :grass/trunk/vector/v.db.select/main.c
          Function
main(Begins at: 29, Ends at:185)
Complexity:   |      22 |   *** |      MONSTER |        22 |
Clone analysis:
          File :grass/trunk/vector/v.delaunay/main.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/vector/v.distance/main.c
          Function
cmp_exist(Begins at: 1189, Ends at:1199)
metrics are OK
cmp_near(Begins at: 1156, Ends at:1166)
metrics are OK
cmp_near_to(Begins at: 1168, Ends at:1186)
metrics are OK
main(Begins at: 72, Ends at:1153)
Complexity:   |     174 |   *** |      MONSTER |       174 |
CalledNBR:    |     340 |   *** |      MONSTER |       340 |
LOC:          |    1082 |   *** |      MONSTER |      1082 |
print_upload(Begins at: 1204, Ends at:1277)
Complexity:   |      21 |   *** |      MONSTER |        21 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
Clone analysis:
          File :grass/trunk/vector/v.drape/main.c
          Function
main(Begins at: 37, Ends at:286)
LOC:          |     250 |   *** |      MONSTER |       250 |
Clone analysis:
          File :grass/trunk/vector/v.edit/main.c
          Function
main(Begins at: 23, Ends at:471)
Complexity:   |      75 |   *** |      MONSTER |        75 |
CalledNBR:    |     184 |   *** |      MONSTER |       184 |
LOC:          |     449 |   *** |      MONSTER |       449 |
Clone analysis:
          File :grass/trunk/vector/v.external/main.c
          Function
main(Begins at: 28, Ends at:165)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
LOC:          |     138 |    ** | BABY-MONSTER |       138 |
Clone analysis:
          File :grass/trunk/vector/v.extract/main.c
          Function
add_cat(Begins at: 38, Ends at:48)
metrics are OK
main(Begins at: 50, Ends at:413)
Complexity:   |      52 |   *** |      MONSTER |        52 |
CalledNBR:    |     135 |   *** |      MONSTER |       135 |
scan_cats(Begins at: 417, Ends at:436)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      20 |       |           OK |        20 |
Clone analysis:
          File :grass/trunk/vector/v.extrude/main.c
          Function
extrude(Begins at: 380, Ends at:514)
Complexity:   |      19 |    ** | BABY-MONSTER |        19 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
LOC:          |     135 |    ** | BABY-MONSTER |       135 |
main(Begins at: 34, Ends at:356)
Complexity:   |      33 |   *** |      MONSTER |        33 |
LOC:          |     323 |   *** |      MONSTER |       323 |
Clone analysis:
          File :grass/trunk/vector/v.generalize/main.c
          Function
main(Begins at: 42, Ends at:501)
CalledNBR:    |     156 |   *** |      MONSTER |       156 |
LOC:          |     460 |   *** |      MONSTER |       460 |
Clone analysis:
          File :grass/trunk/vector/v.hull/main.c
          Class
Point(Begins at: 33, Ends at:38)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
cmpPoints(Begins at: 51, Ends at:63)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
convexHull(Begins at: 65, Ends at:128)
convexHull3d(Begins at: 132, Ends at:161)
loadSiteCoordinates(Begins at: 164, Ends at:215)
LOC:          |      52 |     * |      WARNING |        52 |
main(Begins at: 267, Ends at:380)
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     114 |    ** | BABY-MONSTER |       114 |
outputHull(Begins at: 223, Ends at:265)
rightTurn(Begins at: 40, Ends at:49)
Clone analysis:
          File :grass/trunk/vector/v.in.ascii/main.c
          File :grass/trunk/vector/v.in.db/main.c
          Function
main(Begins at: 26, Ends at:236)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
CalledNBR:    |      98 |   *** |      MONSTER |        98 |
LOC:          |     211 |   *** |      MONSTER |       211 |
Clone analysis:
          File :grass/trunk/vector/v.in.dwg/main.c
          Function
main(Begins at: 64, Ends at:289)
CalledNBR:    |     104 |   *** |      MONSTER |       104 |
Clone analysis:
          File :grass/trunk/vector/v.in.dxf/main.c
          Function
main(Begins at: 41, Ends at:210)
Complexity:   |      17 |    ** | BABY-MONSTER |        17 |
LOC:          |     170 |   *** |      MONSTER |       170 |
Clone analysis:
          File :grass/trunk/vector/v.in.ogr/main.c
          Function
main(Begins at: 47, Ends at:1133)
Complexity:   |     115 |   *** |      MONSTER |       115 |
CalledNBR:    |     422 |   *** |      MONSTER |       422 |
LOC:          |    1087 |   *** |      MONSTER |      1087 |
Clone analysis:
          File :grass/trunk/vector/v.in.region/main.c
          Function
main(Begins at: 24, Ends at:101)
CalledNBR:    |      34 |    ** | BABY-MONSTER |        34 |
Clone analysis:
          File :grass/trunk/vector/v.in.sites/main.c
          Function
main(Begins at: 32, Ends at:258)
CalledNBR:    |     114 |   *** |      MONSTER |       114 |
LOC:          |     227 |   *** |      MONSTER |       227 |
Clone analysis:
          File :grass/trunk/vector/v.info/main.c
          Function
format_double(Begins at: 337, Ends at:341)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
main(Begins at: 42, Ends at:333)
CalledNBR:    |     230 |   *** |      MONSTER |       230 |
LOC:          |     292 |   *** |      MONSTER |       292 |
Clone analysis:
          File :grass/trunk/vector/v.kcv/main.c
          Function
drand48(Begins at: 40, Ends at:43)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
main(Begins at: 53, Ends at:265)
CalledNBR:    |      84 |   *** |      MONSTER |        84 |
LOC:          |     213 |   *** |      MONSTER |       213 |
Clone analysis:
          File :grass/trunk/vector/v.kernel/main.c
          Function
L(Begins at: 37, Ends at:76)
LOC:          |      40 |       |           OK |        40 |
compute_all_distances(Begins at: 481, Ends at:506)
LOC:          |      26 |     * |      WARNING |        26 |
compute_all_net_distances(Begins at: 511, Ends at:585)
ParamNBR:     |       5 |    ** | BABY-MONSTER |         5 |
CalledNBR:    |      18 |       |           OK |        18 |
LOC:          |      75 |     * |      WARNING |        75 |
compute_distance(Begins at: 644, Ends at:691)
Complexity:   |       5 |     * |      WARNING |         5 |
ParamNBR:     |       7 |   *** |      MONSTER |         7 |
compute_net_distance(Begins at: 589, Ends at:642)
ParamNBR:     |       9 |       |           OK |         9 |
LOC:          |      54 |       |           OK |        54 |
main(Begins at: 79, Ends at:442)
read_points(Begins at: 446, Ends at:476)
Clone analysis:
          File :grass/trunk/vector/v.label/main.c
          Function
main(Begins at: 33, Ends at:445)
CalledNBR:    |     140 |   *** |      MONSTER |       140 |
LOC:          |     413 |   *** |      MONSTER |       413 |
print_label(Begins at: 447, Ends at:473)
Clone analysis:
          File :grass/trunk/vector/v.label.sa/main.c
          Function
main(Begins at: 33, Ends at:114)
parse_args(Begins at: 116, Ends at:235)
CalledNBR:    |      39 |   *** |      MONSTER |        39 |
print_label(Begins at: 237, Ends at:268)
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      32 |       |           OK |        32 |
Clone analysis:
          File :grass/trunk/vector/v.lrs/v.lrs.create/main.c
          Function
cmp_along(Begins at: 876, Ends at:892)
metrics are OK
main(Begins at: 82, Ends at:874)
Complexity:   |      80 |   *** |      MONSTER |        80 |
CalledNBR:    |     271 |   *** |      MONSTER |       271 |
LOC:          |     793 |   *** |      MONSTER |       793 |
Clone analysis:
          File :grass/trunk/vector/v.lrs/v.lrs.label/main.c
          Function
cmp_along(Begins at: 525, Ends at:535)
metrics are OK
main(Begins at: 50, Ends at:523)
CalledNBR:    |     180 |   *** |      MONSTER |       180 |
LOC:          |     474 |   *** |      MONSTER |       474 |
Clone analysis:
          File :grass/trunk/vector/v.lrs/v.lrs.segment/main.c
          Function
find_line(Begins at: 359, Ends at:378)
main(Begins at: 43, Ends at:354)
LOC:          |     312 |   *** |      MONSTER |       312 |
offset_pt_90(Begins at: 384, Ends at:388)
ParamNBR:     |       4 |     * |      WARNING |         4 |
Clone analysis:
          File :grass/trunk/vector/v.lrs/v.lrs.where/main.c
          Function
main(Begins at: 36, Ends at:230)
CalledNBR:    |      80 |   *** |      MONSTER |        80 |
LOC:          |     195 |   *** |      MONSTER |       195 |
Clone analysis:
          File :grass/trunk/vector/v.mkgrid/main.c
          Function
main(Begins at: 30, Ends at:286)
LOC:          |     257 |   *** |      MONSTER |       257 |
Clone analysis:
          File :grass/trunk/vector/v.neighbors/main.c
          Function
main(Begins at: 27, Ends at:155)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |     129 |    ** | BABY-MONSTER |       129 |
Clone analysis:
          File :grass/trunk/vector/v.net/main.c
          Function
main(Begins at: 28, Ends at:212)
LOC:          |     185 |   *** |      MONSTER |       185 |
Clone analysis:
          File :grass/trunk/vector/v.net.alloc/main.c
          Function
main(Begins at: 38, Ends at:378)
CalledNBR:    |     119 |   *** |      MONSTER |       119 |
LOC:          |     341 |   *** |      MONSTER |       341 |
Clone analysis:
          File :grass/trunk/vector/v.net.iso/main.c
          Function
main(Begins at: 44, Ends at:538)
Complexity:   |      58 |   *** |      MONSTER |        58 |
CalledNBR:    |     139 |   *** |      MONSTER |       139 |
LOC:          |     495 |   *** |      MONSTER |       495 |
Clone analysis:
          File :grass/trunk/vector/v.net.path/main.c
          Function
main(Begins at: 25, Ends at:155)
CalledNBR:    |      55 |   *** |      MONSTER |        55 |
LOC:          |     131 |    ** | BABY-MONSTER |       131 |
Clone analysis:
          File :grass/trunk/vector/v.net.salesman/main.c
          Function
add_city(Begins at: 49, Ends at:70)
metrics are OK
cmp(Begins at: 391, Ends at:403)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
cnode(Begins at: 44, Ends at:47)
LOC:          |       4 |       |           OK |         4 |
metrics are OK
main(Begins at: 73, Ends at:389)
LOC:          |     317 |   *** |      MONSTER |       317 |
Clone analysis:
This file has 3 potentially cloned functions:
  cmp  cmp
In /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.salesman/main.c clones of cmp are:
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.net.steiner/main.c  cmp
          File :grass/trunk/vector/v.net.steiner/main.c
          Function
cmp(Begins at: 649, Ends at:661)
metrics are OK
get_node_costs(Begins at: 89, Ends at:112)
LOC:          |      24 |       |           OK |        24 |
init_node_costs(Begins at: 53, Ends at:83)
metrics are OK
main(Begins at: 320, Ends at:647)
Complexity:   |      35 |   *** |      MONSTER |        35 |
LOC:          |     328 |   *** |      MONSTER |       328 |
mst(Begins at: 123, Ends at:318)
LOC:          |     196 |   *** |      MONSTER |       196 |
Clone analysis:
          File :grass/trunk/vector/v.net.visibility/main.c
          Function
add_points(Begins at: 161, Ends at:187)
count(Begins at: 191, Ends at:227)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      37 |       |           OK |        37 |
count_new(Begins at: 144, Ends at:157)
metrics are OK
load_lines(Begins at: 232, Ends at:263)
CalledNBR:    |       6 |       |           OK |         6 |
main(Begins at: 26, Ends at:140)
LOC:          |     115 |    ** | BABY-MONSTER |       115 |
process_boundary(Begins at: 329, Ends at:371)
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
process_line(Begins at: 285, Ends at:325)
LOC:          |      41 |       |           OK |        41 |
process_point(Begins at: 265, Ends at:281)
Clone analysis:
          File :grass/trunk/vector/v.normal/main.c
          Function
main(Begins at: 45, Ends at:352)
CalledNBR:    |     112 |   *** |      MONSTER |       112 |
LOC:          |     308 |   *** |      MONSTER |       308 |
Clone analysis:
          File :grass/trunk/vector/v.out.ascii/main.c
          File :grass/trunk/vector/v.out.dxf/main.c
          Function
add_plines(Begins at: 147, Ends at:204)
Complexity:   |       8 |     * |      WARNING |         8 |
LOC:          |      58 |     * |      WARNING |        58 |
do_limits(Begins at: 106, Ends at:123)
metrics are OK
main(Begins at: 37, Ends at:104)
CalledNBR:    |      31 |    ** | BABY-MONSTER |        31 |
LOC:          |      68 |     * |      WARNING |        68 |
make_layername(Begins at: 125, Ends at:145)
Clone analysis:
          File :grass/trunk/vector/v.out.ogr/main.c
          Function
OGR_list_write_drivers(Begins at: 757, Ends at:783)
CalledNBR:    |      17 |   *** |      MONSTER |        17 |
LOC:          |      27 |   *** |      MONSTER |        27 |
main(Begins at: 39, Ends at:657)
Complexity:   |      81 |    ** | BABY-MONSTER |        81 |
CalledNBR:    |     238 |    ** | BABY-MONSTER |       238 |
LOC:          |     619 |    ** | BABY-MONSTER |       619 |
mk_att(Begins at: 659, Ends at:754)
ParamNBR:     |       7 |       |           OK |         7 |
CalledNBR:    |      33 |     * |      WARNING |        33 |
LOC:          |      96 |       |           OK |        96 |
Clone analysis:
          File :grass/trunk/vector/v.out.pov/main.c
          Function
main(Begins at: 23, Ends at:210)
Complexity:   |      24 |   *** |      MONSTER |        24 |
Clone analysis:
          File :grass/trunk/vector/v.out.svg/main.c
          Function
main(Begins at: 43, Ends at:314)
LOC:          |     272 |   *** |      MONSTER |       272 |
mk_attribs(Begins at: 338, Ends at:387)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
mk_path(Begins at: 317, Ends at:335)
metrics are OK
print_escaped_for_xml(Begins at: 390, Ends at:411)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      22 |       |           OK |        22 |
Clone analysis:
          File :grass/trunk/vector/v.out.vtk/main.c
          Function
main(Begins at: 31, Ends at:204)
LOC:          |     174 |   *** |      MONSTER |       174 |
Clone analysis:
          File :grass/trunk/vector/v.overlay/main.c
          Function
main(Begins at: 28, Ends at:502)
Complexity:   |      64 |   *** |      MONSTER |        64 |
CalledNBR:    |     188 |   *** |      MONSTER |       188 |
LOC:          |     475 |   *** |      MONSTER |       475 |
Clone analysis:
          File :grass/trunk/vector/v.parallel/main.c
          Function
main(Begins at: 26, Ends at:96)
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
Clone analysis:
          File :grass/trunk/vector/v.patch/main.c
          Function
copy_records(Begins at: 388, Ends at:483)
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |      96 |    ** | BABY-MONSTER |        96 |
main(Begins at: 46, Ends at:385)
CalledNBR:    |     151 |   *** |      MONSTER |       151 |
LOC:          |     340 |   *** |      MONSTER |       340 |
max_cat(Begins at: 575, Ends at:592)
LOC:          |      18 |       |           OK |        18 |
metrics are OK
patch(Begins at: 485, Ends at:573)
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |      89 |     * |      WARNING |        89 |
Clone analysis:
          File :grass/trunk/vector/v.perturb/main.c
          Function
main(Begins at: 43, Ends at:252)
Clone analysis:
          File :grass/trunk/vector/v.proj/main.c
          Function
main(Begins at: 34, Ends at:290)
Complexity:   |      28 |   *** |      MONSTER |        28 |
Clone analysis:
          File :grass/trunk/vector/v.qcount/main.c
          Function
main(Begins at: 44, Ends at:203)
CalledNBR:    |      62 |   *** |      MONSTER |        62 |
LOC:          |     160 |   *** |      MONSTER |       160 |
Clone analysis:
          File :grass/trunk/vector/v.random/main.c
          Function
drand48(Begins at: 49, Ends at:52)
metrics are OK
main(Begins at: 57, Ends at:307)
CalledNBR:    |     121 |   *** |      MONSTER |       121 |
myrand(Begins at: 309, Ends at:312)
metrics are OK
Clone analysis:
          File :grass/trunk/vector/v.reclass/main.c
          Function
cmpcat(Begins at: 31, Ends at:41)
metrics are OK
main(Begins at: 43, Ends at:425)
CalledNBR:    |     176 |   *** |      MONSTER |       176 |
LOC:          |     383 |   *** |      MONSTER |       383 |
Clone analysis:
          File :grass/trunk/vector/v.sample/main.c
          Function
main(Begins at: 51, Ends at:294)
CalledNBR:    |     107 |   *** |      MONSTER |       107 |
LOC:          |     244 |   *** |      MONSTER |       244 |
Clone analysis:
          File :grass/trunk/vector/v.segment/main.c
          Function
find_line(Begins at: 253, Ends at:272)
main(Begins at: 31, Ends at:249)
offset_pt_90(Begins at: 278, Ends at:282)
Clone analysis:
          File :grass/trunk/vector/v.select/main.c
          Function
add_aarea(Begins at: 27, Ends at:55)
LOC:          |      29 |       |           OK |        29 |
line_overlap_area(Begins at: 59, Ends at:105)
 at least 4 values are close to an outlier please consider revising code!
main(Begins at: 107, Ends at:518)
LOC:          |     412 |   *** |      MONSTER |       412 |
Clone analysis:
          File :grass/trunk/vector/v.split/main.c
          Function
main(Begins at: 24, Ends at:190)
LOC:          |     167 |   *** |      MONSTER |       167 |
Clone analysis:
          File :grass/trunk/vector/v.support/main.c
          Function
main(Begins at: 26, Ends at:209)
CalledNBR:    |      77 |   *** |      MONSTER |        77 |
LOC:          |     184 |   *** |      MONSTER |       184 |
Clone analysis:
          File :grass/trunk/vector/v.surf.idw/main.c
          Class
Point(Begins at: 30, Ends at:34)
          Class
cell_list(Begins at: 71, Ends at:75)
          Class
list_Point(Begins at: 35, Ends at:40)
          Function
calculate_distances(Begins at: 443, Ends at:490)
calculate_distances_noindex(Begins at: 492, Ends at:529)
main(Begins at: 52, Ends at:405)
LOC:          |     354 |   *** |      MONSTER |       354 |
newpoint(Begins at: 407, Ends at:441)
LOC:          |      35 |       |           OK |        35 |
Clone analysis:
          File :grass/trunk/vector/v.surf.rst/main.c
          Function
clean_fatal_error(Begins at: 848, Ends at:875)
CalledNBR:    |      13 |     * |      WARNING |        13 |
main(Begins at: 129, Ends at:802)
Complexity:   |      99 |   *** |      MONSTER |        99 |
CalledNBR:    |     291 |   *** |      MONSTER |       291 |
LOC:          |     674 |   *** |      MONSTER |       674 |
print_tree(Begins at: 806, Ends at:844)
LOC:          |      39 |       |           OK |        39 |
Clone analysis:
          File :grass/trunk/vector/v.to.3d/main.c
          File :grass/trunk/vector/v.to.db/main.c
          Function
Clone analysis:
          File :grass/trunk/vector/v.to.points/main.c
          Function
main(Begins at: 157, Ends at:384)
CalledNBR:    |      95 |   *** |      MONSTER |        95 |
LOC:          |     228 |   *** |      MONSTER |       228 |
write_line(Begins at: 70, Ends at:155)
Complexity:   |      11 |     * |      WARNING |        11 |
write_point(Begins at: 39, Ends at:68)
Clone analysis:
          File :grass/trunk/vector/v.to.rast/main.c
          Function
main(Begins at: 27, Ends at:141)
CalledNBR:    |      42 |   *** |      MONSTER |        42 |
Clone analysis:
          File :grass/trunk/vector/v.to.rast3/main.c
          Function
main(Begins at: 26, Ends at:166)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
LOC:          |     141 |   *** |      MONSTER |       141 |
Clone analysis:
          File :grass/trunk/vector/v.transform/main.c
          Function
main(Begins at: 56, Ends at:368)
LOC:          |     313 |   *** |      MONSTER |       313 |
Clone analysis:
          File :grass/trunk/vector/v.type/main.c
          Function
main(Begins at: 27, Ends at:239)
CalledNBR:    |      49 |   *** |      MONSTER |        49 |
Clone analysis:
          File :grass/trunk/vector/v.univar/main.c
          Function
main(Begins at: 27, Ends at:467)
Complexity:   |      56 |   *** |      MONSTER |        56 |
CalledNBR:    |     120 |   *** |      MONSTER |       120 |
LOC:          |     441 |   *** |      MONSTER |       441 |
Clone analysis:
          File :grass/trunk/vector/v.vol.rst/main.c
          Function
main(Begins at: 194, Ends at:910)
CalledNBR:    |     310 |   *** |      MONSTER |       310 |
LOC:          |     717 |   *** |      MONSTER |       717 |
Clone analysis:
          File :grass/trunk/vector/v.voronoi/main.c
          File :grass/trunk/vector/v.what/main.c
          Function
main(Begins at: 37, Ends at:193)
CalledNBR:    |      51 |   *** |      MONSTER |        51 |
Clone analysis:
          File :grass/trunk/vector/v.what.rast/main.c
          Class
order(Begins at: 27, Ends at:35)
          Function
by_cat(Begins at: 387, Ends at:392)
metrics are OK
by_row(Begins at: 379, Ends at:384)
metrics are OK
main(Begins at: 42, Ends at:376)
Complexity:   |      38 |   *** |      MONSTER |        38 |
LOC:          |     335 |   *** |      MONSTER |       335 |
srch_cat(Begins at: 395, Ends at:405)
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/nviz/src/nviz_init.c
          Function
Ngetargs(Begins at: 372, Ends at:420)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      26 |       |           OK |        26 |
LOC:          |      49 |       |           OK |        49 |
Ninit(Begins at: 505, Ends at:537)
Complexity:   |       1 |     * |      WARNING |         1 |
LOC:          |      33 |     * |      WARNING |        33 |
Ninitdata(Begins at: 541, Ends at:562)
metrics are OK
make_red_yellow_ramp(Begins at: 422, Ends at:433)
ParamNBR:     |       4 |       |           OK |         4 |
metrics are OK
parse_command(Begins at: 23, Ends at:362)
set_default_wirecolors(Begins at: 472, Ends at:503)
metrics are OK
sort_surfs_mid(Begins at: 440, Ends at:470)
Clone analysis:
          File :grass/trunk/visualization/nviz2/cmd/main.c
          Function
main(Begins at: 29, Ends at:178)
CalledNBR:    |      72 |   *** |      MONSTER |        72 |
LOC:          |     150 |   *** |      MONSTER |       150 |
swap_gl(Begins at: 180, Ends at:183)
metrics are OK
Clone analysis:
          File :grass/trunk/visualization/ximgview/main.c
          Function
create_window(Begins at: 57, Ends at:100)
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      44 |     * |      WARNING |        44 |
draw(Begins at: 102, Ends at:123)
metrics are OK
dummy_handler(Begins at: 137, Ends at:139)
LOC:          |       3 |       |           OK |         3 |
metrics are OK
get_2(Begins at: 188, Ends at:195)
CalledNBR:    |       0 |     * |      WARNING |         0 |
LOC:          |       8 |     * |      WARNING |         8 |
get_4(Begins at: 197, Ends at:204)
main(Begins at: 276, Ends at:322)
LOC:          |      47 |       |           OK |        47 |
main_loop(Begins at: 141, Ends at:186)
map_file(Begins at: 248, Ends at:274)
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
read_bmp_header(Begins at: 206, Ends at:246)
Complexity:   |       9 |       |           OK |         9 |
CalledNBR:    |      14 |       |           OK |        14 |
metrics are OK
redraw(Begins at: 125, Ends at:135)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 15:37:57 EDT 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
