[GRASS-QA] GRASS QA: martinl |raster.h raster.c Gs3.c color_get.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 16:52:18 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/raster.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/display/raster.c
Function
D_cell_draw_end(Begins at: 203, Ends at:206)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
D_cell_draw_setup(Begins at: 133, Ends at:149)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
D_draw_c_raster(Begins at: 56, Ends at:59)
ParamNBR: | 3 | * | WARNING | 3 |
D_draw_cell(Begins at: 78, Ends at:81)
D_draw_d_raster(Begins at: 46, Ends at:49)
D_draw_f_raster(Begins at: 51, Ends at:54)
D_draw_raster(Begins at: 39, Ends at:44)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 6 | | OK | 6 |
D_draw_raster_RGB(Begins at: 151, Ends at:201)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 51 | | OK | 51 |
draw_cell(Begins at: 83, Ends at:116)
ParamNBR: | 4 | *** | MONSTER | 4 |
CalledNBR: | 9 | * | WARNING | 9 |
LOC: | 34 | * | WARNING | 34 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/ogsf/Gs3.c
Function
Gs_build_256lookup(Begins at: 623, Ends at:670)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 48 | * | WARNING | 48 |
at least 3 values are close to an outlier please consider revising code!
Gs_distance(Begins at: 84, Ends at:94)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
metrics are OK
Gs_get_cat_label(Begins at: 819, Ends at:884)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 66 | * | WARNING | 66 |
Conclusion: | this function is a BABY-MONSTER |
Gs_load_3dview(Begins at: 996, Ends at:1121)
Complexity: | 16 | * | WARNING | 16 |
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 126 | * | WARNING | 126 |
at least 4 values are close to an outlier please consider revising code!
Gs_loadmap_as_bitmap(Begins at: 555, Ends at:609)
CalledNBR: | 21 | ** | BABY-MONSTER | 21 |
LOC: | 55 | * | WARNING | 55 |
Gs_loadmap_as_char(Begins at: 446, Ends at:534)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 23 | * | WARNING | 23 |
LOC: | 89 | * | WARNING | 89 |
Gs_loadmap_as_float(Begins at: 114, Ends at:166)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 53 | * | WARNING | 53 |
Gs_loadmap_as_int(Begins at: 188, Ends at:239)
CalledNBR: | 19 | ** | BABY-MONSTER | 19 |
LOC: | 52 | * | WARNING | 52 |
Gs_loadmap_as_short(Begins at: 332, Ends at:418)
Complexity: | 10 | ** | BABY-MONSTER | 10 |
CalledNBR: | 25 | * | WARNING | 25 |
LOC: | 87 | ** | BABY-MONSTER | 87 |
Gs_numtype(Begins at: 250, Ends at:310)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 61 | * | WARNING | 61 |
at least 2 values are close to an outlier please consider revising code!
Gs_pack_colors(Begins at: 683, Ends at:734)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 17 | * | WARNING | 17 |
Gs_pack_colors_float(Begins at: 750, Ends at:804)
Gs_save_3dview(Begins at: 898, Ends at:983)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 86 | * | WARNING | 86 |
Gs_update_attrange(Begins at: 1132, Ends at:1242)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 111 | | OK | 111 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/raster/color_get.c
File :grass/trunk/lib/raster/color_look.c
File :grass/trunk/lib/raster/get_row_colr.c
File :grass/trunk/raster/r.mapcalc/map.c
Class
map(Begins at: 49, Ends at:65)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
row_cache(Begins at: 42, Ends at:47)
Class
sub_cache(Begins at: 35, Ends at:40)
Function
cache_get(Begins at: 189, Ends at:193)
Complexity: | 1 | * | WARNING | 1 |
LOC: | 5 | | OK | 5 |
cache_get_raw(Begins at: 130, Ends at:187)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 58 | | OK | 58 |
metrics are OK
cache_release(Begins at: 109, Ends at:128)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 20 | | OK | 20 |
metrics are OK
cache_setup(Begins at: 100, Ends at:107)
CalledNBR: | 0 | | OK | 0 |
LOC: | 8 | | OK | 8 |
metrics are OK
cache_sub_init(Begins at: 86, Ends at:98)
LOC: | 13 | | OK | 13 |
metrics are OK
check_output_map(Begins at: 651, Ends at:654)
metrics are OK
close_map(Begins at: 426, Ends at:454)
CalledNBR: | 8 | | OK | 8 |
LOC: | 29 | | OK | 29 |
metrics are OK
close_maps(Begins at: 635, Ends at:647)
Complexity: | 2 | * | WARNING | 2 |
close_output_map(Begins at: 673, Ends at:677)
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 3 | * | WARNING | 3 |
compare_ints(Begins at: 197, Ends at:200)
metrics are OK
copy_cats(Begins at: 686, Ends at:696)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
copy_colors(Begins at: 698, Ends at:708)
copy_history(Begins at: 710, Ends at:719)
LOC: | 10 | | OK | 10 |
metrics are OK
create_history(Begins at: 721, Ends at:761)
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 41 | | OK | 41 |
get_map_row(Begins at: 593, Ends at:633)
ParamNBR: | 7 | * | WARNING | 7 |
CalledNBR: | 15 | | OK | 15 |
init_cats(Begins at: 211, Ends at:222)
LOC: | 12 | | OK | 12 |
init_colors(Begins at: 202, Ends at:209)
metrics are OK
map_type(Begins at: 458, Ends at:484)
Complexity: | 11 | | OK | 11 |
LOC: | 27 | | OK | 27 |
metrics are OK
open_map(Begins at: 486, Ends at:579)
Complexity: | 27 | | OK | 27 |
CalledNBR: | 19 | | OK | 19 |
LOC: | 94 | | OK | 94 |
metrics are OK
open_output_map(Begins at: 656, Ends at:665)
metrics are OK
put_map_row(Begins at: 667, Ends at:671)
LOC: | 5 | * | WARNING | 5 |
read_map(Begins at: 387, Ends at:424)
Complexity: | 12 | | OK | 12 |
ParamNBR: | 5 | | OK | 5 |
LOC: | 38 | | OK | 38 |
metrics are OK
read_row(Begins at: 365, Ends at:369)
setup_map(Begins at: 371, Ends at:385)
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 15 | * | WARNING | 15 |
setup_maps(Begins at: 581, Ends at:591)
metrics are OK
setup_region(Begins at: 24, Ends at:31)
translate_from_cats(Begins at: 300, Ends at:363)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 64 | | OK | 64 |
metrics are OK
translate_from_colors(Begins at: 224, Ends at:275)
Complexity: | 17 | | OK | 17 |
LOC: | 52 | | OK | 52 |
metrics are OK
unopen_output_map(Begins at: 679, Ends at:682)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 1 | * | WARNING | 1 |
LOC: | 4 | ** | BABY-MONSTER | 4 |
Clone analysis:
File :grass/trunk/raster/r.mapcalc/map3.c
Function
check_output_map(Begins at: 569, Ends at:572)
metrics are OK
close_map(Begins at: 361, Ends at:380)
metrics are OK
close_maps(Begins at: 557, Ends at:565)
LOC: | 9 | | OK | 9 |
metrics are OK
close_output_map(Begins at: 605, Ends at:611)
LOC: | 7 | | OK | 7 |
metrics are OK
compare_ints(Begins at: 160, Ends at:163)
metrics are OK
copy_cats(Begins at: 620, Ends at:630)
metrics are OK
copy_colors(Begins at: 632, Ends at:642)
metrics are OK
copy_history(Begins at: 644, Ends at:646)
LOC: | 3 | | OK | 3 |
metrics are OK
create_history(Begins at: 648, Ends at:650)
metrics are OK
get_map_row(Begins at: 523, Ends at:555)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
LOC: | 33 | | OK | 33 |
init_cats(Begins at: 183, Ends at:194)
metrics are OK
init_colors(Begins at: 165, Ends at:181)
metrics are OK
map_type(Begins at: 384, Ends at:420)
Complexity: | 12 | * | WARNING | 12 |
LOC: | 37 | | OK | 37 |
open_map(Begins at: 422, Ends at:513)
Complexity: | 26 | * | WARNING | 26 |
LOC: | 92 | | OK | 92 |
open_output_map(Begins at: 574, Ends at:596)
Complexity: | 3 | *** | MONSTER | 3 |
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 23 | ** | BABY-MONSTER | 23 |
put_map_row(Begins at: 598, Ends at:603)
metrics are OK
read_map(Begins at: 324, Ends at:359)
ParamNBR: | 6 | * | WARNING | 6 |
LOC: | 36 | | OK | 36 |
read_row(Begins at: 66, Ends at:105)
ParamNBR: | 5 | ** | BABY-MONSTER | 5 |
LOC: | 40 | | OK | 40 |
setup_map(Begins at: 320, Ends at:322)
setup_maps(Begins at: 515, Ends at:521)
metrics are OK
setup_region(Begins at: 20, Ends at:28)
metrics are OK
translate_from_cats(Begins at: 263, Ends at:318)
LOC: | 56 | | OK | 56 |
metrics are OK
translate_from_colors(Begins at: 196, Ends at:238)
Complexity: | 17 | * | WARNING | 17 |
LOC: | 43 | * | WARNING | 43 |
unopen_output_map(Begins at: 613, Ends at:616)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
LOC: | 4 | * | WARNING | 4 |
write_row(Begins at: 107, Ends at:156)
Complexity: | 14 | | OK | 14 |
LOC: | 50 | | OK | 50 |
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.out.mpeg/main.c
Function
gee_wildfiles(Begins at: 378, Ends at:427)
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 50 | * | WARNING | 50 |
load_files(Begins at: 224, Ends at:353)
CalledNBR: | 42 | | OK | 42 |
LOC: | 130 | | OK | 130 |
main(Begins at: 74, Ends at:221)
CalledNBR: | 35 | | OK | 35 |
LOC: | 148 | | OK | 148 |
metrics are OK
parse_command(Begins at: 431, Ends at:464)
Complexity: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 5 | *** | MONSTER | 5 |
LOC: | 34 | ** | BABY-MONSTER | 34 |
use_r_out(Begins at: 356, Ends at:374)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 19 | *** | MONSTER | 19 |
Clone analysis:
File :grass/trunk/raster/r.out.png/main.c
Function
main(Begins at: 48, Ends at:321)
Complexity: | 19 | ** | BABY-MONSTER | 19 |
CalledNBR: | 76 | *** | MONSTER | 76 |
LOC: | 274 | *** | MONSTER | 274 |
Clone analysis:
File :grass/trunk/raster/r.out.ppm/main.c
Function
main(Begins at: 32, Ends at:230)
Complexity: | 24 | *** | MONSTER | 24 |
CalledNBR: | 78 | *** | MONSTER | 78 |
LOC: | 199 | *** | MONSTER | 199 |
Clone analysis:
File :grass/trunk/raster/r.out.ppm3/main.c
Class
band(Begins at: 27, Ends at:36)
Function
main(Begins at: 40, Ends at:197)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 63 | *** | MONSTER | 63 |
LOC: | 158 | *** | MONSTER | 158 |
Clone analysis:
File :grass/trunk/raster/r.out.vrml/put_grid.c
Function
vrml_put_grid(Begins at: 10, Ends at:160)
ParamNBR: | 9 | *** | MONSTER | 9 |
CalledNBR: | 59 | *** | MONSTER | 59 |
LOC: | 151 | *** | MONSTER | 151 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 16:40:05 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
