[GRASS-QA] GRASS QA: martinl |Gs3.c main.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Tue Jun 30 16:57:01 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/ogsf/Gs3.c
Function
Gs_build_256lookup(Begins at: 623, Ends at:670)
| New Metrics |Old Metrics|
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 48 | * | WARNING | 48 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Gs_distance(Begins at: 84, Ends at:94)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
Gs_get_cat_label(Begins at: 819, Ends at:884)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 66 | * | WARNING | 66 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Gs_load_3dview(Begins at: 996, Ends at:1121)
Complexity: | 16 | * | WARNING | 16 |
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 126 | * | WARNING | 126 |
at least 4 values are close to an outlier please consider revising code!
Gs_loadmap_as_bitmap(Begins at: 555, Ends at:609)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 21 | ** | BABY-MONSTER | 21 |
LOC: | 55 | * | WARNING | 55 |
Gs_loadmap_as_char(Begins at: 446, Ends at:534)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 23 | * | WARNING | 23 |
LOC: | 89 | * | WARNING | 89 |
Gs_loadmap_as_float(Begins at: 114, Ends at:166)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 53 | * | WARNING | 53 |
Gs_loadmap_as_int(Begins at: 188, Ends at:239)
CalledNBR: | 19 | ** | BABY-MONSTER | 19 |
LOC: | 52 | * | WARNING | 52 |
Gs_loadmap_as_short(Begins at: 332, Ends at:418)
Complexity: | 10 | ** | BABY-MONSTER | 10 |
CalledNBR: | 25 | * | WARNING | 25 |
LOC: | 87 | ** | BABY-MONSTER | 87 |
Gs_numtype(Begins at: 250, Ends at:310)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 61 | * | WARNING | 61 |
at least 2 values are close to an outlier please consider revising code!
Gs_pack_colors(Begins at: 683, Ends at:734)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 17 | * | WARNING | 17 |
Gs_pack_colors_float(Begins at: 750, Ends at:804)
Gs_save_3dview(Begins at: 898, Ends at:983)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 86 | * | WARNING | 86 |
Gs_update_attrange(Begins at: 1132, Ends at:1242)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 111 | | OK | 111 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.colors.out/main.c
Function
main(Begins at: 42, Ends at:143)
Complexity: | 9 | | OK | 9 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 34 | | OK | 34 |
LOC: | 102 | | OK | 102 |
at least 1 values are close to an outlier please consider revising code!
write_rule(Begins at: 27, Ends at:40)
Complexity: | 3 | * | WARNING | 3 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 2 | ** | BABY-MONSTER | 2 |
LOC: | 14 | ** | BABY-MONSTER | 14 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 16:44:49 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
