[GRASS-QA] GRASS QA: martinl |do_graph.c main.c color.c display.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Tue Jun 30 18:03:50 EDT 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.graph/do_graph.c
Function
check_alloc(Begins at: 254, Ends at:277)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
do_color(Begins at: 97, Ends at:127)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 31 | | OK | 31 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
do_draw(Begins at: 49, Ends at:75)
CalledNBR: | 6 | | OK | 6 |
LOC: | 27 | | OK | 27 |
metrics are OK
do_icon(Begins at: 279, Ends at:328)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 50 | * | WARNING | 50 |
at least 3 values are close to an outlier please consider revising code!
do_linewidth(Begins at: 129, Ends at:142)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 14 | | OK | 14 |
metrics are OK
do_move(Begins at: 77, Ends at:95)
LOC: | 19 | | OK | 19 |
metrics are OK
do_poly(Begins at: 145, Ends at:200)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 56 | * | WARNING | 56 |
do_rotate(Begins at: 228, Ends at:239)
LOC: | 12 | | OK | 12 |
metrics are OK
do_size(Begins at: 202, Ends at:226)
CalledNBR: | 3 | | OK | 3 |
LOC: | 25 | | OK | 25 |
metrics are OK
do_symbol(Begins at: 330, Ends at:433)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 104 | ** | BABY-MONSTER | 104 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
do_text(Begins at: 241, Ends at:252)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 1 | | OK | 1 |
metrics are OK
set_graph_stuff(Begins at: 25, Ends at:37)
CalledNBR: | 0 | | OK | 0 |
LOC: | 13 | | OK | 13 |
metrics are OK
set_last_color(Begins at: 436, Ends at:449)
ParamNBR: | 4 | * | WARNING | 4 |
set_text_size(Begins at: 39, Ends at:47)
LOC: | 9 | | OK | 9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/display/d.graph/main.c
Function
main(Begins at: 47, Ends at:139)
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 93 | ** | BABY-MONSTER | 93 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/display/d.labels/color.c
Function
RGBA_has_color(Begins at: 78, Ends at:84)
LOC: | 7 | | OK | 7 |
metrics are OK
set_RGBA_from_components(Begins at: 23, Ends at:32)
Complexity: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
set_RGBA_from_str(Begins at: 50, Ends at:69)
LOC: | 20 | | OK | 20 |
metrics are OK
set_color_from_RGBA(Begins at: 88, Ends at:98)
CalledNBR: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
unset_RGBA(Begins at: 72, Ends at:75)
LOC: | 4 | | OK | 4 |
metrics are OK
Clone analysis:
File :grass/trunk/display/d.rast/display.c
Function
cell_draw(Begins at: 46, Ends at:92)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 47 | * | WARNING | 47 |
display(Begins at: 12, Ends at:44)
LOC: | 33 | | OK | 33 |
mask_raster_array(Begins at: 94, Ends at:103)
CalledNBR: | 2 | | OK | 2 |
Clone analysis:
File :grass/trunk/include/colors.h
Class
color_name(Begins at: 38, Ends at:42)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
color_rgb(Begins at: 33, Ends at:36)
Clone analysis:
File :grass/trunk/lib/nviz/nviz.c
Function
Nviz_color_from_str(Begins at: 71, Ends at:83)
metrics are OK
Nviz_init_data(Begins at: 27, Ends at:49)
LOC: | 23 | | OK | 23 |
metrics are OK
Nviz_set_bgcolor(Begins at: 57, Ends at:62)
LOC: | 6 | | OK | 6 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/raster/color_hist.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/ps/ps.map/do_labels.c
Function
do_label(Begins at: 78, Ends at:372)
Complexity: | 58 | *** | MONSTER | 58 |
CalledNBR: | 77 | *** | MONSTER | 77 |
LOC: | 295 | *** | MONSTER | 295 |
do_labels(Begins at: 24, Ends at:76)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 53 | * | WARNING | 53 |
Clone analysis:
File :grass/trunk/ps/ps.map/main.c
Function
main(Begins at: 88, Ends at:753)
Complexity: | 102 | *** | MONSTER | 102 |
CalledNBR: | 220 | *** | MONSTER | 220 |
LOC: | 666 | *** | MONSTER | 666 |
Clone analysis:
File :grass/trunk/ps/ps.map/ps_vareas.c
Function
PS_vareas_plot(Begins at: 129, Ends at:271)
Complexity: | 19 | | OK | 19 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 42 | | OK | 42 |
LOC: | 143 | | OK | 143 |
construct_path(Begins at: 18, Ends at:52)
Complexity: | 5 | * | WARNING | 5 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 8 | * | WARNING | 8 |
LOC: | 35 | | OK | 35 |
plot_area(Begins at: 55, Ends at:83)
Complexity: | 6 | ** | BABY-MONSTER | 6 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 11 | *** | MONSTER | 11 |
LOC: | 29 | *** | MONSTER | 29 |
set_ps_color_rgbcol_varea(Begins at: 86, Ends at:126)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 41 | | OK | 41 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/ps/ps.map/ps_vlines.c
Function
PS_vlines_plot(Begins at: 18, Ends at:206)
Complexity: | 27 | *** | MONSTER | 27 |
CalledNBR: | 49 | *** | MONSTER | 49 |
LOC: | 189 | *** | MONSTER | 189 |
Clone analysis:
File :grass/trunk/ps/ps.map/ps_vpoints.c
Function
PS_vpoints_plot(Begins at: 18, Ends at:286)
Complexity: | 40 | *** | MONSTER | 40 |
CalledNBR: | 65 | *** | MONSTER | 65 |
LOC: | 269 | *** | MONSTER | 269 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_border.c
Function
read_border(Begins at: 20, Ends at:82)
CalledNBR: | 7 | | OK | 7 |
LOC: | 63 | * | WARNING | 63 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_plt.c
Function
add_to_plfile(Begins at: 337, Ends at:355)
metrics are OK
read_eps(Begins at: 107, Ends at:178)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 72 | * | WARNING | 72 |
read_line(Begins at: 180, Ends at:247)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 68 | * | WARNING | 68 |
at least 4 values are close to an outlier please consider revising code!
read_point(Begins at: 7, Ends at:105)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
read_rectangle(Begins at: 249, Ends at:335)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 87 | * | WARNING | 87 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_text.c
Function
read_text(Begins at: 43, Ends at:319)
Complexity: | 55 | *** | MONSTER | 55 |
CalledNBR: | 84 | *** | MONSTER | 84 |
LOC: | 277 | *** | MONSTER | 277 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_vareas.c
Function
read_vareas(Begins at: 34, Ends at:203)
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 170 | *** | MONSTER | 170 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_vlines.c
Function
read_vlines(Begins at: 39, Ends at:287)
Complexity: | 46 | *** | MONSTER | 46 |
LOC: | 249 | *** | MONSTER | 249 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_vpoints.c
Function
read_vpoints(Begins at: 40, Ends at:283)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 73 | *** | MONSTER | 73 |
LOC: | 244 | *** | MONSTER | 244 |
Clone analysis:
File :grass/trunk/ps/ps.map/r_wind.c
Function
read_wind(Begins at: 14, Ends at:103)
LOC: | 90 | * | WARNING | 90 |
Clone analysis:
File :grass/trunk/vector/v.to.rast/support.c
Class
My_color_rule(Begins at: 104, Ends at:111)
Class
My_labels_rule(Begins at: 253, Ends at:258)
Function
update_cats(Begins at: 72, Ends at:84)
metrics are OK
update_colors(Begins at: 42, Ends at:54)
metrics are OK
update_dbcolors(Begins at: 86, Ends at:230)
CalledNBR: | 38 | *** | MONSTER | 38 |
LOC: | 145 | *** | MONSTER | 145 |
update_fcolors(Begins at: 57, Ends at:69)
metrics are OK
update_hist(Begins at: 17, Ends at:39)
update_labels(Begins at: 234, Ends at:501)
Complexity: | 35 | *** | MONSTER | 35 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 97 | *** | MONSTER | 97 |
LOC: | 268 | *** | MONSTER | 268 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Jun 30 17:51:36 EDT 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
