[GRASS-QA] GRASS QA: mmetz |plus_area.c plus_line.c struct_alloc.c |
	28 clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Tue Mar 17 10:50:58 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/diglib/plus_area.c
          Function
dig_add_area(Begins at: 161, Ends at:230)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      70 |     * |      WARNING |        70 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
dig_add_isle(Begins at: 610, Ends at:684)
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      75 |     * |      WARNING |        75 |
dig_angle_next_line(Begins at: 461, Ends at:538)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      78 |     * |      WARNING |        78 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
dig_area_add_isle(Begins at: 241, Ends at:267)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      27 |       |           OK |        27 |
 at least 1 values are close to an outlier please consider revising code!
dig_area_del_isle(Begins at: 278, Ends at:309)
Complexity:   |       6 |     * |      WARNING |         6 |
LOC:          |      32 |       |           OK |        32 |
 at least 2 values are close to an outlier please consider revising code!
dig_area_set_box(Begins at: 429, Ends at:443)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      15 |       |           OK |        15 |
dig_build_area_with_line(Begins at: 48, Ends at:145)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      19 |     * |      WARNING |        19 |
LOC:          |      98 |    ** | BABY-MONSTER |        98 |
dig_del_area(Begins at: 329, Ends at:418)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      15 |     * |      WARNING |        15 |
LOC:          |      90 |     * |      WARNING |        90 |
 at least 3 values are close to an outlier please consider revising code!
dig_del_isle(Begins at: 722, Ends at:762)
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      41 |       |           OK |        41 |
dig_isle_set_box(Begins at: 696, Ends at:710)
dig_node_angle_check(Begins at: 554, Ends at:593)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      40 |       |           OK |        40 |
Clone analysis:
This file has 6 potentially cloned functions:
  dig_line_set_box  dig_line_get_box  dig_area_set_box  dig_line_set_box  dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_area_set_box are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c  dig_isle_set_box
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c  dig_line_set_box
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c  dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c clones of dig_isle_set_box are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_area.c  dig_area_set_box
          File :grass/trunk/lib/vector/diglib/plus_line.c
          Function
dig_add_line(Begins at: 31, Ends at:131)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |      22 |     * |      WARNING |        22 |
LOC:          |     101 |    ** | BABY-MONSTER |       101 |
dig_del_line(Begins at: 148, Ends at:213)
Complexity:   |      12 |     * |      WARNING |        12 |
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      66 |     * |      WARNING |        66 |
dig_line_get_area(Begins at: 226, Ends at:246)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      21 |       |           OK |        21 |
dig_line_get_box(Begins at: 308, Ends at:322)
dig_line_set_area(Begins at: 258, Ends at:272)
dig_line_set_box(Begins at: 283, Ends at:297)
Clone analysis:
  dig_isle_set_box  dig_line_set_box  dig_area_set_box  dig_isle_set_box  dig_line_get_box
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c clones of dig_line_get_box are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/plus_line.c clones of dig_line_set_box are:
          File :grass/trunk/lib/vector/diglib/struct_alloc.c
          Function
dig_alloc_area(Begins at: 189, Ends at:208)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |      20 |       |           OK |        20 |
Conclusion:   | this function is a            OK           |
metrics are OK
dig_alloc_areas(Begins at: 149, Ends at:163)
metrics are OK
dig_alloc_cats(Begins at: 272, Ends at:296)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
dig_alloc_isle(Begins at: 211, Ends at:226)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
dig_alloc_isles(Begins at: 171, Ends at:186)
CalledNBR:    |       3 |       |           OK |         3 |
metrics are OK
dig_alloc_line(Begins at: 110, Ends at:119)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
dig_alloc_lines(Begins at: 127, Ends at:141)
metrics are OK
dig_alloc_node(Begins at: 40, Ends at:54)
metrics are OK
dig_alloc_nodes(Begins at: 93, Ends at:107)
metrics are OK
dig_alloc_points(Begins at: 232, Ends at:266)
LOC:          |      35 |       |           OK |        35 |
metrics are OK
dig_area_alloc_isle(Begins at: 325, Ends at:340)
metrics are OK
dig_area_alloc_line(Begins at: 303, Ends at:318)
metrics are OK
dig_isle_alloc_line(Begins at: 348, Ends at:364)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
dig_node_alloc_line(Begins at: 63, Ends at:84)
LOC:          |      22 |       |           OK |        22 |
metrics are OK
dig_out_of_memory(Begins at: 369, Ends at:373)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
Clone analysis:
This file has 16 potentially cloned functions:
  dig_alloc_lines  dig_area_alloc_line  dig_alloc_node  dig_isle_alloc_line  dig_alloc_nodes  dig_alloc_areas  dig_area_alloc_line  dig_alloc_isle  dig_alloc_lines  dig_alloc_areas  dig_area_alloc_line  dig_alloc_nodes  dig_alloc_lines  dig_alloc_areas  dig_alloc_isles
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_areas are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_alloc_nodes
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_alloc_lines
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_area_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isle are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_isles are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_isle_alloc_line
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_lines are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_alloc_areas
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_node are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_alloc_isle
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_alloc_nodes are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_area_alloc_line are:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c clones of dig_isle_alloc_line are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/struct_alloc.c  dig_alloc_isles
____________________________________________
Threshold grass key metrics values at Tue Mar 17 09:59:05 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
