[GRASS-QA] GRASS QA: mmetz |poly.c build_nat.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Wed Mar 18 15:19:49 EDT 2009
Hello mmetz,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/vector/diglib/poly.c
Function
dig_find_area_poly(Begins at: 93, Ends at:116)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
dig_get_poly_points(Begins at: 34, Ends at:86)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 53 | * | WARNING | 53 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/vector/Vlib/build_nat.c
Function
Vect_attach_centroids(Begins at: 332, Ends at:413)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 82 | * | WARNING | 82 |
at least 2 values are close to an outlier please consider revising code!
Vect_attach_isle(Begins at: 261, Ends at:288)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 28 | | OK | 28 |
metrics are OK
Vect_attach_isles(Begins at: 298, Ends at:322)
LOC: | 25 | | OK | 25 |
metrics are OK
Vect_build_line_area(Begins at: 40, Ends at:118)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 79 | * | WARNING | 79 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Vect_build_nat(Begins at: 425, Ends at:677)
Complexity: | 42 | *** | MONSTER | 42 |
CalledNBR: | 59 | *** | MONSTER | 59 |
LOC: | 253 | *** | MONSTER | 253 |
Conclusion: | this function is a MONSTER |
Vect_isle_find_area(Begins at: 129, Ends at:251)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 27 | ** | BABY-MONSTER | 27 |
LOC: | 123 | ** | BABY-MONSTER | 123 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Mar 18 14:28:11 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
