[GRASS-QA] GRASS QA: martinl |vector.h header.c print.c | no clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Nov 5 18:28:20 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/vector.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/header.c
Function
Vect__read_head(Begins at: 122, Ends at:192)
| New Metrics |Old Metrics|
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 62 | *** | MONSTER | 62 |
LOC: | 71 | * | WARNING | 71 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Vect__write_head(Begins at: 86, Ends at:112)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 24 | ** | BABY-MONSTER | 24 |
LOC: | 27 | | OK | 27 |
Conclusion: | this function is a BABY-MONSTER |
Vect_get_comment(Begins at: 437, Ends at:440)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
Vect_get_date(Begins at: 303, Ends at:306)
metrics are OK
Vect_get_full_name(Begins at: 225, Ends at:232)
CalledNBR: | 4 | | OK | 4 |
LOC: | 8 | | OK | 8 |
metrics are OK
Vect_get_map_date(Begins at: 384, Ends at:387)
metrics are OK
Vect_get_map_name(Begins at: 357, Ends at:360)
metrics are OK
Vect_get_mapset(Begins at: 213, Ends at:216)
metrics are OK
Vect_get_name(Begins at: 201, Ends at:204)
metrics are OK
Vect_get_organization(Begins at: 270, Ends at:273)
metrics are OK
Vect_get_person(Begins at: 330, Ends at:333)
metrics are OK
Vect_get_proj(Begins at: 479, Ends at:482)
metrics are OK
Vect_get_proj_name(Begins at: 497, Ends at:512)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_get_scale(Begins at: 410, Ends at:413)
metrics are OK
Vect_get_thresh(Begins at: 536, Ends at:540)
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
metrics are OK
Vect_get_zone(Begins at: 464, Ends at:467)
metrics are OK
Vect_is_3d(Begins at: 242, Ends at:245)
metrics are OK
Vect_print_header(Begins at: 37, Ends at:46)
CalledNBR: | 9 | | OK | 9 |
LOC: | 10 | | OK | 10 |
metrics are OK
Vect_read_header(Begins at: 56, Ends at:60)
metrics are OK
Vect_set_comment(Begins at: 423, Ends at:428)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 6 | | OK | 6 |
metrics are OK
Vect_set_date(Begins at: 286, Ends at:291)
metrics are OK
Vect_set_map_date(Begins at: 370, Ends at:375)
metrics are OK
Vect_set_map_name(Begins at: 343, Ends at:348)
metrics are OK
Vect_set_organization(Begins at: 255, Ends at:261)
LOC: | 7 | | OK | 7 |
metrics are OK
Vect_set_person(Begins at: 316, Ends at:321)
metrics are OK
Vect_set_scale(Begins at: 397, Ends at:401)
metrics are OK
Vect_set_thresh(Begins at: 522, Ends at:527)
metrics are OK
Vect_set_zone(Begins at: 450, Ends at:454)
metrics are OK
Vect_write_header(Begins at: 70, Ends at:75)
metrics are OK
lookup(Begins at: 544, Ends at:550)
ParamNBR: | 4 | * | WARNING | 4 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.info/print.c
____________________________________________
Threshold grass key metrics values at Thu Nov 05 18:28:20 EST 2009 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
