[GRASS-QA] GRASS QA: martinl |vector.h find_file.c close.c field.c
	...| no clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Thu Nov  5 18:35:33 EST 2009
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/include/vector.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/gis/find_file.c
          Function
G_find_file(Begins at: 140, Ends at:143)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
G_find_file2(Begins at: 172, Ends at:175)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_find_file2_misc(Begins at: 177, Ends at:182)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |       6 |       |           OK |         6 |
G_find_file_misc(Begins at: 145, Ends at:149)
LOC:          |       5 |       |           OK |         5 |
find_file(Begins at: 5, Ends at:86)
Complexity:   |      14 |       |           OK |        14 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      82 |       |           OK |        82 |
find_file1(Begins at: 90, Ends at:113)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      24 |       |           OK |        24 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/vector/Vlib/close.c
          Function
Vect_close(Begins at: 64, Ends at:148)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      33 |    ** | BABY-MONSTER |        33 |
LOC:          |      85 |     * |      WARNING |        85 |
clo_dummy(Begins at: 30, Ends at:33)
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       0 |       |           OK |         0 |
Conclusion:   | this function is a            OK           |
metrics are OK
format(Begins at: 36, Ends at:40)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/field.c
          Function
Vect_add_dblink(Begins at: 209, Ends at:261)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      53 |     * |      WARNING |        53 |
Vect_check_dblink(Begins at: 181, Ends at:193)
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
Vect_default_field_info(Begins at: 273, Ends at:347)
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      75 |     * |      WARNING |        75 |
Vect_get_dblink(Begins at: 360, Ends at:386)
CalledNBR:    |      10 |     * |      WARNING |        10 |
LOC:          |      27 |       |           OK |        27 |
Vect_get_field(Begins at: 400, Ends at:415)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Vect_map_add_dblink(Begins at: 81, Ends at:110)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
Vect_map_check_dblink(Begins at: 167, Ends at:170)
metrics are OK
Vect_map_del_dblink(Begins at: 121, Ends at:156)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      36 |       |           OK |        36 |
Vect_new_dblinks_struct(Begins at: 41, Ends at:53)
Complexity:   |       2 |       |           OK |         2 |
metrics are OK
Vect_read_dblinks(Begins at: 427, Ends at:657)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      78 |   *** |      MONSTER |        78 |
LOC:          |     231 |   *** |      MONSTER |       231 |
Conclusion:   | this function is a       MONSTER           |
Vect_reset_dblinks(Begins at: 62, Ends at:65)
metrics are OK
Vect_set_db_updated(Begins at: 771, Ends at:778)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Vect_subst_var(Begins at: 718, Ends at:758)
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      41 |       |           OK |        41 |
Vect_write_dblinks(Begins at: 667, Ends at:708)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      42 |     * |      WARNING |        42 |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/lib/vector/Vlib/open.c
          Function
Vect__open_old(Begins at: 124, Ends at:396)
Complexity:   |      31 |       |           OK |        31 |
ParamNBR:     |       5 |       |           OK |         5 |
CalledNBR:    |     102 |       |           OK |       102 |
LOC:          |     273 |       |           OK |       273 |
metrics are OK
Vect_coor_info(Begins at: 608, Ends at:646)
Complexity:   |       6 |   *** |      MONSTER |         6 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      11 |   *** |      MONSTER |        11 |
LOC:          |      39 |   *** |      MONSTER |        39 |
Vect_maptype_info(Begins at: 656, Ends at:673)
Complexity:   |       5 |     * |      WARNING |         5 |
CalledNBR:    |       4 |     * |      WARNING |         4 |
LOC:          |      18 |       |           OK |        18 |
Vect_open_new(Begins at: 514, Ends at:597)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      43 |       |           OK |        43 |
LOC:          |      84 |       |           OK |        84 |
metrics are OK
Vect_open_old(Begins at: 410, Ends at:413)
Complexity:   |       1 |     * |      WARNING |         1 |
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
Vect_open_old_head(Begins at: 464, Ends at:468)
Vect_open_spatial_index(Begins at: 767, Ends at:832)
ParamNBR:     |       1 |     * |      WARNING |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      66 |       |           OK |        66 |
Vect_open_topo(Begins at: 686, Ends at:757)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      72 |     * |      WARNING |        72 |
Vect_open_update(Begins at: 427, Ends at:449)
Complexity:   |       2 |     * |      WARNING |         2 |
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      23 |     * |      WARNING |        23 |
 at least 3 values are close to an outlier please consider revising code!
Vect_open_update_head(Begins at: 482, Ends at:502)
LOC:          |      21 |       |           OK |        21 |
Vect_set_open_level(Begins at: 96, Ends at:107)
LOC:          |      12 |       |           OK |        12 |
fatal_error(Begins at: 59, Ends at:71)
metrics are OK
format(Begins at: 38, Ends at:42)
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Nov 05 18:35:33 EST 2009 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
