[GRASS-QA] GRASS QA: wegmann |local_proto.h func.c frag.c main.c |
no clones | 1 monsters |13 warnings
soccerlab.info at gmail.com
Tue Aug 10 14:43:22 EDT 2010
Hello wegmann,
here's a report on your recent grass-SVN change for the revision : 42949
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.pi/r.pi.index/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.pi/r.pi.index/func.c
Function
dist(Begins at: 202, Ends at:207)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a OK |
metrics are OK
f_area(Begins at: 10, Ends at:22)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
f_area_perim_ratio(Begins at: 160, Ends at:179)
Complexity: | 4 | | OK | 4 |
LOC: | 20 | | OK | 20 |
f_asymmetry(Begins at: 125, Ends at:158)
CalledNBR: | 2 | | OK | 2 |
LOC: | 34 | | OK | 34 |
f_borderindex(Begins at: 65, Ends at:93)
LOC: | 29 | | OK | 29 |
f_compactness(Begins at: 95, Ends at:123)
f_frac_dim(Begins at: 181, Ends at:200)
CalledNBR: | 3 | | OK | 3 |
f_nearest_dist(Begins at: 231, Ends at:252)
Complexity: | 6 | | OK | 6 |
LOC: | 22 | | OK | 22 |
f_perim(Begins at: 24, Ends at:42)
LOC: | 19 | | OK | 19 |
f_proximity(Begins at: 254, Ends at:264)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 11 | | OK | 11 |
f_shapeindex(Begins at: 44, Ends at:63)
min_dist(Begins at: 209, Ends at:229)
LOC: | 21 | | OK | 21 |
Clone analysis:
This file does not contain cloned functions
File :/raster/r.pi/r.pi.index/frag.c
Function
getNeighbors(Begins at: 16, Ends at:52)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 37 | | OK | 37 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
writeFrag(Begins at: 54, Ends at:108)
CalledNBR: | 7 | | OK | 7 |
LOC: | 55 | | OK | 55 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :/raster/r.pi/r.pi.index/main.c
Class
menu(Begins at: 18, Ends at:23)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Function
main(Begins at: 39, Ends at:306)
Complexity: | 31 | ** | BABY-MONSTER | 31 |
CalledNBR: | 82 | *** | MONSTER | 82 |
LOC: | 268 | *** | MONSTER | 268 |
Conclusion: | this function is a MONSTER |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Aug 10 14:43:21 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
