[GRASS-QA] GRASS QA: wegmann |divr_cats.c null_cats.c readcell.c
	local_proto.h ...| no clones | 3 monsters |16 warnings
    soccerlab.info at gmail.com
    Tue Aug 10 14:57:40 EDT 2010
Hello wegmann,
here's a report on your recent grass-SVN change for the revision : 42954
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.pi/r.pi.corrwin/divr_cats.c
          Function
divr_cats(Begins at: 3, Ends at:9)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.pi/r.pi.corrwin/null_cats.c
          Function
null_cats(Begins at: 4, Ends at:12)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :/raster/r.pi/r.pi.corrwin/readcell.c
          Function
readcell(Begins at: 6, Ends at:27)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :/raster/r.pi/r.pi.index/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.pi/r.pi.rectangle/main.c
          Class
alignment(Begins at: 9, Ends at:14)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
main(Begins at: 25, Ends at:263)
Complexity:   |      18 |     * |      WARNING |        18 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      71 |   *** |      MONSTER |        71 |
LOC:          |     239 |   *** |      MONSTER |       239 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/r.pi/r.pi.rectangle/buffer.c
          Function
set_buffer(Begins at: 3, Ends at:62)
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      60 |       |           OK |        60 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
          File :/raster/r.pi/r.pi.index/func.c
          Function
min_dist(Begins at: 272, Ends at:296)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      25 |       |           OK |        25 |
f_shapeindex(Begins at: 50, Ends at:74)
Complexity:   |       4 |       |           OK |         4 |
f_proximity(Begins at: 325, Ends at:337)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      13 |       |           OK |        13 |
f_borderindex(Begins at: 76, Ends at:112)
LOC:          |      37 |       |           OK |        37 |
f_asymmetry(Begins at: 152, Ends at:201)
LOC:          |      50 |       |           OK |        50 |
f_compactness(Begins at: 114, Ends at:150)
f_perim(Begins at: 26, Ends at:48)
LOC:          |      23 |       |           OK |        23 |
f_area_perim_ratio(Begins at: 203, Ends at:227)
f_frac_dim(Begins at: 229, Ends at:253)
CalledNBR:    |       3 |       |           OK |         3 |
f_area(Begins at: 10, Ends at:24)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      15 |       |           OK |        15 |
f_nearest_dist(Begins at: 298, Ends at:323)
LOC:          |      26 |       |           OK |        26 |
dist(Begins at: 255, Ends at:270)
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
          File :/raster/r.pi/r.pi.corrwin/bufs.c
          Function
allocate_bufs(Begins at: 12, Ends at:30)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
rotate_bufs(Begins at: 32, Ends at:61)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
Clone analysis:
          File :/raster/r.pi/r.pi.index/frag.c
          Function
getNeighbors(Begins at: 17, Ends at:66)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
writeFrag(Begins at: 68, Ends at:154)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      87 |     * |      WARNING |        87 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :/raster/r.pi/r.pi.index/main.c
          Class
menu(Begins at: 18, Ends at:23)
          Function
main(Begins at: 39, Ends at:319)
Complexity:   |      31 |    ** | BABY-MONSTER |        31 |
CalledNBR:    |      82 |   *** |      MONSTER |        82 |
LOC:          |     281 |   *** |      MONSTER |       281 |
Clone analysis:
          File :/raster/r.pi/r.pi.corrwin/intr_cats.c
          Function
intr_cats(Begins at: 4, Ends at:9)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
          File :/raster/r.pi/r.pi.rectangle/local_proto.h
          File :/raster/r.pi/r.pi.corrwin/main.c
          Function
main(Begins at: 21, Ends at:294)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
CalledNBR:    |      84 |   *** |      MONSTER |        84 |
LOC:          |     274 |   *** |      MONSTER |       274 |
Clone analysis:
          File :/raster/r.pi/r.pi.corrwin/gather.c
          Function
gather(Begins at: 10, Ends at:39)
Clone analysis:
          File :/raster/r.pi/r.pi.corrwin/local_proto.h
          File :/raster/r.pi/r.pi.corrwin/ncb.h
          Class
ncb(Begins at: 2, Ends at:17)
|OLD Metrics |        |        |        |        |        |        |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Aug 10 14:57:39 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
