[GRASS-QA] GRASS QA: mmetz |ami_stream.h | no clones | 0 monsters
|1 warnings
soccerlab.info at gmail.com
Sat Aug 14 14:03:49 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43103
ANALYSIS
your changes to files/class/methods/functions :
File :/include/iostream/ami_stream.h
Class
AMI_STREAM(Begins at: 153, Ends at:204)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 2 | 0 | 0 | 14 | 1 | 91 |
|OLD Metrics | 2 | 0 | 0 | 14 | 1 | 91 |
Class
AMI_STREAM<T>(Begins at: -9999, Ends at:-9999)
|NEW Metrics | 1 | 0 | 38 | 66 | 0 | 66 |
|OLD Metrics | 1 | 0 | 38 | 66 | 0 | 66 |
Method
stream_len(Begins at: 382, Ends at:428)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 47 | | OK | 47 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Class
UntypedStream(Begins at: 122, Ends at:150)
|NEW Metrics | 1 | 0 | 1 | 1 | 0 | 0 |
|OLD Metrics | 1 | 0 | 1 | 1 | 0 | 0 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Aug 14 14:03:46 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 17 | 41 | 65 |
LOC: | 65 | 147 | 230 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
