[GRASS-QA] GRASS QA: mmetz |mapset_msc.c remove.c copy_dir.c paths.c ...| no clones | 0 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Sat Aug 14 14:07:35 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43104
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/gis/mapset_msc.c
          Function
G__mapset_permissions2(Begins at: 133, Ends at:158)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      26 |       |           OK |        26 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G__mapset_permissions(Begins at: 100, Ends at:120)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      21 |       |           OK |        21 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/lib/gis/remove.c
          Function
recursive_remove(Begins at: 105, Ends at:130)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
          File :/lib/gis/copy_dir.c
          Function
G_recursive_copy(Begins at: 64, Ends at:146)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      25 |     * |      WARNING |        25 |
LOC:          |      83 |     * |      WARNING |        83 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :/lib/gis/paths.c
          Function
G_lstat(Begins at: 136, Ends at:143)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G_stat(Begins at: 119, Ends at:122)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Clone analysis:
          File :/lib/gis/user_config.c
          Function
_make_toplevel(Begins at: 50, Ends at:140)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      91 |     * |      WARNING |        91 |
_make_sublevels(Begins at: 193, Ends at:275)
CalledNBR:    |      23 |     * |      WARNING |        23 |
Clone analysis:
          File :/lib/gis/mapset_nme.c
          Function
G_available_mapsets(Begins at: 141, Ends at:182)
CalledNBR:    |      15 |       |           OK |        15 |
LOC:          |      42 |       |           OK |        42 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Aug 14 14:07:32 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        65 |       147 |       230 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
