[GRASS-QA] GRASS QA: hamish |main.c get_item.c poly2rast.c | no
clones | 0 monsters |3 warnings
soccerlab.info at gmail.com
Sun Aug 29 04:00:54 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 43331
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.in.poly/main.c
Function
main(Begins at: 20, Ends at:63)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 44 | | OK | 44 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/raster/r.in.poly/get_item.c
Function
get_item(Begins at: 5, Ends at:102)
Complexity: | 18 | * | WARNING | 18 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 24 | * | WARNING | 24 |
LOC: | 98 | * | WARNING | 98 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/raster/r.in.poly/poly2rast.c
Function
poly_to_rast(Begins at: 9, Ends at:98)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 28 | * | WARNING | 28 |
LOC: | 90 | * | WARNING | 90 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Aug 29 04:00:45 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
