[GRASS-QA] GRASS QA: glynn |Graph_close.c Graph_set.c main.cc
pngdriver.h | no clones | 0 monsters |2 warnings
soccerlab.info at gmail.com
Sun Aug 29 11:30:03 EDT 2010
Hello glynn,
here's a report on your recent grass-SVN change for the revision : 43338
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/pngdriver/Graph_close.c
Function
unmap_file(Begins at: 19, Ends at:35)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
PNG_Graph_close(Begins at: 37, Ends at:45)
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :/lib/pngdriver/Graph_set.c
Function
PNG_Graph_set(Begins at: 65, Ends at:152)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 32 | * | WARNING | 32 |
LOC: | 88 | * | WARNING | 88 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
map_file(Begins at: 31, Ends at:63)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 33 | | OK | 33 |
metrics are OK
Clone analysis:
File :/visualization/wximgview/main.cc
Class
MyApp(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 17 | 29 | 0 | 3 |
|OLD Metrics | | | | | | |
Method
map_file(Begins at: 170, Ends at:207)
Complexity: | 7 | | OK | |
ParamNBR: | 0 | | OK | |
CalledNBR: | 20 | * | WARNING | |
LOC: | 38 | | OK | |
at least 1 values are close to an outlier please consider revising code!
Class
MyFrame(Begins at: -9999, Ends at:-9999)
|NEW Metrics | 1 | 0 | 8 | 21 | 0 | 10 |
Clone analysis:
File :/lib/pngdriver/pngdriver.h
Class
png_state(Begins at: 18, Ends at:37)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sun Aug 29 11:29:57 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
