[GRASS-QA] GRASS QA: hamish |set_draw.c local_proto.h set_vpoints.c
set_ps.c ...| no clones | 1 monsters |4 warnings
soccerlab.info at gmail.com
Wed Dec 8 17:56:31 EST 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 44564
ANALYSIS
your changes to files/class/methods/functions :
File :/postscript/ps.output/set_draw.c
Function
set_draw(Begins at: 27, Ends at:335)
| New Metrics |Old Metrics|
Complexity: | 62 | *** | MONSTER | 62 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 136 | *** | MONSTER | 136 |
LOC: | 309 | *** | MONSTER | 309 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/postscript/ps.output/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :/postscript/ps.output/set_vpoints.c
Function
set_vpoints_line(Begins at: 131, Ends at:237)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 25 | * | WARNING | 25 |
LOC: | 107 | * | WARNING | 107 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
set_vpoints(Begins at: 22, Ends at:128)
Complexity: | 16 | * | WARNING | 16 |
CalledNBR: | 22 | * | WARNING | 22 |
Clone analysis:
File :/postscript/ps.output/set_ps.c
Function
set_ps_pattern(Begins at: 90, Ends at:141)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 52 | | OK | 52 |
at least 2 values are close to an outlier please consider revising code!
set_ps_rect(Begins at: 18, Ends at:22)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
File :/postscript/ps.output/ps3_map.c
____________________________________________
Threshold grass key metrics values at Wed Dec 08 17:56:14 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
