[GRASS-QA] GRASS QA: martinl |main.c lights.c change_view.c exag.c
| no clones | 1 monsters |5 warnings
soccerlab.info at gmail.com
Sat Jul 10 15:46:44 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42631
ANALYSIS
your changes to files/class/methods/functions :
File :/visualization/nviz2/cmd/main.c
Function
main(Begins at: 30, Ends at:193)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 82 | *** | MONSTER | 82 |
LOC: | 164 | ** | BABY-MONSTER | 164 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/lib/nviz/lights.c
Function
Nviz_set_light_color(Begins at: 88, Ends at:107)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Nviz_set_light_bright(Begins at: 63, Ends at:79)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 17 | | OK | 17 |
Nviz_set_light_ambient(Begins at: 116, Ends at:128)
LOC: | 13 | | OK | 13 |
Nviz_set_light_position(Begins at: 27, Ends at:54)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 28 | | OK | 28 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :/lib/nviz/change_view.c
Function
Nviz_change_exag(Begins at: 208, Ends at:223)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a OK |
metrics are OK
Nviz_set_viewpoint_position(Begins at: 94, Ends at:126)
Complexity: | 3 | | OK | 3 |
LOC: | 33 | | OK | 33 |
metrics are OK
Nviz_set_viewpoint_twist(Begins at: 190, Ends at:198)
ParamNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
metrics are OK
Nviz_resize_window(Begins at: 27, Ends at:49)
CalledNBR: | 6 | | OK | 6 |
LOC: | 23 | | OK | 23 |
metrics are OK
Nviz_set_viewpoint_height(Begins at: 136, Ends at:158)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
Nviz_set_viewpoint_persp(Begins at: 168, Ends at:180)
metrics are OK
Clone analysis:
File :/lib/nviz/exag.c
Function
Nviz_get_exag(Begins at: 76, Ends at:99)
Complexity: | 6 | | OK | 6 |
ParamNBR: | 0 | | OK | 0 |
LOC: | 24 | | OK | 24 |
metrics are OK
Nviz_get_exag_height(Begins at: 28, Ends at:67)
Complexity: | 8 | | OK | 8 |
LOC: | 40 | | OK | 40 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 15:46:31 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 44 | 70 |
LOC: | 72 | 163 | 255 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
