[GRASS-QA] GRASS QA: martinl |main.c args.c map_obj.c nviz.c ...|
no clones | 1 monsters |6 warnings
soccerlab.info at gmail.com
Sat Jul 10 15:57:38 EDT 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 42635
ANALYSIS
your changes to files/class/methods/functions :
File :/visualization/nviz2/cmd/main.c
Function
main(Begins at: 30, Ends at:214)
| New Metrics |Old Metrics|
Complexity: | 17 | * | WARNING | 17 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 89 | *** | MONSTER | 89 |
LOC: | 185 | ** | BABY-MONSTER | 185 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/visualization/nviz2/cmd/args.c
Function
args_lighting(Begins at: 569, Ends at:607)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 39 | | OK | 39 |
Conclusion: | this function is a OK |
metrics are OK
parse_command(Begins at: 44, Ends at:112)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 69 | | OK | 69 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
args_surface(Begins at: 114, Ends at:304)
CalledNBR: | 57 | ** | BABY-MONSTER | 57 |
LOC: | 191 | ** | BABY-MONSTER | 191 |
Conclusion: | this function is a BABY-MONSTER |
args_fringe(Begins at: 609, Ends at:637)
CalledNBR: | 10 | | OK | 10 |
LOC: | 29 | | OK | 29 |
metrics are OK
Clone analysis:
File :/lib/nviz/map_obj.c
Function
Nviz_new_map_obj(Begins at: 44, Ends at:165)
Complexity: | 20 | * | WARNING | 20 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 42 | * | WARNING | 42 |
LOC: | 122 | * | WARNING | 122 |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
File :/lib/nviz/nviz.c
Function
Nviz_init_data(Begins at: 25, Ends at:51)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 27 | | OK | 27 |
metrics are OK
Nviz_color_from_str(Begins at: 88, Ends at:100)
LOC: | 13 | | OK | 13 |
metrics are OK
Nviz_new_fringe(Begins at: 113, Ends at:143)
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 31 | | OK | 31 |
Nviz_destroy_data(Begins at: 57, Ends at:66)
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
metrics are OK
Clone analysis:
File :/include/nviz.h
Class
fringe_data(Begins at: 79, Ends at:85)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | | | | | | |
Class
render_window(Begins at: 110, Ends at:126)
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Clone analysis:
File :/visualization/nviz2/cmd/local_proto.h
Class
GParams(Begins at: 7, Ends at:34)
Clone analysis:
File :/lib/nviz/draw.c
Function
Nviz_draw_all(Begins at: 199, Ends at:245)
Complexity: | 6 | | OK | 6 |
LOC: | 47 | | OK | 47 |
metrics are OK
Clone analysis:
File :/lib/ogsf/GS2.c
Function
GS_draw_flowline_at_xy(Begins at: 744, Ends at:801)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 11 | | OK | 11 |
LOC: | 58 | | OK | 58 |
at least 1 values are close to an outlier please consider revising code!
GS_draw_fringe(Begins at: 811, Ends at:820)
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 15:57:26 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 19 | 44 | 70 |
LOC: | 72 | 163 | 255 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
