[GRASS-QA] GRASS QA: jarekj71 |fuzzylogic.c rule_parser.c main.c
helpers.c ...| no clones | 2 monsters |10 warnings
soccerlab.info at gmail.com
Sat Jul 10 19:56:42 EDT 2010
Hello jarekj71,
here's a report on your recent grass-SVN change for the revision : 42732
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.fuzzy.system/fuzzylogic.c
Function
f_and(Begins at: 60, Ends at:92)
| New Metrics |Old Metrics|
Complexity: | 8 | | OK | 8 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
fuzzy(Begins at: 3, Ends at:58)
Complexity: | 14 | * | WARNING | 14 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 56 | | OK | 56 |
Clone analysis:
This file does not contain cloned functions
File :/raster/r.fuzzy.system/rule_parser.c
Function
parse_rule_file(Begins at: 3, Ends at:58)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 20 | * | WARNING | 20 |
at least 2 values are close to an outlier please consider revising code!
parse_rules(Begins at: 62, Ends at:309)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 39 | * | WARNING | 39 |
LOC: | 248 | *** | MONSTER | 248 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/raster/r.fuzzy.system/main.c
Function
main(Begins at: 18, Ends at:259)
Complexity: | 38 | *** | MONSTER | 38 |
CalledNBR: | 101 | *** | MONSTER | 101 |
LOC: | 242 | *** | MONSTER | 242 |
Clone analysis:
File :/raster/r.fuzzy.system/helpers.c
Function
get_universe(Begins at: 53, Ends at:87)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 35 | | OK | 35 |
Conclusion: | this function is a OK |
metrics are OK
set_cats(Begins at: 216, Ends at:258)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 43 | | OK | 43 |
metrics are OK
show_membership(Begins at: 158, Ends at:214)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 57 | | OK | 57 |
set_colors(Begins at: 262, Ends at:267)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 6 | | OK | 6 |
metrics are OK
process_coors(Begins at: 89, Ends at:155)
CalledNBR: | 28 | * | WARNING | 28 |
LOC: | 67 | * | WARNING | 67 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :/raster/r.fuzzy.system/map_parser.c
Function
parse_map_file(Begins at: 3, Ends at:99)
Complexity: | 16 | * | WARNING | 16 |
CalledNBR: | 33 | * | WARNING | 33 |
LOC: | 97 | * | WARNING | 97 |
Clone analysis:
File :/raster/r.fuzzy.system/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.fuzzy.system/system.c
Function
implicate(Begins at: 3, Ends at:57)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 55 | | OK | 55 |
defuzzify(Begins at: 158, Ends at:198)
CalledNBR: | 0 | | OK | 0 |
LOC: | 41 | | OK | 41 |
parse_expression(Begins at: 59, Ends at:154)
Complexity: | 15 | * | WARNING | 15 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 96 | * | WARNING | 96 |
Clone analysis:
File :/raster/r.fuzzy.system/io.c
Function
get_cells(Begins at: 61, Ends at:102)
CalledNBR: | 3 | | OK | 3 |
LOC: | 42 | | OK | 42 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 19:56:25 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 42 | 66 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
