[GRASS-QA] GRASS QA: hamish |main.c exp_perms.c set_perms.c | no
clones | 0 monsters |3 warnings
soccerlab.info at gmail.com
Sat Jul 10 20:08:58 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 42737
ANALYSIS
your changes to files/class/methods/functions :
File :/general/g.access/main.c
Function
main(Begins at: 25, Ends at:89)
| New Metrics |Old Metrics|
Complexity: | 8 | | OK | 8 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 24 | * | WARNING | 24 |
LOC: | 65 | | OK | 65 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/general/g.access/exp_perms.c
Function
explain_perms(Begins at: 4, Ends at:34)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 31 | | OK | 31 |
Clone analysis:
File :/general/g.access/set_perms.c
Function
set_perms(Begins at: 9, Ends at:29)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 21 | | OK | 21 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Sat Jul 10 20:08:41 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 42 | 66 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
