[GRASS-QA] GRASS QA: jarekj71 |local_proto.h memory.c main.c slope_aspect.c | no clones | 0 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Jun 7 04:14:19 EDT 2010
Hello jarekj71,
here's a report on your recent grass-SVN change for the revision : 42493
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.convergence/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/raster/r.convergence/memory.c
          Function
create_maps(Begins at: 73, Ends at:94)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      22 |       |           OK |        22 |
Conclusion:   | this function is a            OK           |
metrics are OK
free_map(Begins at: 143, Ends at:149)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
get_cell(Begins at: 43, Ends at:70)
Complexity:   |       8 |       |           OK |         8 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      28 |       |           OK |        28 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
open_map(Begins at: 3, Ends at:41)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      20 |       |           OK |        20 |
LOC:          |      39 |       |           OK |        39 |
metrics are OK
shift_buffers(Begins at: 96, Ends at:141)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      46 |       |           OK |        46 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/raster/r.convergence/main.c
          Function
main(Begins at: 21, Ends at:182)
Complexity:   |      15 |     * |      WARNING |        15 |
CalledNBR:    |      64 |    ** | BABY-MONSTER |        64 |
LOC:          |     162 |     * |      WARNING |       162 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :/raster/r.convergence/slope_aspect.c
          Function
calculate_convergence(Begins at: 159, Ends at:230)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      72 |       |           OK |        72 |
 at least 2 values are close to an outlier please consider revising code!
create_distance_aspect_matrix(Begins at: 32, Ends at:95)
CalledNBR:    |      19 |       |           OK |        19 |
LOC:          |      64 |       |           OK |        64 |
metrics are OK
get_distance(Begins at: 2, Ends at:30)
LOC:          |      29 |       |           OK |        29 |
metrics are OK
get_slope_aspect(Begins at: 97, Ends at:157)
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      61 |       |           OK |        61 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Jun 07 04:14:18 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        11 |        24 |        38 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        21 |        49 |        78 |
LOC:                  |        80 |       183 |       287 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
