[GRASS-QA] GRASS QA: mmetz |catchment.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Jun 8 03:39:18 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 42504
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.stream.basins/catchment.c
Function
fifo_return_del(Begins at: 194, Ends at:206)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a OK |
metrics are OK
fifo_insert(Begins at: 179, Ends at:192)
CalledNBR: | 2 | | OK | 2 |
LOC: | 14 | | OK | 14 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Jun 08 03:38:55 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 11 | 24 | 38 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 21 | 49 | 78 |
LOC: | 79 | 181 | 283 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
