[GRASS-QA] GRASS QA: mmetz |r.univar_main.c globals.h stats.c
r3.univar_main.c | 4 clones | 1 monsters |4 warnings
soccerlab.info at gmail.com
Tue Nov 2 22:52:54 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43812
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.univar/r.univar_main.c
Function
process_raster(Begins at: 245, Ends at:365)
| New Metrics |Old Metrics|
Complexity: | 22 | ** | BABY-MONSTER | 22 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 121 | * | WARNING | 121 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
univar_stat_with_percentiles(Begins at: 222, Ends at:243)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a OK |
metrics are OK
set_params(Begins at: 27, Ends at:69)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 43 | | OK | 43 |
metrics are OK
open_raster(Begins at: 207, Ends at:220)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 14 | | OK | 14 |
metrics are OK
main(Begins at: 79, Ends at:205)
Complexity: | 19 | ** | BABY-MONSTER | 19 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 43 | ** | BABY-MONSTER | 43 |
LOC: | 127 | * | WARNING | 127 |
Clone analysis:
This file has 2 potentially cloned functions:
set_params
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r.univar_main.c clones of univar_stat_with_percentiles are:
/data/project-manager/grass/grassSVN/grass-addons/raster/r.univar.zonal/r.univar_main.c univar_stat_with_percentiles
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r.univar_main.c clones of set_params are:
/data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r3.univar_main.c set_params
File :/raster/r.univar/globals.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.univar/stats.c
Function
print_stats_table(Begins at: 298, Ends at:494)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
CalledNBR: | 56 | ** | BABY-MONSTER | 56 |
LOC: | 197 | ** | BABY-MONSTER | 197 |
free_univar_stat_struct(Begins at: 77, Ends at:99)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
metrics are OK
print_stats(Begins at: 105, Ends at:296)
Complexity: | 29 | ** | BABY-MONSTER | 29 |
CalledNBR: | 54 | ** | BABY-MONSTER | 54 |
LOC: | 192 | ** | BABY-MONSTER | 192 |
create_univar_stat_struct(Begins at: 19, Ends at:71)
Complexity: | 4 | | OK | 4 |
LOC: | 53 | | OK | 53 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/stats.c clones of free_univar_stat_struct are:
/data/project-manager/grass/grassSVN/grass-addons/raster/r.univar.zonal/stats.c free_univar_stat_struct
File :/raster/r.univar/r3.univar_main.c
Function
main(Begins at: 76, Ends at:307)
Complexity: | 43 | *** | MONSTER | 43 |
CalledNBR: | 64 | ** | BABY-MONSTER | 64 |
LOC: | 232 | ** | BABY-MONSTER | 232 |
Conclusion: | this function is a MONSTER |
set_params(Begins at: 28, Ends at:70)
metrics are OK
Clone analysis:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r3.univar_main.c clones of set_params are:
/data/project-manager/grass/grassSVN/grass/trunk/raster/r.univar/r.univar_main.c set_params
____________________________________________
Threshold grass key metrics values at Tue Nov 02 22:52:41 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
