[GRASS-QA] GRASS QA: mmetz |sp-template.c | no clones | 1 monsters
|3 warnings
soccerlab.info at gmail.com
Wed Nov 3 00:43:12 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43857
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/vector/dglib/sp-template.c
Function
DGL_SP_CACHE_INITIALIZE_FUNC(Begins at: 39, Ends at:55)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
DGL_SP_DIJKSTRA_FUNC(Begins at: 300, Ends at:607)
Complexity: | 40 | *** | MONSTER | 40 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 54 | ** | BABY-MONSTER | 54 |
LOC: | 308 | *** | MONSTER | 308 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
DGL_SP_CACHE_REPORT_FUNC(Begins at: 91, Ends at:216)
Complexity: | 18 | * | WARNING | 18 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 32 | * | WARNING | 32 |
LOC: | 126 | * | WARNING | 126 |
at least 4 values are close to an outlier please consider revising code!
DGL_SP_CACHE_DISTANCE_FUNC(Begins at: 67, Ends at:89)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 23 | | OK | 23 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Nov 03 00:42:58 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 67 | 151 | 235 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
