[GRASS-QA] GRASS QA: neteler |index.h renyi.c pielou.c | 9 clones |
6 monsters |3 warnings
soccerlab.info at gmail.com
Mon Nov 29 22:35:36 EST 2010
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 44428
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.li/r.li.daemon/index.h
The system don't find class, method and function
in this file during analysis!
File :/raster/r.li/r.li.renyi/renyi.c
Function
calculate(Begins at: 134, Ends at:328)
| New Metrics |Old Metrics|
Complexity: | 32 | *** | MONSTER | 32 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 35 | * | WARNING | 35 |
LOC: | 195 | ** | BABY-MONSTER | 195 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
calculateD(Begins at: 331, Ends at:523)
LOC: | 193 | ** | BABY-MONSTER | 193 |
calculateF(Begins at: 527, Ends at:726)
LOC: | 200 | ** | BABY-MONSTER | 200 |
main(Begins at: 35, Ends at:88)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 24 | * | WARNING | 24 |
LOC: | 54 | | OK | 54 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
renyi(Begins at: 90, Ends at:130)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 41 | | OK | 41 |
Clone analysis:
This file has 1 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.renyi/renyi.c clones of renyi are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.mps/mps.c meanPatchSize
File :/raster/r.li/r.li.pielou/pielou.c
Function
calculate(Begins at: 126, Ends at:355)
Complexity: | 36 | *** | MONSTER | 36 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 36 | * | WARNING | 36 |
LOC: | 230 | ** | BABY-MONSTER | 230 |
calculateD(Begins at: 359, Ends at:584)
Complexity: | 35 | *** | MONSTER | 35 |
LOC: | 226 | ** | BABY-MONSTER | 226 |
calculateF(Begins at: 587, Ends at:809)
LOC: | 223 | ** | BABY-MONSTER | 223 |
cmp(Begins at: 36, Ends at:46)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 48, Ends at:81)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 34 | | OK | 34 |
metrics are OK
pielou(Begins at: 83, Ends at:123)
Clone analysis:
This file has 8 potentially cloned functions:
cmp_exist cmp cmp srch srch_cat dominance shannon
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.pielou/pielou.c clones of cmp are:
/data/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/ascii.c srch
/data/project-manager/grass/grassSVN/grass/trunk/vector/v.distance/main.c cmp_exist
/data/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/main.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.extract/main.c cmp
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.to.3d/trans3.c srch
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.what.rast/main.c srch_cat
In /data/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.pielou/pielou.c clones of pielou are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.dominance/dominance.c dominance
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.li/r.li.shannon/shannon.c shannon
____________________________________________
Threshold grass key metrics values at Mon Nov 29 22:35:17 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
