[GRASS-QA] GRASS QA: martinl |parser.c | no clones | 1 monsters |0
warnings
soccerlab.info at gmail.com
Mon Nov 29 22:48:40 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44433
ANALYSIS
your changes to files/class/methods/functions :
File :/lib/gis/parser.c
Function
G_parser(Begins at: 310, Ends at:571)
| New Metrics |Old Metrics|
Complexity: | 43 | *** | MONSTER | 43 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 86 | *** | MONSTER | 86 |
LOC: | 262 | *** | MONSTER | 262 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
check_required(Begins at: 1129, Ends at:1151)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 23 | | OK | 23 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Nov 29 22:48:20 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
