[GRASS-QA] GRASS QA: martinl |gdal.c | no clones | 1 monsters |3 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Nov 30 01:04:10 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44481
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/raster/gdal.c
          Class
GDAL_Options(Begins at: 336, Ends at:342)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Function
Rast_close_gdal_write_link(Begins at: 580, Ends at:608)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a            OK           |
metrics are OK
Rast_init_gdal(Begins at: 201, Ends at:213)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
read_gdal_options(Begins at: 354, Ends at:391)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      38 |       |           OK |        38 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Rast_close_gdal_link(Begins at: 563, Ends at:570)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Rast_gdal_raster_IO(Begins at: 616, Ends at:625)
ParamNBR:     |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Rast_get_gdal_link(Begins at: 224, Ends at:334)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |     111 |     * |      WARNING |       111 |
Conclusion:   | this function is a  BABY-MONSTER           |
load_library(Begins at: 103, Ends at:133)
LOC:          |      31 |       |           OK |        31 |
metrics are OK
Rast_create_gdal_link(Begins at: 402, Ends at:556)
CalledNBR:    |      47 |    ** | BABY-MONSTER |        47 |
LOC:          |     155 |    ** | BABY-MONSTER |       155 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Nov 30 01:03:48 EST 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |        10 |        22 |        34 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        68 |       153 |       239 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
