[GRASS-QA] GRASS QA: martinl |local_proto.h args.c main.c | no
clones | 1 monsters |1 warnings
soccerlab.info at gmail.com
Tue Nov 30 01:12:48 EST 2010
Hello martinl,
here's a report on your recent grass-SVN change for the revision : 44484
ANALYSIS
your changes to files/class/methods/functions :
File :/vector/v.out.ogr/local_proto.h
Class
Flags(Begins at: 13, Ends at:15)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
Options(Begins at: 8, Ends at:11)
Clone analysis:
This file does not contain cloned functions
File :/vector/v.out.ogr/args.c
Function
parse_args(Begins at: 5, Ends at:111)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 44 | ** | BABY-MONSTER | 44 |
LOC: | 107 | * | WARNING | 107 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/vector/v.out.ogr/main.c
Function
main(Begins at: 30, Ends at:926)
Complexity: | 138 | *** | MONSTER | 138 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 351 | *** | MONSTER | 351 |
LOC: | 897 | *** | MONSTER | 897 |
Conclusion: | this function is a MONSTER |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Nov 30 01:12:27 EST 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 10 | 22 | 34 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 68 | 153 | 239 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
