[GRASS-QA] GRASS QA: hamish |tools.c main.c local_proto.h algorithm.c | no clones | 1 monsters |4 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Sep 9 03:57:23 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 43433
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.landsat.acca/tools.c
          Function
pval(Begins at: 120, Ends at:128)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a            OK           |
metrics are OK
quantile(Begins at: 86, Ends at:108)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      23 |       |           OK |        23 |
metrics are OK
hist_put(Begins at: 26, Ends at:39)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
mean(Begins at: 42, Ends at:57)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
filter_holes(Begins at: 130, Ends at:340)
Complexity:   |      32 |   *** |      MONSTER |        32 |
CalledNBR:    |      87 |   *** |      MONSTER |        87 |
LOC:          |     211 |    ** | BABY-MONSTER |       211 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
moment(Begins at: 59, Ends at:84)
Complexity:   |       5 |       |           OK |         5 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.landsat.acca/main.c
          Function
check_raster(Begins at: 49, Ends at:82)
Complexity:   |       7 |       |           OK |         7 |
CalledNBR:    |      12 |       |           OK |        12 |
LOC:          |      34 |       |           OK |        34 |
metrics are OK
main(Begins at: 89, Ends at:206)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |      42 |     * |      WARNING |        42 |
LOC:          |     118 |     * |      WARNING |       118 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :/imagery/i.landsat.acca/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :/imagery/i.landsat.acca/algorithm.c
          Function
acca_first(Begins at: 203, Ends at:341)
Complexity:   |      23 |    ** | BABY-MONSTER |        23 |
ParamNBR:     |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |     139 |     * |      WARNING |       139 |
Conclusion:   | this function is a  BABY-MONSTER           |
acca_second(Begins at: 344, Ends at:441)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
LOC:          |      98 |     * |      WARNING |        98 |
acca_algorithm(Begins at: 75, Ends at:200)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      26 |     * |      WARNING |        26 |
LOC:          |     126 |     * |      WARNING |       126 |
 at least 4 values are close to an outlier please consider revising code!
shadow_algorithm(Begins at: 449, Ends at:460)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Sep 09 03:57:17 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        43 |        69 |
LOC:                  |        66 |       148 |       231 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
