[GRASS-QA] GRASS QA: hamish |landsat.c landsat_met.c | no clones |
0 monsters |3 warnings
soccerlab.info at gmail.com
Thu Sep 9 04:15:41 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 43435
ANALYSIS
your changes to files/class/methods/functions :
File :/imagery/i.landsat.toar/landsat.c
Function
lsat_bandctes(Begins at: 51, Ends at:169)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 119 | * | WARNING | 119 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :/imagery/i.landsat.toar/landsat_met.c
Function
met_TM5(Begins at: 137, Ends at:194)
Complexity: | 12 | * | WARNING | 12 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 23 | * | WARNING | 23 |
LOC: | 58 | | OK | 58 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
met_ETM(Begins at: 43, Ends at:108)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 26 | * | WARNING | 26 |
LOC: | 66 | * | WARNING | 66 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Sep 09 04:15:38 EDT 2010 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 19 | 30 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 18 | 43 | 69 |
LOC: | 66 | 148 | 231 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
