[GRASS-QA] GRASS QA: mmetz |lidar.h zones.c | 2 clones | 0 monsters
	|2 warnings
    soccerlab.info at gmail.com
    Fri Sep 17 08:58:13 EDT 2010
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 43484
ANALYSIS
your changes to files/class/methods/functions :
          File :/lib/lidar/lidar.h
          Class
Point(Begins at: 79, Ends at:86)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
Reg_dimens(Begins at: 70, Ends at:77)
          Class
element(Begins at: 88, Ends at:93)
Clone analysis:
This file does not contain cloned functions
          File :/lib/lidar/zones.c
          Function
P_Read_Vector_Region_Map(Begins at: 320, Ends at:385)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      66 |     * |      WARNING |        66 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
P_Read_Raster_Region_Map(Begins at: 387, Ends at:479)
Complexity:   |      16 |     * |      WARNING |        16 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      93 |     * |      WARNING |        93 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 2 potentially cloned functions:
In /data/project-manager/grass/grassSVN/grass/trunk/lib/lidar/zones.c clones of P_Read_Vector_Region_Map are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/lidarlib/zones.c  P_Read_Vector_Region_Map
In /data/project-manager/grass/grassSVN/grass/trunk/lib/lidar/zones.c clones of P_Read_Raster_Region_Map are:
          /data/project-manager/grass/grassSVN/grass/trunk/vector/lidar/lidarlib/zones.c  P_Read_Raster_Region_Map
____________________________________________
Threshold grass key metrics values at Fri Sep 17 08:58:10 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        17 |        41 |        65 |
LOC:                  |        66 |       150 |       234 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
