[GRASS-QA] GRASS QA: neteler |main.c main.c main.c main.c ...| no
clones | 0 monsters |5 warnings
soccerlab.info at gmail.com
Fri Apr 15 08:59:39 EDT 2011
Hello neteler,
here's a report on your recent grass-SVN change for the revision : 45985
ANALYSIS
your changes to files/class/methods/functions :
File :/raster/r.stream.del/main.c
Function
main(Begins at: 31, Ends at:108)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | 5 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 30 | * | WARNING | 30 |
LOC: | 78 | * | WARNING | 78 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :/raster/r.stream.distance/main.c
Function
main(Begins at: 33, Ends at:195)
Complexity: | 16 | * | WARNING | 16 |
CalledNBR: | 54 | ** | BABY-MONSTER | 54 |
LOC: | 163 | ** | BABY-MONSTER | 163 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :/raster/r.stream.basins/main.c
Function
main(Begins at: 30, Ends at:178)
Complexity: | 14 | * | WARNING | 14 |
CalledNBR: | 42 | ** | BABY-MONSTER | 42 |
LOC: | 149 | ** | BABY-MONSTER | 149 |
Clone analysis:
File :/raster/r.stream.order/main.c
Function
main(Begins at: 24, Ends at:203)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 47 | ** | BABY-MONSTER | 47 |
LOC: | 180 | ** | BABY-MONSTER | 180 |
Clone analysis:
File :/raster/r.stream.stats/main.c
Function
main(Begins at: 32, Ends at:97)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 66 | * | WARNING | 66 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Fri Apr 15 08:59:34 EDT 2011 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 9 | 21 | 33 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 16 | 38 | 61 |
LOC: | 63 | 142 | 222 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
