[GRASS-QA] GRASS QA: mmetz |common.h main.cpp Altitude.cpp Altitude.h ...| 6 clones | 1 monsters |7 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Apr 18 02:16:58 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 46015
ANALYSIS
your changes to files/class/methods/functions :
          File :/imagery/i.atcorr/common.h
          Class
Sixs_aer(Begins at: 41, Ends at:47)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |        |        |        |        |        |        |
          Class
Sixs_aerbas(Begins at: 49, Ends at:61)
|NEW Metrics |      1 |      0 |      0 |      1 |      0 |      0 |
          Class
Sixs_disc(Begins at: 69, Ends at:80)
          Class
Sixs_sos(Begins at: 34, Ends at:39)
          Class
Sixs_trunc(Begins at: 63, Ends at:67)
Clone analysis:
This file does not contain cloned functions
          File :/imagery/i.atcorr/main.cpp
          Class
Options(Begins at: 60, Ends at:79)
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
RBitem(Begins at: 87, Ends at:92)
          Class
ScaleRange(Begins at: 81, Ends at:85)
          Class
TICache(Begins at: 173, Ends at:225)
|NEW Metrics |      1 |      0 |      5 |     11 |      0 |      2 |
|OLD Metrics |      1 |      0 |      8 |      4 |      0 |      2 |
          Method
set_alt_vis(Begins at: 179, Ends at:191)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |           |
ParamNBR:     |       2 |       |           OK |           |
CalledNBR:    |       0 |       |           OK |           |
LOC:          |      13 |       |           OK |           |
Conclusion:   | this function is a            OK           |
metrics are OK
search(Begins at: 199, Ends at:212)
Complexity:   |       2 |       |           OK |         3 |
ParamNBR:     |       3 |     * |      WARNING |         1 |
CalledNBR:    |       2 |       |           OK |         0 |
LOC:          |      14 |       |           OK |        10 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
add(Begins at: 214, Ends at:224)
Complexity:   |       1 |       |           OK |         2 |
ParamNBR:     |       5 |     * |      WARNING |         2 |
CalledNBR:    |       1 |       |           OK |         0 |
LOC:          |      11 |       |           OK |         6 |
TICache(Begins at: 194, Ends at:198)
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |       5 |       |           OK |         1 |
metrics are OK
          Function
adjust_region(Begins at: 111, Ends at:118)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
read_scale(Begins at: 523, Ends at:549)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
define_module(Begins at: 417, Ends at:445)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
define_options(Begins at: 449, Ends at:520)
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |      72 |     * |      WARNING |        72 |
 at least 2 values are close to an outlier please consider revising code!
process_raster(Begins at: 242, Ends at:402)
Complexity:   |      25 |    ** | BABY-MONSTER |        25 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      42 |    ** | BABY-MONSTER |        42 |
LOC:          |     161 |    ** | BABY-MONSTER |       161 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
write_fp_to_cell(Begins at: 132, Ends at:142)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
round_c(Begins at: 122, Ends at:128)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
compare_hv(Begins at: 145, Ends at:170)
Complexity:   |       7 |       |           OK |         7 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
main(Begins at: 552, Ends at:656)
Complexity:   |      16 |     * |      WARNING |        16 |
CalledNBR:    |      44 |    ** | BABY-MONSTER |        44 |
LOC:          |     105 |     * |      WARNING |       105 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
This file has 6 potentially cloned functions:
  /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  read_scale  define_module  define_options  write_fp_to_cell
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of TICache are:
          152  /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp
          205  /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of read_scale are:
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_module are:
          /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  define_module
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of define_options are:
          /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  define_options
In /data/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp clones of write_fp_to_cell are:
          /var/project-manager/grass/grassSVN/grass/trunk/imagery/i.atcorr/main.cpp  write_fp_to_cell
          File :/imagery/i.atcorr/Altitude.cpp
          Class
Altitude(Begins at: -9999, Ends at:-9999)
|NEW Metrics |      1 |      0 |     36 |     47 |      0 |     21 |
          Method
init(Begins at: 192, Ends at:279)
Complexity:   |       9 |     * |      WARNING |           |
CalledNBR:    |      11 |       |           OK |           |
LOC:          |      88 |     * |      WARNING |           |
update_hv(Begins at: 281, Ends at:360)
CalledNBR:    |       9 |       |           OK |           |
LOC:          |      80 |     * |      WARNING |           |
parse(Begins at: 362, Ends at:371)
ParamNBR:     |       0 |       |           OK |           |
CalledNBR:    |       4 |       |           OK |           |
LOC:          |      10 |       |           OK |           |
metrics are OK
Clone analysis:
          File :/imagery/i.atcorr/Altitude.h
          Class
Altitude(Begins at: 42, Ends at:96)
|NEW Metrics |      1 |      0 |      1 |      8 |      0 |     28 |
          Method
set_height(Begins at: 89, Ends at:89)
ParamNBR:     |       1 |       |           OK |           |
LOC:          |       1 |       |           OK |           |
metrics are OK
          Class
Plane_sim(Begins at: 59, Ends at:66)
Clone analysis:
          File :/imagery/i.atcorr/6s.cpp
          Function
pre_compute_v(Begins at: 126, Ends at:137)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
pre_compute_hv(Begins at: 111, Ends at:123)
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
pre_compute_h(Begins at: 140, Ends at:151)
metrics are OK
init_6S(Begins at: 45, Ends at:107)
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      63 |     * |      WARNING |        63 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Mon Apr 18 02:16:43 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        63 |       142 |       222 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
